I have a 2003 Kia Sedona EX that we bought used. It does not have info in the owners manual regarding the overhead dvd player. How do you get sound along with the images?
I have a 2002 and it has headphones (wireless) that you can hear the sound on. I am trying to figure out if the sound will pipe through the car.I have a 2002 and it has headphones (wireless) that you can hear the sound on. I am trying to figure out if the sound will pipe through the car.
Sarah, The Engine Coolant Temperature Sensor on your Kia is located below rad hose driver side by exhaust manifold. May be a good time to flush coolant system when changing sensor.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info." How to Replace Lower Engine Coolant Sensor
www.kia.ca/.../ownersmanual/2006_sedona_Owners_Manual_E...
Kia Motorsrecommended special tools, genuine Kia replacement parts and .... Room light main control switch.....3-123 ...... work properly, the power sliding door and ..... fuel only. • Check to make sure the fuel filler cap is securely closed after refu- .... roof, you have to reset your sunroof sys- ...... bulb check when you turned the ignition.
Most vehicles have the fuses listed in the owners manual in the glove box or buy you a service manual from a parts supplier like Advance, Oreily's etc. .
Most likely, there are metal peaces on the break pad, for when the pads get wore down to a certain point they rub the rotor to let you know its time for new breaks.
That did the trick. It was 88.1, thanks!
