Question about Vacuums
Hey how are u all doing? i have a mazda b2200 p/up,i'm installing a carburetor,but needs a detaile intruction how to connect the vacuum hoses,can anyone help please
  • 4 Answers
Start here
http://autorepair.about.com/library/faqs/bl419h.htm
Vacuum hoses are used one for servo brake asssy other for oil drainage at airfilter casing, hot-cold air inlet selection etc . It is bettter to find a user manual that shows a schematic layout.
Good Luck!
Posted on Mar 16, 2008
SOURCE:
How do I installa new hose to the mortorized brush head on my shark lift waway
Hi, it's Allie from Crucial Vacuum!
Replacing your Shark Floor Nozzle Hose is very easy. Start by unplugging your unit to avoid any safety hazards. The floor nozzle hose's side that attached to the floor base of your Navigator can easily be pulled away. The other side of the floor nozzle hose has two tabs that can be pushed in while pulling it away from the base.
When installing, connect the floor nozzle hose to the canister first by pressing both side tabs while placing it until it click in its place. Then connect the hose to the floor base.
You can purchase direct your replacement hose and filters from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/catalogsearch/result/?q=NV352
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Alejandra (Allie) Sepulveda-Rivera
Crucial Vacuum Customer Care
Sep 10, 2014 | Shark Vacuum. Navigator Lift-Away Bagless...
How do i put the wand back together on a rainbow e-series ?
The wire schematics in the handle assembly has four total wires. Two from the hose and two from the Receptacle Nozzle. Take one wire from the hose and one wire from the receptacle and connect together. Take the second wire from the hose and connect to the Switch Handle PN2E PN2. Take the second wire from the receptacle and connect to the other switch terminal. If you need more details, you can download the schematics at Rainbow Vacuum Schematics or you can call us at 800-523-0510.
RainVac
www.rainvac.com
May 30, 2014 | Rainbow E series Canister Wet/Dry Vacuum
Attatchment stuck in hose of bissell
Hey Chelsea! Try turning the attachment while trying to pull it out. If that doesn't work, run the connection under some warm water.
If you're still having difficulty, you may want to have a Qualified Technician at one of our Authorized Service Centers assist you.
Here's a quick link to locating one.
http://www.bissell.com/service-centers/?cid=ccsocial
Jan 03, 2013 | Bissell 3594 CleanView PowerTrak Bagless...
I have a S3765 Hoover Wind Tunnel with a crack in the hose close to the cannister. I know wires run through the hose and that there are wire connections on either end of the hose. The replacement hose...
If the vacuum has been maintained properly and runs well it may be worth repairing. The hose is pricey but less than a new vacuum. Many new vacuums today, especially lower priced ones are very poor quality and don't last much longer than a year. It appears by the schematics of your model you can replace just the hose section or the entire hose assembly. Replacing the hose only would require removing the ends of your old hose and installing them on the new hose.
Sep 28, 2017 | Hoover S3670 Bagged Canister Vacuum
Hey guys, my dyson vacuum hose has been clogged by dog hair. how do i reach a lower bit of the hose to unclog it??
You should be able to clear the blockage in your DC24 hose by following these simple steps: http://www.dyson.co.uk/support/help.asp?article=1513&product=DC24-ALLFLOORS
This should resolve the issue, but if you need any further help or advice, please get in touch with us, free, on 08002980298 (UK), or 1866MYDYSON (US), so we can provide assistance.
Kind regards,
Jack
Dyson Customer Service
Nov 16, 2010 | Dyson Ball DC24 Bagless Upright Vacuum
Intructions
Hey storm,
Rather than type all that out, it's faster to get you a copy of the instructions.
Fortunately, like most (though not all) manufacturers, Bissell makes owner manuals for their recent carpet cleaners available online on their website. Go here
http://www.bissell.com/Product_Search.aspx?Criteria=9500
and choose the manual for your model ["User Guide (PDF)"]. As long as you have free Adobe Reader software installed on your computer, you can read and/or print the manual out for free.
Jun 06, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Connect or disconnect hose on upright vacuum
The hose has to be connected to engage the suction. To test this, is there suction in the hose when you turn the vacuum on? If so then the hose needs to be connected.
Jan 31, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Decreased hose suction with Windtunnel
There are very few things left to check. First verify that the filter is installed properly, in the dirt cup. second check to make sure the dirt cup lid is on and secure. Did you use water on the round dirt cup filter? if you have you will need to replace it. To verify this remove the round filter and re-install the dirt cup on the vac. do not vacuum the carpet, just turn it on to check for proper suction. and then turn it off.
Your problem has nothing to do with it in the upright position. once turned on you will always have suction, either to the floor or when hose is removed from foot for accessories.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
Dec 03, 2008 | Hoover U5753-900 WindTunnel Bagless...
Vacuums Logo
184 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
