We have a RCA Model 32V550T TV. It just all of sudden decided not to come on. You can press the button on top, nothing, the same with to remote. It did this one other time, but it came on. I have tried everything. I wounder if it is a fuse. How do you obtain this area, ect. Thanks
  • pnsoemb Mar 16, 2008
    Thanks, I have unplugged the TV and a few other things.
    I tried to find out from RCA Corp., about getting a copy of the Schematics on the innereds, to see where the fuse might be.
    The 32" is 4 yrs. old.
    Thanks
  • Matthew Haynie
    Matthew Haynie May 11, 2010
    How old is the TV? Is it a flat panel or a CRT?
    Scholar:
  • 146 Answers
Try to unplug the tv for 30 min. then try to see if it works. If not, there is a fuse in the tv. take off the back cover and replace it. If it blows again, take it to a repair shop. If the fuse is good, you will still need to take it to a repair shop.
Posted on Mar 15, 2008
  • Anonymous Mar 19, 2008
    To find the fuse just follow the power cord. It will be next to the power cord where it plugs into the circuit board.
SOURCE:
RCA 32v550t. The parental control has been accidently activated and i can't figure out the code. The front panel has also been locked please help me.
Hello Most RCA and GE TV sets use a four digit code to control the v-chip. The code reset procedure is different depending on the model. Try each method until you find one that works
  1. Hold down MENU on the remote and VOLUME DOWN on the TV it's self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
  2. Hold down the 0 on the remote and the VOLUME DOWN buttons on the TV its self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
  3. Hold down the MENU button on the front of the TV and the TV button on the remote at the same time for at least 4 seconds
  4. Hold down GO BACK on the remote and MENU on the front of the TV at the same time for at least 4 seconds.
Depending on the model, one of the methods should unlock the V-chip. Now, if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET.
Nov 20, 2010 | RCA 32V550T 32" TV
Is not turn it on again when i press manually, not from remote control, on control parent
Try unplugging and replugging,then reprograming the remote. Also try removing the batteries from the remote, holding a button down to drain the power, reinstalling the batteries, and reprogramming the remote.
Aug 11, 2009 | RCA 32V550T 32" TV
RCA 32V550T Nothing happens when you press Power. NOTHING.
This set needs a flyback transformer p/n 262342, and a horizontal output IC, location number on the board is q14401 and crosses to NTE2353. When you're in there too touch up any bad solder joints you can find. Fixed several of these with the same problem.
May 25, 2009 | RCA 32V550T 32" TV
I have a remote RCR3273 and can't get it to control my Panasonic
I press the tv button on rca remote and it wont stay on, tryed holding tv button and entering code but power button flashes twice and turns off. Entered last number and nothing happed, cant find any other help.
Apr 27, 2009 | RCA Universal Remote 3 Device Remote...
Need tv code for RCA 32V550T
I apologize but because Phillips doesn't give a code for your specific model the following are possible codes you need to try :
0704, 0002, 0406, 0007, 0011, 0611, 0811, 0312, 0514, 0720, 0102, 0502, 0601, 0817, 0917, 0835, 0901, 0103, 0803, 0211, 0912, 0114, 0519, 0320, 0420
Jan 15, 2009 | RCA 32V550T 32" TV
RCA 32v550t problem
PRESS AND HOLD MENU AND POWER ON THE SET
Jan 15, 2008 | RCA 32V550T 32" TV
Control Panel
Yes you can replace the chip, BUT, first try to clean the button contacts. I have to do that to my remotes, phones, and RCA TV (yes I have one too) etc.. around my house. Just needs a good cleaning. Don't forget to unplug the TV.
Jun 30, 2007 | RCA 32V550T 32" TV
Vertical adjustment
hold menu press power press volume up a p and d will appear use the volume up to change the value of v to 76 then you in but you require which setting to adjust i don't have them with me now but try this and see if you can get in first,.to exit press power button /
Nov 30, 2006 | RCA 32V550T 32" TV
Televison & Video Logo
Top Televison & Video Experts
Ekse
