Question about Philips Magnavox 27MS343S 27" TV
Magnavox 27 I have a magnavox 27 Tv in the domo mode how do you get it out of the demo mode thank you Problems
  • 4 more comments
  • Anonymous Mar 19, 2008
    I have an old 27" that just put itself in demo mode one morning and I haven't got a clue on how to get it back right.
  • santeen Aug 09, 2008
  • donnamil_don Aug 28, 2008
    I have a magnavox 25TRC1 and am trying to locate the headphone port. My 78 mom is using the tv and is very hard-of-hearing. Does this model have a jack port for telephone headphones?
  • Anonymous Dec 04, 2008
    same as above
  • eghernandezz Jan 23, 2009
    I have a 25TRC1 0101 Magnavox and I need the codes to set a universal remote to it, can anyone help.
  • karmathayer Mar 14, 2009
    the demo on my magnavox keeps looping.
THANKS FOR THE INFORMATION ThaMp3DOCTOR. PRESSING THE VOLUME+and CHANNEL+ SIMULTANEOUSLY FOR 5 SECONDS WORKED!   THANKS
Posted on Jun 10, 2008
  • 8,596 Answers
To exit from factory mode, press the 'VOLUME(-)' and 'CHANNEL(-)' buttons on the TV set simultaneous for 5 seconds.
Posted on Mar 20, 2008
On some model of Magnavox you press the power and channel (+) button simultaneous.
Posted on Mar 28, 2008
I found this on another site and it helped my friend with a 25trc1 0101 magnavox tv
Press Vol + and vol - at the same time.
QUESTION NO. P310-5: Magnavox TV model# HT1305C121, chassis# 13G602-00AA.
TV shows demonstration mode and will not turn on and off channels. Can
only view the advertisement. Need code for resetting the system.
Press volume up and volume down at the same time.
Posted on Apr 07, 2008
  • carlos rivera Jun 05, 2014
    you could just go to the menu select options select home or store display
SOURCE:
My PHILIPS MAGNAVOX tv is showing promo screening and it wont stop
It may be in the Demo mode, usually a combination of front buttons or the remote may have a button will clear it.
Try combinations of channel and vol down or one down and one up, failing that call philips customer service.
Dec 08, 2012 | Philips Magnavox 27MS343S 27" TV
Tip
How to Disable Philips Magnavox Demo mode
  • Many people are annoyed about demo mode coming out of nowhere and causing problems with many Magnavox televisions there is a simple process which will allow you to disable the demo mode.
  1. Television must be turned off But remain plugged in
  2. First You must place both your fingers on the VOL + and VOL - buttons on the television.
  3. Then Turn on the television while still holding the volume buttons in for about 6 seconds..
  • The demo mode will now be disabled, Some televisions may turn off after demo mode is disabled just use remote to turn television back on or use programme up and down button on television to turn it on.
  • This will work even if you don't have the original remote as it requires no remote at all its a simple process and it will work with nearly all models of Magnavox televisions.
on Aug 01, 2010 | Philips Magnavox 27MS343S 27" TV
I have an m# ts3270 b101 stuck in the demo mode. would luv answer to problem, i am draining my family of their patience.
Man o man, just moved my same model Magnavox and have the same problem. Staying in demo mode...
Dec 18, 2010 | Philips Magnavox 27MS343S 27" TV
Was trying to program TV and did something now I can not get
It may be on demo mode. It's been a while since I worked on this Magnavox, but I think it is on the on screen menu. If so, switch demo mode off
Jun 06, 2009 | Philips Magnavox 27MS343S 27" TV
27'' TV will not turn off demo mode
My ancient TV/VCR Quasar combo had the same problem...and I don't have the original remote control. But holding down the "play" button for five seconds did the trick. Perhaps your TV is similar. I also read that holding down the "menu" button works as well. Hope this helps.
Apr 01, 2009 | Philips Magnavox 27MS343S 27" TV
TV demo mode
Press and hold the VOLUME UP and VOLUME DOWN keys simultaneously until the TV shuts off. Then turn it back on and you're ready to roll.
Jul 24, 2008 | Philips Magnavox 27MS343S 27" TV
Magnavox 27" in the demo mode.
Mar 15, 2008 | Philips Magnavox 27MS343S 27" TV
Magnavox television stuck in demo mode
My wife somehow put our Magnavox TV into demo mode too...
Plug in the set. With the set ON. Press the volume up (+) AND volume down (-) at the same time.
This worked to get it out of demo mode!
Jan 03, 2008 | Televison & Video
In demo mode
Try two buttons at same time = hold four seconds
Try menu & power Vol up & chan up on front of TV
Let me know..........................T.
Nov 07, 2007 | Philips Magnavox 27MS343S 27" TV
Message on screen
In demo mode? Hold both vol up & chan up at the same time for four seconds-that will release demo mode.
Oct 04, 2007 | Philips Magnavox 27MS343S 27" TV
Philips Magnavox 27MS343S 27" TV Logo
1,528 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
