Television won't power up
Emerson Model EWF2006
bought on 4/23/07
won't power up
high pitched sound
I have an ilo 32 inch color tv model #iwt3206 just now 3 months old the tv madea trip to florida from new york in feb( 24 hour trip) got to florida plugged tv in . loud pop in outlet but tv powered on with no picture and then would not make any sound or give me any picture ... now the tv whenever plugged in just has a high pitched whistle with no power on or sounds other then the whistle ... what might this be and how would i fix this?? or what could i do ??
  • 236 Answers
It sounds like the high voltage circuit got damp and arced. This arc caused the horizontal output transistor to short.
You might try replacing the output transistor if you're experienced in this type of repair. If not then you need to take it to a repair shop.
The "whistle " you're hearing is the power supply indicating that it has a short on its load. When the power supply has an over load (short) its frequency drops down when your ear can hear it oscillating. This type of power supply is a switching power supply normally operating a several thousand hz(cycles) which is out of range of human hearing.
Posted on Mar 16, 2008
The buttons will not work in my 32 inch ilo tv woh can i fix it
If all the buttons except on off do not work read the owner manual carefully as the set may have a Keyboard lock out feature, on/off also could be affected depending on model.
Dec 10, 2012 | iLO IWT3206 TV
Vizio 32 Inch, turn on completely fine for about 20-30 minutes. Then sound goes out accompanied by high pitch noise and picture has varying lines or colors through it. Won't power off, have to un
Are you a decent do it yourselfer? It sounds like it is the capacitors. What happens is they get hot and expand (the top of the Capacitor). The top will be dome shaped and it will look like the top is splitting open. You can buy (about $1.50 ea.) the capacitors at your local electronics store (not Radio Shack they usually don't have a high enough amp).
You will need to take the back off and look at all of the capacitors to see which ones are bad. Usually it will be 2 or 3 of the larger ones but there could be more. Next you will need a soldering iron with a fine tip and some wicking material. How could are you at soldering and de-soldering? before I go on.
If you let me know the model # of your set I can be a little more detailed also.
Sep 24, 2012 | Vizio L32 32 in. LCD HDTV
Does ilo model #IWT3206 television have reset button ?
It does not appear to have a reset button or any type of reset menu option. Some TV's will reset by simply unplugging them from the AC outlet for 1-2 minutes then plugging them back up.
Jan 31, 2012 | iLO IWT3206 TV
I need to buy a generator for power. What is the watt power of a 32 inch ilo tv.
Hello A 32" TV sill draw about 175W from mains supply. So it is best for you to buy a generator having a rated power of at least 1000W, so that you can use the excess watts for some other purposes too, and the generator will not get overloaded with the use of TV only. Ok
Oct 27, 2010 | iLO IWT3206 TV
Remote control
you should be able to get a Universal remote and the codes for your TV. you'll most likely have to sit and enter codes till you get the right one though.
Oct 03, 2009 | iLO 3200 32 in. LCD Television
Remote wont change to vid1, vid2 please help
The GE universal remote #24914 works to change your Ilo tv from analog to digital and switch to vid1 or vid2 ect.... The code is in the book that comes with the remote. I use this remote myself. This remote can be bought at Target for under $10.
May 21, 2009 | iLO IWT3206 TV
My ilo tv picture is 1 1/2 inches. How can I fix this??
its a vertical problem could be bad cap or possible vertical i.c. okay take to tv shop is their still a warrany on this set sounds pretty new shad
May 14, 2009 | iLO IWT3206 TV
Sound but no picture
check with a flashlight against the screen for picture, if present backlight inverter has failed.
Dec 07, 2008 | iLO 3200 32 in. LCD Television
Looking for the triming for an ilo IWT3206 32 inch sdvd
you can't buy any parts for any iLo product. I too have gone through that run-around with wal-mart and iLo. Wal-mart will not even offer a refund on that tv.
Jan 03, 2008 | Televison & Video
Ilo remote control code
Yes the Emerson code 198 worked for my jumbo universal remote made my Innovage. I also have the ILO 32' TV and could not find the code but this one worked!!! Hope it helps
Sep 20, 2007 | iLO 3200 32 in. LCD Television
Televison & Video Logo
234 people viewed this question
Top Televison & Video Experts
