Question about Car Audio & Video
Orion 12000 I have a orion 12 d amp hooked up in my car. All of a sudden the sound stop coming out of my speakers. I have 12 volts to the amp. the amp lights come on and no sound. If i tag 12volts to the positive speaker wire at amp the sound comes back and last for about 6 hrs. any ideas
  • Anonymous Nov 08, 2008
    I have a blitz audio 2500 watt amp. My remote fried yesterday causing my protect light to come on. Took it out and its been working fine. On my way home from work today the sub got really loud and then cut off. You can tap the amp and it thumps a power surge through my sub. (Serwin Vega 15" 1000 watt). Im stumped.
The speaker out let on back of speaker box went bad and burnt the circuits in the amp
Posted on Mar 20, 2008
When car is hooked up I get visuals, lights. etc. but no sound transmits from the stereo to speakers. I have checked all speaker connections and RCA jacks, along w/ amp and subwoofer and all are connected...
The illumination wires (orange, not yellow. Yellow is for 12 volt in) would not have an effect on sound. Either the internal amp is blown or you have a shorted speaker which is preventing the internal amp from turning on. Disconnect all speakers and hook a KNOWN GOOD one to an output. I f you get sound, the problem is in the car, if not, the problem is in the radio. If you accidentally crossed two of the speaker wires or let one touch a chassis ground, you blew the amp.
Jul 01, 2011 | Car Audio & Video
My amp keeps going into some safe mode and red light blinks and stops base to my sub. I have it hooked up to 1 15.4 Orion HCCA.
The "safe mode" on your amp usually kicks in for two reasons - the ohm load on the sub is too low for the amp (presenting a "short" to the amp), or it's going into thermal protection because the amp is too hot. From your description, it sounds like there's a short in the wire, the sub's ohm load is too low, or the sub is partially blown.
If you have another sub or speaker, connect it to the amp's output and see if the amp still goes into protection mode. If the amp goes into protection with a known-good speaker, then there may be something wrong with the amp's power supplies. If the amp works properly with another speaker or sub, then I would check the sub that's causing it to short out.
You may also want to check whether or not the amp is over heating by just touching the amp when it goes into protection. If it's just warm, that should be ok - if it's hot, then it might be working too hard. In this case, you may need to check the input voltage (12-14VDC) and the size of the power and ground cables. If your ground isn't properly connected, it can cause weird problems like over heating, shorts, erratic behavior, etc...
Mar 04, 2010 | Orion HCCA-D5000 Car Audio Amplifier
My amp suddenly stopped working. Orion-Cobalt 800.1 RCA Problems.
Hello icpdownie,
A grounded or shorted RCA cable could be the problem. Try replacing the RCA's.
Hope this helps.
Aug 12, 2009 | Car Audio & Video
Only door speakers have sound on the cd mode
the amp requires a 12 volt power constant, and a 12 volt "on" signal. you prolly have the 12 v "on" hooked up to the car stereo's antennae remote, meaning your amp gets power when the radio is on, cuase the radio is sending a signal to the amp (thinking that it is sending a signal to the antennae to raise)
you do have one of those collapsable antennas, right?
Mar 12, 2009 | Clarion VRX745VD Car DVD Player
Orion hcca 250 digital reference
if its hot its drawing to much current sound as if you have something improperly hooked up..if i could see your wiring i could help u out better steve
Feb 27, 2009 | Orion HCCA-D5000 Car Audio Amplifier
No sound
Try running the amp without the speaker wires hooked up. See if the light is still on. If it is still on, the disconnect all power to amp for 12 hours. This should reset the amp. Then try again without and then with the speakers. This should fix the problem. If the light is still on, that means a capacitor inside could have overheated and fried the output.
Feb 04, 2009 | Lanzar VIBE286 Car Audio Amplifier
Visonik 350watt Amp Doesnt Come On....
With your multimeter set to DC volts, the black meter probe on the ground terminal of the amp (not on the point where the ground wire connected to the vehicle) and the head unit on (so the amp will have remote voltage applied), touch the red probe alternately to the B+ and remote terminals of the amp. If the voltage is below ~11 volts, you need to check the wiring feeding whichever line is too low.
Let me know if you have any other questions.
Oct 06, 2008 | Visonik V117SX Car Audio Amplifier
Red protection light
If the amp is going into protect mode, it probably has shorted output transistors. To eliminate other possible problems, do the following.
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp (not on the point where the ground wire connected to the vehicle) and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage is below ~11 volts, you need to check the wiring feeding whichever line is too low.
If the voltage remains near or above 12v, disconnect all speaker wires from the speaker terminals of the amp and disconnect signal cables from the amp. If it powers up, the wiring needs to be checked. If it still shuts down, the amp almost certainly has shorted output transistors and will need to be repaired.
Sep 12, 2008 | Nitro BMW-482 Car Audio Amplifier
Wiring
1st make sure your amp is coming on. Use another speaker that you have heard play to test it.
Next test the woofer with a 9 to 15 volt battery. Touch the battery leads quickly across the + and - on one side at a time. The speaker should move and make a pop on both voice coils.
If the amp plays and speakers play, then you need to know the power rating and impedence stability of both amp and speakers. That will determine how they are wired up.
Jul 28, 2008 | Digital Audio DA8012 12" Subwoofer Car...
Amp makes subs pop
It sounds like your amp chip has gone bad, here is some thing you can try turn on your unit then start tapping on top of with your finger not hard see if the any of the pops matches your finger taps some times when the chip starts to go out it well act like that.
Nov 04, 2006 | Orion 2500D Car Audio Amplifier
Car Audio & Video Logo
266 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
