Question about Panasonic CT-32SX12 32" TV
Bad color just this morning the color has failed on our Panasonic tv. W now have a large oval shape in the center and around it are the colors of the rainbow in an octagonal shape. It's red in the center, then green and then blue. We can still see the picture, except for the color variations, and the sound is fine. Can any one advise? Is this worth fixing or should we just by a new tv?
  • joanieOregon Mar 18, 2008
    Thank you for your response. A demagnatizing coil? Is this easily installed? I can do it myself? Also, why would a tv suddenly become magnatized?
    Thanks. This has been very helpful. Just to let you know, the problem fixed itself. All of a sudden the color was right again. This before I could unplug the tv. Hmmm? Strange. --J
  • 373 Answers
If it is a glass crt then you need to have the set demagnatized with a demagnatizing coil. All tv shops have one. This is worth fixing and usually at the price of a service call.
Posted on Mar 16, 2008
  • TV Doctor
    TV Doctor Mar 18, 2008
    Sometimes unplugging for a minute and turning back on will energize the automatic demagnatizing in the set
SOURCE:
Projection HDTV Pansonic 47" Curving blue and green colors on top and bottom of screen.
You will need to replace your two convergence I.C.s.They are two large IC mounted on a large aluminum heat sink.Replace both,look for any burned resistors near them,replace those if needed,and readjust your convergence. Good Luck
Let me know if you need any further help
Mar 29, 2008 | Panasonic PT-47WX42 47" Rear Projection...
I have panasonic model pt53wx54j rear projection tv. When the tv is on accross the bottom in a oval shape starting in one corner and ending is an oval shape yellow in color. Just above that is a blue color...
If you go into the customer menu and select convergence and it is skewed you need to remove the light box and replace both of the STK-392-110 CONVERGENCE IC chips this set uses.
I HAVE START TO FINISH, STEP BY STEP INSTRUCTIONS FOR THIS REPAIR IN THIS SET--I can post them here if you think you or someone you know can do the repair.
Most shops get 300 or more for this repair--if you buy the chips on Ebay (I can tell you the seller to look for there) they and any other parts should total under 30 dollars. The fact that the set is still coming on means most likely just the two chips need to be replaced and the set adjusted with the Panasonic remote for this set.
If you have questions or want the instructions rate this solution and let me know and I will post them here---I do this here for FREE.
SD TECH
Nov 27, 2009 | Televison & Video
Color is lighter in center of screen. It started as a small bat-man cape shaped area at top of screen and has moved down the center of the screen over the past week. About 5 inches in width and light blue...
sounds like the alignment in the color guns is off. this takes a professional to repair and usually isn't too terribly costly if it's just a realignment. check your local directory for large tv repair.
Jul 11, 2009 | Televison & Video
Fuzzy picture, oval shaped, scrolling up slowly
I would start by checking the large filter capacitors in the power supply. I can't be sure since I'm not seeing the set, but it sounds like you're describing AC ripple. In a 20-year-old set, some of those electrolytics will be drying out. A few replacements may take care of the trouble for you.
Jan 01, 2009 | Panasonic PT-56WXF95 56" Rear Projection...
Sounds like the deguassing cicuit has failed . This aligns the purity of your colors .Most of the time it is a simple loose connection on the themistor or the degaussing input cord to the board . Or the thermistor is bad . The tv was not dropped ? If it was this could have loosened the shadow mask in the picture , then the only way to repair is the replace the picture tube . Good luck
Mar 04, 2008 | Panasonic CT-36D32 36" TV
No Picture
Rarely picture tube also shows the same symptom. High pitch sound is due to through deflection area LOT power supply is loaded. Compulsary horizontal output transister short. From your statement i think Lot puncture takes place. Change LOT and horizontal output transister and check tv is now working.
Aug 23, 2007 | Zenith A32B86R 32" TV
Panasonic Color Rings
It sounds like you have a warped shadow mask in your picture tube if your set uses a picture tube. A shadow mask is like a screen wire that lets the three color guns shoot electrons to their respective phosphor dot on the screen to produce the three primary colors which are mixed properly to produce the scene that is being shown. In other words you have a bad picture tube. Stargazer
Aug 12, 2007 | Panasonic CT-27SF37 27" TV
Old Panasonic TV
take your set to a tech could be having problem in your video circuit or the neck board socket need to be replace.good luck.
Mar 29, 2007 | Panasonic CT-2788YD 27" TV
Panasonic CT-32SX12 32" TV Logo
108 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
