Question about Video Game Consoles & Games
Playstation 3 problems registering new account
Get on line ok with playstation 3 but when i try registring new account i get about half way through and it comes up cant connect error code (80710D23)some other codes come up at different times..all other links to net seems ok
many thanks bob
  • revs916 Mar 22, 2008
    yes using update 217 and still no good.thanks ..
  • Anonymous Mar 21, 2009
    error Has occurred 80710D23 on my ps3 after updatting call of duty
Having exactly same problem are you using update 2.17?
Posted on Mar 17, 2008
I need to register my kindle fire
You can do that online or through the fire itself.
I copied directions from online. Mine has been registered so long I forget from one to the next. I know it asks some questions but nothing big. I think it may as to verify the device ID. You just click yes or OK.
  1. From Home, press the Menu button, and then select Settings. Select Registration.
  2. Specify the Amazon account you want to use for your Kindle:
    • If you already have an Amazon account: Select this option. Enter your Amazon account information. Select Register. Your name will appear as the Registered User when registration is complete.
    • If you do not have an Amazon account: Select this option and follow the on-screen instructions to set up a new Amazon account.
Nov 02, 2016 | Amazon Kindle
3 of my 5 phones say "No Line"?
This sounds like a registration problem, the errant
handset(s) and the base have lost identification
with each other.
NOTE: the CS6429 works a maximum of 5
handsets, so you have a "fully populated system".
You will have to clear each handset ( I ) then clear
the base of all registrations ( II ) before re-registering
each handset ( III ).
( I ). First de-register each handset ---
0. Start by taking off the battery compartment cover.
1. press [menu]
2. scroll up/down to "Settings"
3. enter * 7 8 9 0 #
4. scroll down to "next page", press [select]
5. scroll down to "Register Clear?", press [select]
6. display asks "Confirm?" or "Register Clear??",
press [select]
7. display reads "Ok" and chirps, press [ off ]
8. UNPLUG THE HANDSET BATTERY
(this is why the cover was off)
9. Wait ~30 seconds, re-connect the battery &
replace the cover
10. display reads "Not Registered"
( II.) To clear the base of all handset registrations
1. press [Find Handset] on the base and hold
past ~4 sec when the "In Use" lamp lights, at
about 10 secs the "In Use" lamp will begin to
blink. 2. release the [Find Handset] button momentarily,
then briefly press it again. After a moment,
all handsets that were registered to the base
(if any) will display "Not Registered" and be
ready for fresh registration ===============================
( III.) To register each handset to the base:
1. press [Find Handset] on the base and hold for
~4 sec until the "In Use" lamp lights.
2. press # on the handset and set the handset into
the handset cradle on the base
3. within 30 seconds or so, the handset will either
chirp and display "Handset Registered", then
"Handset #x" or it will say "Registration Failed".
NOTE: the battery must be well charged prior to the
registration process, a weak battery may cause a
"Registration Failed". Charge the battery for a
few hours and try the registration ( III ) again.
Good luck !!
Apr 16, 2016 | Vtech Accessory Handset with Caller ID for...
Hand set says connecting even before it is reset with new base.
This sounds like a registration problem, each 'old'
handset must be de-registered from its original
base and then registered to the 'new' base.
NOTE: the CS6229 handles a maximum of 5
handsets. If you have a handset displaying
"Handset #5" then you have a 'fully populated system'
even if you actually have only one or two handsets.
You will need to clear each handset ( I ) then clear
each handset ( III ) up to the maximum of five.
( I ). First, to de-register a handset ---
1. press [menu]
press [select]
replace the cover
( if needed, else skip ahead to ( III ). )
Good luck !!
Jul 23, 2015 | Vtech Lands Phones
I have a vetch mod# CS6114 I checked the base unit and it gets power to charge phone but I can't get a dial tone. I even hooked up to another line and still won't work.
handset must be de-registered from wherever
it thinks it is and then registered to your base.
( I ). First, to de-register a cs6114 handset ---
1. press [menu]
4. scroll from "Test Base" to "Test Handset", press [select]
press [select]
replace the cover
( III.) To register the cs6114 handset to the base:
NOTE 2: Some cs6114 bases do not have the "In Use"
lamp indicator. To register the handset simply park it
displaying "Not Registered" in the base cradle and wait
for the registration to occur. Pressing # as above may
be required, maybe not.
Good luck !!
Feb 12, 2015 | Vtech DECT 6.0 Cordless Phone with Digital...
I would like to register my new Garmin navigation 1450LMT show me how
From Garmin site; to register your Garmin device, please visit the Garmin registration page online. To begin, select the type of product you wish to register then follow these easy steps based upon the product selected:
Automotive devices:
Sign in to your existing myGarmin account or select the option to create a new account (if one has not already been created)1
If prompted, select Continue on the page titled "Getting Started"
Connect your device to your computer
Follow the steps to install the Garmin Communicator Plugin2
Confirm the device information is correct and select Continue
If you created a new myGarmin account, enter the required information and select Next (this step is skipped if using an existing account)
Your device is now registered in your myGarmin account. Information on your device and possible updates will be provided on the Registration Complete page.
Outdoor, Fitness, Sport, Marine and other devices:
Login to your existing myGarmin account or select the option to create a new account (if one has not already been created)1
Enter your device serial number3
Select Submit
Confirm the product name and serial number are correct and select Next
Your device is now registered in your myGarmin account. Select the option to Go to myDashboard to check for device firmware updates.
1 Multiple devices can be registered in a single myGarmin account.
2 The Garmin Communicator Plugin allows your device to communicate with your computer. If you are registering multiple devices, you will skip this step once it is installed. For browser specific instruction on installing the Communicator Plugin, click here.
3 The marine device registration path also provides an option to register using the device unit ID as well as an option to register using a prepared card.
Note: For instructions on registering your nuvifone or garminfone, click here.
Hope this helps.
Jun 06, 2011 | GPS
Trying to sign in to PS network comes up with error code 8002A203. saying we have been signed out of network? Can anyone shed some light on the problem please.
System maintenance is currently underway , during the down time, which finishes at 3am GMT on Thursday, March 10th, users will not be able to log in to the PlayStation Account Management, register a new PSN account or access the PlayStation Store via the PlayStation 3 or PlayStation Portable.
Mar 09, 2011 | Sony Playstation 3 (PS3) Console
Getting the following error message when trying to play on line "An error has occurred. You have been signed out of PlaystationNetwork. (8002A203). how do i fix?
Currently System Maintenance; However, during the down time, which finishes at 3am GMT on Thursday, March 10th, users will not be able to log in to the PlayStation Account Management, register a new PSN account or access the PlayStation Store via the PlayStation 3 or PlayStation Portable.
Hi There.. Lost instructions..wanted to know how to change the handset setting/line settings.. want to change handset to different base ?? Hopefully you can assist? Thanks
First, you need to de-register the handset from the current base. Then register it to the new base. On the handset, press Menu then navigate (up/down arrows) to Handset Settings and press OK. Next navigate to Registration and press OK.
For deregistration: navigate to Deregister then press 3 3 5 . Then select which handset to deregister (1-6) (the handset number will flash when it is selected) and press OK. Select Yes and then OK. When the deregistration is complete, press OFF.
For registrations, navigate to HS Registration then press OK. Then move to the base and press and hold the Locator button until the registration tone starts. If all the handset ring, press the locator button to stop the response and start over. Within a minute and a half of the registration tone starting, press OK on the handset and wait until a beep sounds and the symbol on the screen stops flashing.
The user's manual is available here: http://www2.panasonic.com/consumer-electronics/support/Phones-Fax/Telephones/Expandable-Systems/Operating-Instructions/model.KX-TG1033S.O#ts . It's in the tab marked Operating Instructions. This will provide additional setting information.
I hope this helps.
Nov 29, 2010 | Panasonic KX-TG1033S Cordless Phone
Jose
pspiso.com. You need to register there to view the forums and links but registration is only for FREE...just don't pick the Premium account...
Aug 01, 2008 | Sony PlayStation Portable (PSP) Console
Tru9466 base and tru9465-2 handset
Same manual as lethean provided on a similar post but Page 24 if the previously used Base is Unavailable and your phone shows "Deregistration" in the Menu.
Base Unavailable (Handset Only)
To clear the base registration data in the handset, please follow these steps:
Press and hold [] and [#] for more than 5 seconds. Select the BASE UNAVAILABLE submenu.
BASE UNAVAILABLE appears. Move the cursor to select YES, and then press the OK soft key.
ARE YOU SURE? appears. Move the cursor to select YES. Press the OK soft key.
Mar 10, 2008 | Uniden TCX905 Cordless Accessory Handset...
Video Game Consoles & Games Logo
140 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
