Question about AOC A17W221 17 in. HD-Ready LCD Television
Can change the sound with my remotes
I have broken my original remote that came with my AOC tv (the remote didn't change channels only volume ). i have direct tv and i have been using there RC16 model remote for a while now. It works but i cant change the volume and now my old AOC remote wont work at all i cant change the volume but i can still bring up guide and change channels i was wondering if there is a way to fix that
(forgot to say i can't even turn the tv on other then climbing up the wall like spider man and hit the power button same with the sound) and now with the sound if i hit the button to turn it up the tv input thing goes of instead even when im pushing +
  • aushi Apr 11, 2008
    ill look in to it i really don't want to get another universal remote tho, (i cant get the first one to work) but its worth a try '
    thank you
I recently bought a GE universal remote control, SKU: 24950, that has a control code for the AOC A17W221 TV. I bought mine at Target. You can check online to see if your local store has one before you go there. It's also listed on the GE site under consumer electronics accessories with a price. Don't know if they sell it online, though.
Posted on Apr 08, 2008
SOURCE:
Sound goes up all the way and no controll
Remote Control volume UP could be sticking inside the remote itself. Remove batteries and manually turn TV on and see if sound works ok.
Jul 09, 2014 | AOC L32W961 32 in. TV
How do I adjust my screen size
You can do this manually throught he menu and using the volume/channel buttons to toggle to the choices. Go to the video menu and in there you will be able to adjust the display size.
Jan 24, 2013 | AOC L32W861 32 in. LCD TV
AOC A15X221 have picture no sound
Try a factory reset:
1. Press and hold "Menu" and "Channel+" on the TV. (do not use the remote)
2. Using the other hand, press the Power button.
3. A small screen should appear in the top left part of the screen.
4. Using the remote, select "Memory Recall" and Enter.
5. Power off and reboot the TV and Computer.
6. Run channel auto-scan to regain the picture.
Nov 20, 2011 | AOC A15X221 15 in. LCD Television
My television set is stuck on one channel....the audio changes with the channel but the picture stays blurred on one channel...whats wrong with it?
Lots of possibilities. If you are using the remote, try also using buttons on the TV to change channels. If TV buttons work, the remote is broken or perhaps try changing batteries and cleaning battery contacts on the remote. If neither work, lots of other things to try. You may need to set preselect channels, so your TV thinks there is only one channel out there until you do. If you are on a cable box you just need channel 3 and change channels on the cable box. I can't tell what you mean by "audio changes with the channel" ... if you mean that when you try to advance channels, it increases volume and moving down in channels lowers volume that would be strange -- if you are using a programable remote it might not be set correctly (try another programming code). The "blurred" picture is probably symptomatic of having the set on the wrong channel, and if you could set channel it might clear up ... I'd start with getting channels to change. If you need more help, give the brand and model of TV, say if you are using a remote (original or programable), and what the 'audio changes' comment means in more detail. Probably worst case is that your tuner circuit is fried, but don't assume that without more diagnostic.
Aug 29, 2011 | Televison & Video
Remote will turn TV on/off. But will not change channels or volume
OPEN REMOTE CONTROL AND CLEAN IT BY COTTON .AND CLOSE THEN IT IS WORK PERFECTLY
Aug 02, 2010 | AOC L22W898 22 in. LCD TV
I can't get my dish system to work with this TV. I'm only getting 2 chanels. How do I program new chanels to this TV? I need chanel 60.
It depends on the TV a bit. Which model of Broksonic TV do you have? Do you have the original remote? (remotes.com has replacement remotes for many TVs.) Look at the TV (or the original remote) for a menu or channel add subtract option. (The TV is probably programmed to skip the channels that didn't have a signal in the past so you need to reprogram this.) If the TV is a really simple TV (with just the channel and volume controls on the TV), you'll need the original or a direct substitute remote (or a higher end programmable remote). Most basic universal remotes will control power, channel and volume but not the reprogram channels option (in my experience). If you can program the add/remove channels, press 60 on the remote, wait for the TV to go to that channel and then press the Add Channel button. Alternately, with the satellite receiver on, press the combination to search all channels and program the skip to channels with signal.
I hope this helps.
(I had a really old Emerson TV; when the original remote started to fail, the cheap universal remote didn't handle the channel programming. Fortunately, the original remote would usually still work for that.)
Jul 07, 2010 | Broksonic TV
Tv aux channel issues
youll have to use the original remote to be able to do that still. always keep the original tv remote because of those issues.
Jun 02, 2010 | Symphonic ST420FF 20" TV
MY REMOTE WILL NOT CHANGE CHANNELS ONLY TURNS TV ON OR OFF
After much trial and error, we discovered a temporary fix. We taped a 3 x 5 index card to the front of the box directly to the right of the time/ channel number. The remote will change both the channels and the sound level with this "fix." Could there be some kind of emission coming from the box that interferes with the remote? Maybe Motorola could put a more opaque front on the box.
ympm
Jan 11, 2009 | Arris DCT6200 DTV Receiver
AOC A17W221 17 in. HD-Ready LCD Television Logo
580 people viewed this question
Top AOC Televison & Video Experts
Steve Allison
Steve Allison
Ekse
Are you an AOC Televison and Video Expert? Answer questions, earn points and help others
