Question about Memorex MVD2042 DVD Player
Pscan - split screen
Have a split screen with pscan - what to do
  • Anonymous Sep 13, 2008
    Split screen (PSCAN)
  • Anonymous Sep 17, 2008
    Split screen, "pscan" with an exclamation point in a triangle.  Just tried the switch idea, but had to shut off power to both TV and DVD player in order for things to go back to "normal."
    New Friend:
The switch on the back of my Memorex DVD Player was set to Progressive Scan (ON) Turned off, worked!!!
Posted on Jan 04, 2010
There is a switch on the back that will fix this.
Posted on Mar 24, 2008
SOURCE:
SOURCE: It split the screen in half saying PSCAN!
Cut the PSCAN button off in the back of the dvd player,there is a switch back there that turns it on and off.
Posted on Mar 23, 2010
SOURCE: my screen is split shows an orange pscan error
ok, this will make you feel stupid. when it does that just look behind the memorex dvd player and find a pscan switch, then switch it off... it pissed my sister off so much and her boyfriend found the switch. lol
Posted on Jun 29, 2010
SOURCE: memorex dvd player pscan split screen
thank you!!! it worked!!!
Posted on Oct 02, 2008
SOURCE: pscan split screen coming
Reset it to the original settings. Go to preference setup menu, select default and reset.
This was for a Teac DV220 DVD player
Posted on May 31, 2009
vljenterp81
  • 86 Answers
SOURCE: my dvd has a split screen and says pscan. what do
there are several solutions to this but in most cases you will need the remote to solve this problem. write back and tell me if you have the remote to this player
Posted on Nov 09, 2009
Pscan message and split screen
well on your memorix dvd player you will get a orange triangle that says pscan (progressive scan) you will go to the back of you dvd/vcr and on the right hand side you will see a switch to turn on and off the pscan you will switch it off and you will be set to go
Aug 23, 2009 | Memorex MVD2022 DVD Player
How to get the pscan and split screen go off
press video mode or pscan button on remote
Jul 11, 2009 | Televison & Video
PSCAN is displayed on my screen with a split picture behind.
ariechic, did you ever fix the problem? i have this same problem and i don't know how to fix it...
Mar 21, 2009 | TruTech PLV16190 Television
Memorex dvd player pscan split screen
I had the same problem with mine. I flipped the switch on the back and it worked instantly, hope yours does too.
Feb 26, 2009 | Memorex MVD2042 DVD Player
Split screen pscan lost manuel help pls.
There is a switch in the back I turned off
Jan 25, 2009 | Memorex MVD2022 DVD Player
I work for Memorex technical support. Our customer service phone number is 1-800-919-3647.
On the back of your player you should see a switch that can slide back and forth that's marked PSCAN. Slide the switch into the opposite position from which it's in now. The should solve your problem.
If you feel this solution doesn't deserve a good rating, please let me know why so that I may better assist you. If there is anything more I can do to help, I will!
Jan 05, 2009 | Coby DVD-224 DVD Player
Split screen with pscan warning on
I had the exact same problem and I consulted the manual. All you have to do is turn the PSCAN swtich off. It is located on the back of the dvd player. Then turn the dvd player back on and your problem should be fixed.
Jun 07, 2008 | Memorex MVD2022 DVD Player
I cant get my dvd to run without the pscan split screen coming help.... follwed directions in manual it didnt work HELP memorex dvd player model#mvd2022
had the split screen with pscan triangle looked for the button on the back, no button but on the remote was a button named V.MODE pressed it and everything back to normal thanks for the help
May 16, 2008 | Memorex MVD2022 DVD Player
on the back of the dvd there is a black interruptor, it should be set as PSCAN OFF. thats all folks
Nov 02, 2007 | Memorex MVD2042 DVD Player
Memorex MVD2042 DVD Player Logo
947 people viewed this question
Top Memorex Televison & Video Experts
 Grubhead
Grubhead
Steve Allison
Steve Allison
Are you a Memorex Televison and Video Expert? Answer questions, earn points and help others
