Question about Denon AVR-2807 Receiver
What to use for Audio-out on Denon AVR-2807?
I have the AVR-2807. I have connected a turntable to it and this works fine. I want to convert some of my LP phonograph music to MP3 files, so I have purchased the xitel INport deluxe to connect my Denon receiver to my computer's USB port.
Problem is I don't know where to plug the red & white RCA-type connectors to the Denon! The xitel instructions say to connect to audio outputs that are usually labeled Line Out, Aux Out, Tape Rec or Send.
I am puzzled. Where do I connect the cable to have the turntable audio routed to my xitel device??
  • Karmor
    Karmor Mar 16, 2008
    Graeme - thanks for the suggestion. I have already found the connectors for tape deck in and out. One thing I hadn't considered was the Denon programming steps required to feed signal to these connectors!
    On page 42 of the Denon manual is a small section describing how to press the ZONE2/REC SELECT button until RECOUT LED lights up for a few moments on the display, then select the function to output before the RECOUT light goes out.
    Now that I have masteres this programming step I cn record using the xitel INport just fine.
  • Anonymous Mar 16, 2014
    connect turntable to Denon AVR 1909
  • 1,512 Answers
Hi Karmor
Use the Tape Out(rec) connections on the Denon. If that model has a rec out selector, then be sure to select phono as well. All sweet and ready to rip them files!!
regards
Graeme
Posted on Mar 16, 2008
SOURCE:
Denon AVR - 2807 flickers in TV mode with picture & sound.
Change the hdmi cable and try. If not then you have an hdmi fault module.
Dec 15, 2013 | Denon AVR-2807 Receiver
Downloaded music from itunes into computer and then to mp3 player but music when into mp3 player browser and nothing happens when I open the file
The ITunes maybe be in MP4 file format.
MP3 players can only play music files in mp3 file format.
You can download mp3 music files from the Internet to your computer and then copy them to your MP3 player using the USB cable.
For your CD collection, you need to convert your CDs to mp3 music files onto your computer or download them from the Internet and then copy them to your MP3 player after you have connected the USB cable to the MP3 player and the computer.
You can do this using Windows Media player and Rip the CDs - Media Player will create a MP3 music file for each music track.
Click on this link for instruction on converting music files to mp3 file format :- http://www.fixya.com/support/r5798418-creating_transferring_mp3_music_files
May 04, 2013 | Jensen Audio Players & Recorders
No sound from Russound ss-4 after connecting to BACK surround speaker connections on the 2807.
Check the speaker setup configuration in the setup menu. Many times the surround back speaker terminals can be assigned to something else like zone 2. They may just be turned off.
Dec 27, 2012 | Denon AVR-2807 Receiver
Why can't I get my regular speakers to work on my turntables?
Yes, you need to connect a turntable to a amplification source. Phonographs send a very low level signal. If you decide to get a receiver/amplifier be SURE it has a PHONOGRAPH input - Many new models do not. If you simply plug it into a receiver without one (and the ground screw) your sound will be unpleasent.
Jun 04, 2009 | Sony PS-LX300USB Turntable
Surround sound throughout the house is not working
please use a different wire to connect else chage the connectors
Dec 16, 2008 | Denon AVR-2807 Receiver
Condition on HDMI input when Denon AVR-2807 switched off
hello if you know this spitter conduct voltage and its feed from main device and when you connect another it send it ground you have to do this chech with a voltmeter in the hdmi splitter output is not dc present if so change it cause is not blocking dc current saludos
Dec 04, 2008 | Denon AVR-2807 Receiver
Playback Problem
They should be recording in mp3.  Then converted into ITunes using AAC.  Itunes will play MP3 format from the turntable.  The best thing to do is to record in that format, then test the files before converting them.  That way you can find out if the problem is with Itunes conversion or the turntable.
Oct 06, 2008 | Numark ttUSB Turntable
Denon AVR-2807 Receiver Logo
400 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
