Question about Gateway M305CRV Notebook
Operating system not found
Operating system is not found: computer turns on, lifebook fujitsu logo appears, then they say operating system not found
I switch on my laptop, and the logo comes up for a few seconds. After a few seconds the screen goes black and at the top it says, "Operating system not found"
    Sniper:
  • 64 Answers
On my Windows 7 laptop, I have got "Operating System not found" error. to fix problem, Windows Boot Genius helped me finally!
Posted on Dec 04, 2013
  • 55 Answers
The laptop is unable to read operating sistem from disk - you have to try to insert recovery disk after changing in the bios (you can read on laptop manual how come in bios for changing to first boot is hard disk to first boot is cdrom or dvd or cd ) after that you can try to       recovery the operating sistem - it may be not so easy delfo
Posted on Mar 16, 2008
3 Suggested Answers
SOURCE:
  • 151 Answers
SOURCE: operating system not found
this is the problem that is arised when u try to install  2 OS at one time. for example if u install XP and winn2000 together this problem is arised.
The thing is that u have install new operating system with the help of cd/
Posted on Oct 14, 2007
  • 2427 Answers
Yep, your operating system has crashed, not your hard drive, but the windows on the hard drive..
simply boot from your windows cd / dvd and choose upgrade as the instillation type or leave current file systems intact so as you install windows over again, you dont loose your previous data..
Posted on Jan 08, 2008
How do i factory reset my fugistu lifebook T4220 with out a cd because my computer does not have the thing to put cd's
Step 1Reboot or turn on your Fujitsu Lifebook and press "F12" when the Fujitsu logo appears.
Step 2 Highlight "Recovery and Utility" using your arrow keys and press "Enter." If this options does not appear, you have to recover directly from the recovery disc. Step 3
Select a new keyboard layout on the first screen that appears, if your preferred keyboard is not already selected. Click "Next." Select "Use recovery tools...," and "Next" on the "Operating System" dialog screen. Enter your password, if your system is configured with one. Step 4
Click "Recovery and Utility" on the "System Recovery Options" screen. Step 5
Click the "Recovery" tab and click "Restoring the Factory Image (only C:\drive)." Follow the on-screen instructions to restore your Fujitsu Lifebook. Some models may require a supplied recovery disc be inserted at this point.
Mar 10, 2015 | Computers & Internet
Factory restore
1. Turn on or reboot your system. When the Fujitsu logo appears, press the [F12] key.
2. From the Boot Menu, that appears, check whether the <Recovery and Utility> option is present.
If it is not present, it means that the utility must be used from the disc.
Proceed to "Running Recovery and Utility from the Bootable Disc" , if <Recovery and Utility> is unavailable.
http://support.fujitsupc.com/CS/Portal/s...
Dec 22, 2013 | Fujitsu LifeBook AH530 NoteBook
What F? Key do I press to restore my Fujitsu Siemens amilo L7320GW
Fujitsu simens back to factory settings
Downloads & Disks Regarding The Reset Factory Settings Fujitsu Amilo Li 2727
http://www.user-guides.co.uk/download/reset/resetfactory/reset-factory-settings-fujitsu-amilo-li-2727.html
Fujitsu Laptop to Factory Settings
Restoring the factory settings on your Fujitsu laptop is a great way to get rid of files associated with programs that have been removed from your computer that are taking up space and get rid of pesky viruses that you can't remove from your machine by any other means.
Restoring the factory settings on your laptop can also help resolve problems with an unstable laptop.
You should also restore the factory settings on your laptop if you plan on selling it or giving it to a family member or friend.
Restart or turn on your Fujitsu laptop. Press "F12" repeatedly when the Fujitsu logo appears on the screen to be redirected to the Boot Menu.
Highlight "Recovery and Utility" using the arrow keys on the keyboard, then press "Enter."
A progress bar will appear at the bottom of the screen while the computer is loading the recovery files.
When the files have been loaded, the System Recovery Options window will be displayed.
Select a keyboard layout, then click "Next." The Operating System dialog box appears.
Choose "Use recovery tools...," then click "Next." If prompted, type your administrator password, then press "OK." The System Recovery Options window will appear again.
Select the "Recovery" tab, then click "Restoring the Factory Image (only C:\drive)."
The restoration process will begin, and the laptop will be restored to its original factory settings.
When the process is complete, the computer will automatically restart and boot up to the Windows Setup screen.
Begin personalizing your copy of Windows.
Using Boot Disc
Highlight "CD/DVD" using the arrow keys, then press "Enter."
Place the boot disc that came with your Fujitsu laptop in the optical drive, then click "OK."
A progress bar will appear at the bottom of the screen while the computer is loading the recovery files. When the files have been loaded, the System Recovery Options window will be displayed.
Click "Next" when the Operating System dialog box appears.
If prompted, type your administrator password, then select "OK."
Click "Recovery and Utility" when the System Recovery Options window opens, then select the "Recovery" tab.
Click "Restoring the Factory Image (only C: drive)."
When the process is complete, the computer will automatically restart and boot up to the Windows Setup screen. Begin personalizing your copy of Windows.
Saving and recovering your factory and system images.
http://solutions.us.fujitsu.com/www/content/pdf/SupportGuides/HDD Restore Generic-Multi-lang B6FJ-3031-03EN-00.pdf
Aug 05, 2013 | Everex StepNote XT5000T Notebook
How do I get into bios
As soon as the Fujitsu logo appears on the screen, press the F2 key. If this doesn't work, please post the specific family and model of your Fujitsu Siemens LifeBook PC.
Thanks,
Roger
Jun 03, 2012 | Fujitsu Siemens LifeBook Computers &...
Hi, i have a fujitsu lifebook n 6740 and it running very slow...i was wondering how i can restore it to the factory settings when i bought it
Back up all your stuff first! Then when you're ready, make sure System Restore is first disabled/turned off.
Then when you boot your computer, (before the logo shows on the screen)
Press and hold down Alt+ F11 at the same time, for about 7-8 seconds. This should give you access to factory resetting options.
Hope this works!
Mar 16, 2011 | Fujitsu LifeBook N6470 Notebook
My lifebook s7010 won't startup. After put the on button the screen still remains black. The fujitsu logo will not appear on the screen.
Unplug the AC adapter from power cord, then remove the battery.Wait 30 min and put the battery back.Plug the AC in power cord and try again.If not start you need check AC adapter with voltmeter.If the AC working your computer need service.
Nov 10, 2009 | Fujitsu Siemens LifeBook S7010 Notebook
open the laptop you find the reservoir from the Hard Disk / hdd pull outward and return again to you as the hard drive is logged
Dec 15, 2008 | Fujitsu Siemens LifeBook S-6000 Notebook
Problem with my Bluetooth
I found your driver on the internet. Is your notebook a Fujitsu Siemens LifeBook E8210 PC Notebook like the displayed Icon beside your problem. I will give you the site and some instructions for you to find your driver. Open this site http://support.ts.fujitsu.com/com/support/index.html ---on the Welcome to our Support Pages there is another scroll down inside the webpage, scroll it until it reaches the buttom. You will see there the SELECT PRODUCT drop down box. Choose your product and wait for the 2nd drop down box to appear. Continue choosing your product until the 4th, the last box will appear. The sequence of the boxes are like ex. 1)Notebooks, 2)LIFEBOOK, 3)LIFEBOOKS E, 4) and the 4th box choose between the two E8210 whether your notebook is a ATI-Graphics or Intel-Graphics, after that click on Drivers and choose your operating system. Then you can download all the drivers you want. Hope this helps.
Mar 23, 2008 | Fujitsu Siemens LifeBook® E8210 PC...
Operating system not found? I have got Windows Boot Genius to fix problem safely!
Jan 08, 2008 | Sony VAIO PCG-K25 Notebook
Oct 14, 2007 | Fujitsu Siemens LifeBook S-6000 Notebook
Gateway M305CRV Notebook Logo
976 people viewed this question
Top Gateway Computers & Internet Experts
Ekse
Prashant M
Prashant M
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
