2002 Chrysler Sebring Logo
Posted on Apr 02, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Speed fun control airconditioned doesn´t work property.
The speed fun control doesn´t work in position 1 and 2. If I select 3 or 4 works ok. What is the solution? Sorry for my english.
Paco from Spain.
Anonymous
Level 3:
  • Master 396 Answers
  • Posted on Apr 02, 2010
Anonymous
Master
Level 3:
Answers
396
Questions
0
Helped
157389
Points
1224
Two possible areas I would check using an ohm meter. First is the blower resistor which is usually located by the blower motor and looks like a cement rectangle or a ceramic tube with wires attached to it. The resistor should have very low resistance but should not read open from the common lead to the other terminals. If it tests good test the continuity of the fan switch. Some cars have a fuse for the high and low blower speeds so you can check your fuse diagram and look for two blower or fan fuses. Good Luck.
2answers
I have 2007 Suzuki XL7. I replaced radiator and fan assembly. Fans do not work. Is there a relay? If so, where is it?
Most fan and Ac relays are located in the under hood fuse and relay box. Adequately marked in owners manual or on plastic cover
If I have voltage going to the blower motor from the resister on a 2008 trailblazer with auto climate, why would the blower motor not work
This vehicle doesn't have a blower motor resistor ! It has a blower motor control module , if you have automatic climate control !
If manual climate control , then there is a blower motor resistor assembly !
Blower Motor Control Processor The blower motor control processor controls the speed of the blower motor by increasing or decreasing the voltage drop on the ground side of the blower motor. The HVAC control module provides a low side pulse width modulated signal to the blower motor control processor over the blower motor speed control circuit. As the requested blower speed increases, the HVAC control module increases the amount of time that the speed signal is modulated to ground. As the requested blower speed decreases, the HVAC control module decreases the amount of time that the signal is modulated to ground.
Air Speed - Front Control
The blower motor forces outside air into the vehicle's interior. The vehicle operator determines the blower motor's speed when the driver places the blower switch in one of 5 blower speeds. The blower motor will always operate in any switch position other than OFF, as long as the ignition switch is in the RUN position. The blower motor and mode switches are located within the HVAC control module. The blower motor OFF input is connected in series with the HVAC control module by the off blower motor control circuit.
Depending upon the selected speed, power is provided to the blower motor from either the ignition 3 voltage or battery positive voltage circuits from the fuse block. The battery positive voltage circuit only provides power when the High blower switch position is selected. Power and ground are provided to the HVAC control module by the ignition 3 voltage and the ground circuits.
Low Blower Speed When the Low 1 blower speed is selected, the HVAC control module applies voltage to the blower motor resistor assembly through the low blower motor control circuit. Voltage is divided between 4 series resistors, a blower relay, and the blower motor to achieve the desired blower speed. The blower motor is grounded through the ground circuit.
Medium Blower Speeds When the Medium 1 blower speed is selected, the HVAC control module applies voltage to the blower motor resistor assembly through the medium 1 blower motor control circuit. Voltage is divided between 3 series resistors, a blower relay, and the blower motor to achieve the desired blower speed. The blower motor is grounded through the ground circuit.
When the Medium 2 blower speed is selected, the HVAC control module applies voltage to the blower motor resistor assembly through the medium 2 blower motor control circuit. Voltage is divided between 2 series resistors, a blower relay, and the blower motor to achieve the desired blower speed. The blower motor is grounded through the ground circuit.
When the Medium 3 blower speed is selected, the HVAC control module applies voltage to the blower motor resistor assembly through the medium 3 blower motor control circuit. Voltage is divided between a series resistor, a blower relay, and the blower motor to achieve the desired blower speed. The blower motor is grounded through the ground circuit.
High Blower Speed When the High blower speed is selected, the HVAC control module applies voltage to the blower motor resistor assembly through the high blower motor control circuit. The voltage energizes the blower relay, causing the blower motor to be connected directly to the battery positive voltage circuit. The blower motor and blower motor relay are grounded through the ground circuit.
Go on you tube an check out videos on trouble shooting blower motor circuit
Chevy Trailblazer EXT Blower Motor Won Turn Off
3answers
P0011 and P0300 codes on 3.5 altima. Car shakes on idle and low RPM. Changed the cam shaft sensor and the problem persists. What more can I do?
Altima 2013 p0011 and sometimes a p0300
Thought like most its stalling must be the timing control solenoid that tells to advance or retard the overhead cam.
So I changed the solenoid for for overhead cam. BTW it is normally recommended to change all 3 but money limited and the other 2 are difficult from the top.
After traveling for work most of the year 2020 I started my car few days went by and no issue travel more for work and started to have the issue again.
Now winter I didn't want to change them all.
I have an odbc2 i used figured out that nissan altima has its own sensor addres for the timing advance low and behold when the car was working "CS Adv" was stuck at 0 or doing normal advancing and retarding between-10 and +30. When the engine was acting up stalling in idle stalling right after crank stalling at a stop the "CS Adv" was stuck at greater than +35.
The MCU is dmb and smart at the same time.
Never was there an error for timing sensor but I un plugged my suspected sensor !!!little risky!!! With dual overhead cam 2 sensors 50/50 shot. 1 sensor unplug near firewall top of the engine. The engine ran with only hesitation on starting after no stalling ever and the CSAdv was acting normal.
Replaced the faulty sensor an no issues since.
Blower motor doesn't pump well even the fan switch on high
sounds like blower bearings are dried out and will eventually lock up the blower..sometimes you can spray wd40 in the blower bearings and it will work fine for a while.. also check vacuum controls to the baffle dors in the ductwork..may have some leaks there.. should hear a slight hissing if really bad..repost findings
Blower stays on after key is removed, now a/c works in front once I hit the highway.
Which of these systems does your vehicle have ?
HVAC Systems - Automatic
The blower motor control processor controls the speed of the blower motor by increasing or decreasing the voltage drop on the ground side of the blower motor. The HVAC control module provides a voltage signal to the blower motor control processor over the blower motor speed control circuit. As the requested blower speed increases, the HVAC control module increases the amount of time that the speed signal is modulated to ground. As the requested blower speed decreases, the HVAC control module decreases the amount of time that the signal is modulated to ground.
HVAC Systems - Manual
Low Blower Speed
High Blower Speed
HVAC Control Module
The HVAC control module is a class 2 device that interfaces between the operator and the HVAC system to maintain air temperature and distribution settings. The battery positive voltage circuit provides power that the control module uses for keep alive memory (KAM). If the battery positive voltage circuit loses power, all HVAC DTCs and settings will be erased from KAM. The body control module (BCM), which is the vehicle mode master, provides a device on signal. The control module supports the following features:
99 grand cherokee blower selector high position not working. Blows only level 1-3. replaced resistor, same problem.
automatic or manual a/c.
I'm going to assume manual but Auto is simular and i can give some direction if you have that as well.
There will be a black with tan wire at the blower resistor. This is the wire the HVAC control head grounds to turn the fan on high speed. With a test light hooked to power unplug the resistor, set the blower speed to high, turn the key to the run position. the test light should turn on when you probe the connector. If it doesn't pull the control head and back probe that same wire at the back of the control head with everything still plugged in. If the test light again does not illuminate the the control head is bad and not providing ground
If the test light does turn on when you probe the blower resistor connector plug the resistor back in. Turn the blower speed to the low setting. With your test light hooked to ground see if there is power on the black with tan wire. if there is turn the HVAC off and ground that wire with a jumper wire. the fan should run at high speed. If it doesn't you have a defective resistor.
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
1helpful
IS THERE A BALLAST RESISTOR FOR THE BLOWER MOTOR. THE MOTOR IS FINE BUT IT WILL NOR WORK
Hi I will try and help you if i can.
Yes, there will be a resistor pack that controls the speed of the blower motor.
Usually on a 4 speed motor there will be three resistors.
When 4 speed is selected the motor gets full 12volts ( no resistors used )
When 3 speed is selected the motor gets its Voltage via 1 resistor ( reducing the speed )
When 2 speed is selected the motor gets its Voltage via 2 resistors ( reducing speed even more )
When 1 speed is selected the motor gets its Voltage via 3 resistors ( giving the lowest speed ).
Usually when the resistor pack burns out the motor will work but only on no.4 speed which does not use the resistors.
So i think your problem might be the control switch.
Ihope i have been of some help to you.
John ( South Wales UK )
Where exactly is the blower motor resistor for a 1997 E36 BMW located? The car has climate control. Is there a website or a place with photos specific to this vehicle??
Hi, hope the folowwing will help i found on internet if not email me at [email protected]. My service manual say its in the upper leftside of the heaterbox. remove lower left dash trim panel (drivers) and pull out resistor pack.
Fixing BMW E36 Blower Fan Speed . . . DIY!
It has been two weeks since my blower fan stopped working correctly on the low speed options (1, 2 and 3 ). It only works on high speed (Option 4). At first, I thought that the problem was in the fan speed switch because I’ve seen this problem before and when I told my electrician about it, he disassembled the switch and tried to clean it. Of course this solution didn’t work. So, I’ve decided to dig for the solution myself and I found that this is a pretty common problem among E36 cars. The problem is that speed 1, 2 and 3 are controlled by something called (Final Stage Unit on digital climate control units, Blower Resistor Pack on analog climate control units). The 4th speed is actually uncontrolled, so, it simply bypasses the final stage or resistor pack units. That explains why the fan works on the 4th speed and not the other lower speed options. Anyway, I tried to find a DIY (Do It Yourself) procedure on how to fix this problem and I found one that was written by "Deem3" on bimmerforums (thank you Deem3 for the great write-up). Now take a look below. It’s a really simple procedure. I will be trying it this weekend to see how it goes. I will post more details about this job soon. Symptoms (2 cases):
- Digital Climate Control: All the lights on your digital climate control are working and the buttons respond but the blower doesn’t blow any air.
- Analog Climate Control: The blower doesn’t work except on the highest speed (4th position).To replace it, we need to take off the driver’s side knee bolster. This only requires you to remove two screws,one on the right side of the bolster and one on the left. Using the phillips screwdriver remove the following screws. Now remove the speaker and footwell light. Using the 10mm socket remove the 3 bolts holding the metal shield. And using the phillips screwdriver remove the obd2 port. Now you should be able to see the footwell air duct. Remove it by pulling it.
With everything out of the way you should now be able to see the defective final stage unit. Remove it using the torx-20 screw driver. Replace it with the new part and before you put everything back turn on your car and test the blower. If everything is ok proceed to put everything back, and enjoy the benefits of having a blower in your car again.
3helpful
The Speed fan control is not working on 1, 2 and 3
you have a bad blower motor resistor it is very common on those vehicles and can pick it up at any auto parts store they will have that in stock
Top Chrysler Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you a Chrysler Expert? Answer questions, earn points and help others
