Question about Intel Motherboard
Intel motherboard crash
It starts up and when i dont have ramm in it even beeps but i get no display on my monitor helps !!! plz i tried the jumper trick already but nothin wat to do
  • 152 Answers
Near by cpu and ram slot you can see serial ragistance that value is 10ohms check all serial ragister bank any one bad
check also ide connector and ram slot between 8leg ic 7338
if it burn so you can see it. replace it
Posted on Mar 27, 2008
    Novelist:
    Champion:
  • 236 Answers
You definitley not find display without the ram. that's why it beeps without it, sign of problem no RAM. It should be your video display. can you cck is you have built-in display? if not, then check the display card if properly insert. if its ok inserted, then replace your video card or find a substitute to confirm defect.
one advise, if you keep on testing our board on and off? remove first the power cable of your hard disk drive to prevent damage to the disk continues on and off. when you get the POST display then that's the time you put back the hardisk power.
good luck..
redrivera
Posted on Mar 26, 2008
I have an Intel D845EPI/D845GVSR Motherboard with 512MB PC266 Hynix DDR1 RAM. When i switch on my PC, the system starts but, fails to display even the first screen that it is supposed to display...
Couple of items to try. First disconnect everything except the power and the CPU. Does it give you a beep code?
If not your either have a bad power supply, motherboard, or cpu. (Only if everything else is disconnected.)
Second, If you did get the beep code then put the memory in and see if the system starts to boot. (Try without the screen connected first. If it acts like is going to start turn it off, plug in the mouse, keyboard, and monitor and try again.) ** I have seen where an add on video card would keep the computer from starting so try with the on board video first.**
Third, start adding one extra piece at a time starting with the hard drive.
Let me know if this helps or not.
Apr 22, 2011 | Intel D845EPI (INTELKD845EPILPAK10)...
I have an Intel 845GVSR motherboard with 2.6GHZ processor, yesterday after i cleaned my PC, I could not able to see any display in Monitor (also in keyboard). I dont even hear the boot beep. I cleaned my...
This is a common problem for everyone. You did the right thing by cleaning the RAM. Check the monitor and cable, test with another monitor if possible. Check with another video card as well. This will solve the problem.
Think this is helpful !
Aug 12, 2010 | Intel D845GVSR Motherboard
Display
Have you tried other ram.Also try a graphics card.
May 06, 2009 | Intel D845GVFN Motherboard
Intel DG31PR Booting Problem.
Try resetting the bios by removing the power cord from the back of the machine and removing the battery for an hour periodically hitting the on/off button to dispel and residual power, then try again.
post back please.
Good luck and thanks for using FixYa!!
Apr 23, 2009 | Intel DG31PR Motherboard
Hardware Monitor not working- Intel D945GNT
Not sure what chip you are using, but your problem is one which I have had and solved by the most extreme heat dissipation methods possible...I even went to the extremity of packaging dry ice in Plastic and using an external fan to literally produce arctic temperatures inside the case.
It did attenuate or reduce the heating problem and the Intel hardware monitors took note of that, but I also notice some degradation in the extent of the graphic presentation of the on screen diagnostic display of temperature, fan speeds, etc.
So, with your new problem, since you apparently responded to the three long beeps by adding a keyboard or other peripheral, and solved it, a full statement of that problem with all specs would be appropriate, unless you can no longer read the display.
Mar 27, 2009 | Intel D945GNT Motherboard
Computer Monitor Switched OFF By BIOS SETTINGS
You will need to reset your BIOS setting to its default.
Every motherboard is equip with a jumper called clrtc (Clear RTC), look in your motherboard manual to find out how to use it to reset your BIOS. Or if you know the type of your motherboard, please share it.
Dec 14, 2008 | Intel Motherboard
try to check if your memory (RAM) is compatible with your board. run dxdiag to see your computer specification
Mar 15, 2008 | Intel Motherboard
Intel 845 gvsr no display
Intel d845 gvsr no display ,but the ram is ok when i incerted the ram there is no beep and there is no sound. may be bios corupted and how to solve the problem
Mar 09, 2008 | Intel Motherboard
I changed RAM settings in BIOS, now I can't boot
try jumpers ok move to 2 and 3 for few sec then back on 1 and 2 pins on mobo ok thx nick take ram out do one at time defult to auto in bios thx nick
Feb 06, 2008 | ASUS P4S533-MX Motherboard
My PC Won't Start
Short beeps are usually a ram error. Try reseatting the ram stick(s) and if more than one then try one at a time and in different slot combinations.
Failing that try resetting the bios via the cmos jumper on the motherboard.
Do all of above with power off at plug off course :)
Jan 04, 2008 | Intel Desktop Board D845WN Motherboard
Intel Motherboard Logo
160 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
