How to run audio wire for car nav under front set of dodge 2003 ram truck
  • sunnycal77 Mar 15, 2008
    How does droping the panel get it to the seat? Under carpet.
  • sunnycal77 Mar 16, 2008
    That is what I thought but I can not tell how to remove the kick panel.
  • 19,396 Answers
More then the receiver this problem regards the vehicle.
Click here to contact a Dodge expert.
Posted on Mar 15, 2008
    Genius:
  • 3,587 Answers
Wow..that's a long run..you may need to drop the panel
  • Patrick Michaels
    Patrick Michaels Mar 16, 2008
    ahh..i did not see the word 'seat' it says set...so, you want to know how to bring a wire ..the panel is the kick panel, along side bottom of the door on drivers or passenger side..you'll need to open that up, run wire(I recommend double insulating it to ensure it's immune from moisture, and then you should be there..
  • Patrick Michaels
    hmm..there are Chilton guides for this, you know..best solution is to read from the makers approved service guide
Stereo wiring diagram 04 dodge ram 3500
2004 Dodge Ram 2500 Truck Car Radio Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Pink
Car Radio Accessory Switched 12v+ Wire: Brown/Red
Car Radio Ground Wire: Black/Dark Green
Car Radio Illumination Wire: Orange/Dark Blue
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Dark Green
Left Front Speaker Negative Wire (-): Brown/Red
Right Front Speaker Positive Wire (+): Violet
Right Front Speaker Negative Wire (-): Dark Blue/Red
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown/Yellow
Left Rear Speaker Negative Wire (-): Brown/Light Blue
Right Rear Speaker Positive Wire (+): Dark Blue/White
Right Rear Speaker Negative Wire (-): Dark Blue/Orange
Jun 11, 2013 | Cars & Trucks
I have a 2004 dodge ram 2500, the passenger window switches don't work
Not uncommon, the master window switch on the driver's door goes wonky. Mine had same problem (2003 1500 4.7L long cab) and simply replacing the master switch fixed both bad passenger switch intermittent problems. Easy swap, cheap at the dealer.
Oct 08, 2011 | 2004 Dodge Ram 2500
Wiring for radio speaker wire color misibishia?aido
1989 Dodge Ram 50 Car Audio Wire Harness Color Guide
Car Radio Battery Constant 12v+ Wire: Red
Car Radio Accessory Switched 12v+ Wire: Red/White
Car Radio Illumination Wire: N/A
Car Stereo Dimmer Wire: Orange/White
Left Front Speaker Positive Wire (+): Green
Left Front Speaker Negative Wire (-): Green/Yellow
Right Front Speaker Negative Wire (-): Violet/Yellow
Left Rear Speaker Negative Wire (-): Brown/Yellow
Right Rear Speaker Positive Wire (+): Blue/Red
Right Rear Speaker Negative Wire (-): Blue/White
May 20, 2011 | 1989 Dodge Ram 50
I need a wiring diagram for a 2008 dodge 1500 radio
Thanks for using FixYa.
2008 Dodge Ram 1500 Car Stereo Install Instructions
Car Radio Battery Constant 12v+ Wire: Gray/Red
Car Radio Accessory Switched 12v+ Wire: N/A
Left Front Speaker Positive Wire (+): Dark Green/Yellow
Left Front Speaker Negative Wire (-): Dark Green/Light Blue
Right Front Speaker Positive Wire (+): Gray/Yellow
Right Front Speaker Negative Wire (-): Gray/Light Blue
Left Rear Speaker Positive Wire (+): Gray/Light Green
Left Rear Speaker Negative Wire (-): Gray/Dark Green
Right Rear Speaker Positive Wire (+): Dark Green/Gray
Right Rear Speaker Negative Wire (-): Dark Green/Light Green
Jan 28, 2011 | 2008 Dodge Ram Pickup 1500
Wiring harness for 2004 dodge ram 2500. I need to know the wire colors for the rear speakers
Sep 12, 2010 | 2004 Dodge Ram 2500
I am installing a CD player into a 1996 Dodge Ram 2500 Truck and I need the diagram
Here you go:
1996 Dodge Ram 2500 Truck Car Audio Wiring Diagram
Car Radio Ground Wire: Chassis
Car Stereo Antenna Trigger Wire: Yellow
May 12, 2010 | 1996 Dodge Ram 2500 Club Cab
2003 Dodge Ram 2500 diesel 4x4 wiring diagram
TPIM PROBLEM , MUST HAVE COMPUTER FLASHED AT DEALERSHIP
Apr 21, 2009 | 2001 Dodge Ram 2500 Truck
Need to get wiring diagrams
1988 Dodge Ram Charger Car Audio Wire Color Codes
Car Audio Front Speakers Size: 6′ x 9′
Car Audio Front Speakers Location: Doors
Right Front Speaker Positive Wire (+): Purple
Right Front Speaker Negative Wire (-): Purple/Yellow
Car Audio Rear Speakers Size: 5 1/4′
Car Audio Rear Speakers Location: Side Panels
pls rate
Jun 23, 2008 | 1988 Dodge D-Series Pickups
Running wirer from driver seat to stereo dodger ram truck 2003
peel away the door seal to release the carpet abit and then with a bit of time and effort work the wire through?depends on how easy the carpet comes awya to how long it will take,once the wire is through just place it all back in reverse order
i hope this helps?
Mar 15, 2008 | Car Audio & Video
24 people viewed this question
 Grubhead
Grubhead
