Question about Car Audio & Video
Running wirer from driver seat to stereo dodger ram truck 2003
How to get wire from under front driver seat to stereo in a dodge ram truck 2003 hiding the wire.
  • sunnycal77 Mar 18, 2008
    You told me to go buy a book. My wife works at a book store I thought fixya.com whould be faster. Thanks for all your help and telling to go buy a book to fix my problem.
    Problem Solver:
  • 13 Answers
Peel away the door seal to release the carpet abit and then with a bit of time and effort work the wire through?depends on how easy the carpet comes awya to how long it will take,once the wire is through just place it all back in reverse order
i hope this helps?
Posted on Mar 15, 2008
SOURCE:
My drivers side front speaker stopped working in my 2003 dodge ram pickup
remove the speaker from drivers side , put that speaker in passengers side , if works in passenger side then speaker is o.k and if not speaker is stuffed if working wiring problem in drivers door or from stereo head unit .
Mar 28, 2014 | Dodge Ram 1500 Cars & Trucks
2001 dodge ram left front speaker not working
Check your wires but static could be if you ran your twelve volt amp wire and your stereo to amp wire on same side.
Apr 14, 2013 | 2001 Dodge Ram 3500 Truck
Need to wirer kenwood kdc-hd545u radio to my 1999toyato avalo and the wirer harness has been cut off the toyato need wirer diagram to match wirer colorsto make it work!!
1999 Toyota Corolla Car Radio Stereo Audio Wiring Diagram
Car Radio Constant 12v+ Wire: Blue/Yellow
Car Radio Switched 12v+ Wire: Gray
Car Radio Ground Wire: Brown
Car Radio Illumination Wire: Green
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Pink
Left Front Speaker Negative Wire (-): Violet
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Blue
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Black
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Red
Right Rear Speaker Negative Wire (-): White
Oct 14, 2012 | 1995 Toyota Corolla
I have a 2004 dodge ram 2500, the passenger window switches don't work
Not uncommon, the master window switch on the driver's door goes wonky. Mine had same problem (2003 1500 4.7L long cab) and simply replacing the master switch fixed both bad passenger switch intermittent problems. Easy swap, cheap at the dealer.
Oct 08, 2011 | 2004 Dodge Ram 2500
2001 dodge stratus coup raido wire diagram
i split the diagram in two just prtin and paste. and please leve 4 thumbs up thanks
May 07, 2011 | Dodge Stratus Cars & Trucks
Wiring harness for 2004 dodge ram 2500. I need to know the wire colors for the rear speakers
2004 Dodge Ram 2500 Truck Car Radio Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Pink
Car Radio Accessory Switched 12v+ Wire: Brown/Red
Car Radio Ground Wire: Black/Dark Green
Car Radio Illumination Wire: Orange/Dark Blue
Car Stereo Antenna Trigger Wire: N/A
Left Front Speaker Positive Wire (+): Dark Green
Left Front Speaker Negative Wire (-): Brown/Red
Right Front Speaker Positive Wire (+): Violet
Right Front Speaker Negative Wire (-): Dark Blue/Red
Left Rear Speaker Positive Wire (+): Brown/Yellow
Left Rear Speaker Negative Wire (-): Brown/Light Blue
Right Rear Speaker Positive Wire (+): Dark Blue/White
Right Rear Speaker Negative Wire (-): Dark Blue/Orange
Sep 12, 2010 | 2004 Dodge Ram 2500
I am installing a CD player into a 1996 Dodge Ram 2500 Truck and I need the diagram
Here you go:
1996 Dodge Ram 2500 Truck Car Audio Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Red
Car Radio Accessory Switched 12v+ Wire: Red/White
Car Radio Ground Wire: Chassis
Car Radio Illumination Wire: N/A
Car Stereo Dimmer Wire: Orange/White
Car Stereo Antenna Trigger Wire: Yellow
May 12, 2010 | 1996 Dodge Ram 2500 Club Cab
Power windows only work at driver,s seat. 2003 dodge truck
turn the lockout button on and off a few dozen times. things get spilled and sometimes that will clean off the contacts.
Sep 21, 2009 | 1999 Dodge Ram
Front seat in 1996 Dodge Ram Pickup won't slide forward or back
1.Make sure the stiff wire that crosses under the seat to the passenger side latch hasn't come off. 2.Soak the slides with some good penatrating oil (NOT WD40!).
May 30, 2009 | 1996 Dodge Ram 1500 Club Cab
I need a audio wiring schamatic for a 1997 dodge laramie 1500
1997 Dodge Ram Truck Stereo Radio Wiring Diagram
Car Radio Constant 12v+ Wire: Red
Car Radio Switched 12v+ Wire: Red/White
Car Stereo Antenna Trigger: Yellow
Car Stereo Amplifier Location: Behind the glove box.
Apr 28, 2009 | 1997 Dodge Ram
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
