We use the small plastic wrapped Cascade tablets. It worked fine. Now, however, the cycles run fine but at the end of the cycle the detergent door is open, the tablet has not dissolved and the detergent is spilled over the inside. I think there might be a clog in the detergent line that is not allowing the detergent to flow.
Please advise. Many thanks.
Either:
1. not enough water gets into the dishwasher. open the dishwasher 3-4 times during cycle, you should see some water on the bottom at least once, if not - check water valve, water level float and water pressure.
2. the pump is clogged - there is water, the motor will run but no water is circulated. Check pump filters, check chopper and impeller.
3. motor in main pump is not working - could be caused by something stuck on the impeller or chopper or could be a problem with the motor itself or control board. Check if line voltage is coming to the motor during wash/rinse cycle.
Good luck,
Vlad
First Choice Appliance
SOURCE: We use the Cascade tablets but they don't dissolve
Either:
1. the water does not get into the dishwasher open the dishwasher 3-4 times during cycle, you should see some water at least once, if not - check water valve, water level float and water pressure.
Good luck,
Vlad
