Question about Sanyo DWM-3800 System
Missing wire I am missing the audio wire, with the little port hole, that connects the subwoofer to the DVD/VCR unit, where would I get a new one?
  • drv1 Aug 17, 2008
    Missing the Audio cable to hook up the sub-woofer to the unit---- where can I buy a replacement cable???
  • daddydragoon Sep 21, 2008
    missing wire
To you that have the sanyo dwm-3800u vcr dvd playerin need of the 9 pin cord
you can get this cord by calling jinnie at 870-633-5030 she works for sanyo
Russell
Posted on Jan 05, 2009
6ya staff
SOURCE:
I have a sb wa340 active subwoofer. I have subwoofer and speakers but I don't have DVD how can I use this
So is the DVD part missing? There is a VCR / Aux input on the back but it is for audio only. There are no video inputs so if the DVD is not included in your sub/speaker system, you'll be limited to audio only. First, you'll need to connect a TV to your system using one 'Video Out' cable methods so you can see the menu for the remote control changes on the system. From here there are 2 options:
  1. Connect up a working DVD player directly to your TV using the best option available. Use the audio outputs on your TV to connect to the VCR or TV input on the system box. (Using standard RCA cables.) You may need to enable the external audio outputs on the TV. (Check the setup -> audio menus etc.)
  2. You can use this as an audio amp by connecting a RCA cord from the a DVD R/L audio outputs to the VCR-Aux input on the amp box. You will need to run a separate video feed from the DVD directly to your TV. (Select the desired input on the TV to watch a DVD.)
You'll need to do a lot of switching back and forth with multiple remotes to get everything working, but the speaker setup can be made useful if it still works.
Here is a manual for the system: http://service.us.panasonic.com/OPERMANPDF/SCMT1.PDF
Mar 13, 2015 | Audio Players & Recorders
Hi. We have a Harman Kardon DVD and AVR and a Proline TV. When playing DVDs the sound from the AVR is not playing all tracks (usually the voice track is missing) - just background music and the odd door...
Your HK DVD probably has outputs for left and right audio and video (possibly color coded red, white, and yellow). These should connect to the corresponding DVD (or VCR) inputs on the rear of your AVR. When you play a DVD with your AVR set for DVD/VCR input, you should hear all of the stereo audio (there are no "missing tracks"). Next, review your speaker connections. They should be connected + terminal to the corresponding + terminal on the AVR, etc. One or more speakers may be connected backwards. If your AVR has speaker system A B provisions, be sure that speaker (system) A only has been selected.
Dec 23, 2013 | Harman Kardon AVR 225 Receiver
Symphonic dvd/vcr player
1) you must clean the DVD player, put a clean disk , if you do not have buy it in radio shack.
2) after cleaning if the process do not resolve the problem you must test the following.
3) clean the wires from corrosion +terminal, test the wires from video if is broken or break, repair or replace.
4) if this is o.k
5) test the power supply the voltage for digital is +5Vdc, for Video +15-15vdc. IF this missing repair the power supply.
6) test the VCC in microcontroller.
7) test the OPU optical pick up this contain lasser beam, must read the TOC, if not replace the OPU
8) Test the servomechanism motors a) search b) track c) sledg d) CLV) If there are missing replace or repair.
9) IF you can not resolve this electronic problem go to the repair shop TV for fix. it.
see the block diagram.tight any wires connector very WELL.AND CLEAN WITH CONTACTS CLEANER.
God bless you
Jul 15, 2012 | Philips MWD2205 DVD Player/VCR
When I try to play a DVD or VHS on my GO Video DVD/VCR Combo machine, I get audio but no video & the TV (Sanyo 37" HD) says "No Input". I've checked connections, the TV has multiple video inputs but I...
  1. I found the problem - on the back of the VCR/DVD unit there are 3 outputs: L (Wht) & R (Red) Audio + Yellow Video out. The cable from it to the TV was labeled Red/Audio,White/Video, and was connected to the R & W outs, but actually the Wht should have been connected to the Yellow Video out. There is so little space in the TV cabinet/stand that even though I turned the unit around to see the connections, I couldn't see the other (Yellow - Video) out until I pulled the cables out. It's working fine now - I'm not sure how things got connected wrong, since it was working OK before - possibly when I signed up for AT&T U-Verse & the installers moved things around. I'm very happy with that service, by the way - better than Comcast & cheaper, and didn't mean to imply the connection problem was their fault. I may have moved things around in the new cabinet & not realized I hooked up to the wrong outs...
Jan 03, 2010 | GoVideo Go Video DVD/VCR Combo
Denon AVR-1705 Missing Video Functions?
What you need to do is connect all your devices to the Denon Using the best connections (Yellow Video=OK, S-Video=good, Component green-red-blue=better and HDMI=best. if you do not have a DVD that upconverts to 1080i or p when using HDMI, I would use component cables where available from your devices to the Denon other wise use the next best connection available and if connecting digital audio make a chart of all connection so you can setup everything when your ready for programming the Denon
Feb 11, 2009 | Denon AVR-1705 Receiver
Some sound missing from DVD playback
plug out your dvd for about 2hrs and plug it in back then start all over.good luck.
Apr 01, 2007 | Zenith ZHX-313 System
Sanyo DWM-3800 System Logo
189 people viewed this question
Top Sanyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Michel Laprise Sr
Are you a Sanyo Audio Player and Recorder Expert? Answer questions, earn points and help others
