Question about Bosch 24 in. SHX46A05 Stainless Steel Built-in Dishwasher
My Dishwasher has no power.
My dishwasher is 100% dead. Is there a limit switch or reset on the machine?
  • Gthree Mar 16, 2008
    Had a wire melt down in the junction box. Thank you.
  • Anonymous Jun 30, 2008
    My SHX46A has the same problem. Wires melted in box. FJC.
  • 770 Answers
Have you check at the junction box behind the front bottom panel?? is the breaker ok?/ most newer homes have a switch above the counter to kill the power is that on ?? check that and let me know
Posted on Mar 15, 2008
Our power went off on our Bosch dishwasher when my husband was checking things out he noticed the wires melted the electric plastic wire nut.
Posted on Jun 01, 2008
Frigidaire fghd2433kf dishwasher. less than a year old. flashed PF. the power hasnt been off. now whole unit is dead. no lights or movement.
Hello bidness_67 please check inside of the sink cabinet look for a switch on the back wall. If there is one flip it. Many new building electrical codes require a switchto turn off power to the dishwasher. Sometimes when putting items in the cabinet the switch is hit unknowingly. If there is no switch check outlets (the GFCI ones)and press the reset then check the dishwasher.if not those two items check breaker box for a tripped breaker.
Aug 15, 2011 | Frigidaire FGHD2433KF Builtin Dishwasher
The dishwasher wont get up to temperature stagnate at 40C
possibly the temperature high limit switch needs resetting, by pushing the centre button in with your finger. Make sure power is off first.
Aug 12, 2011 | Moyer Diebel 401HT Dishwasher
My Whirlpool dishwasher was running when there was a power failure, and now there is no power whatsoever. The power failure happened when the machine was on final rinse and drain. Water is still in the...
Most Whirlpool manufactured dishwashers have a thermal fuse, located inside the operator console. When tripped, the dishwasher will not run. A power outage can cause the thermal fuse to trip. It cannot be reset and has to be replaced, if bad. Please post back with your COMPLETE MODEL NUMBER (located around the door opening) so I can determine the configuration of your dishwasher and explain how to access any potential fuses. -->
May 19, 2011 | Whirlpool Dishwashers
I have no power to the dishwasher.No lights light up om the control panel.Checked circuit breaker and there is no problem there.Is there a fuse or power reset button.
if you definetely have power into machine its sounds like a pcb fault these can blow out tracking or relays on pcb causing dead machine can be replaced but not cheap.
Aug 16, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
After final rinse on my Whirlpool dishwasher panel went dead
Check your main power input. Switch off and ON. If no display
Internal fuse / circuit would have tripped.
Try replacing / Resetting. No improvement contact service center for assistance.
Apr 16, 2010 | Whirlpool 24 in. GU2500 XTP Built-in...
Dishwasher not responding to "power"
Check the door switch. THis will kill all power to machine.
Jul 03, 2008 | LG 24 in. LDS 5811 Built-in Dishwasher
Kenmore 17052 is not working
Could be the electrical connection to the machine (behind toe panel), a fuse near the electronic control, the door switches, or the electronic control. P.S. is there a switch behind the counter, or under the sink which powers the dishwasher?
Mar 10, 2008 | Kenmore 24 in. 17052 / 17054 / 17059...
Control Panel not working
I had the same problem with my dishwasher. I have model number kudso2frss4. My husband and Father-in-law checked all the electrical and they were all fine. They found that the high-limit tub thermostat was bad. They bypassed it with a wire until the part comes in. It is working great now. Hope it helps good luck
Jan 15, 2008 | KitchenAid 24 in. KUDS02FRSS Stainless...
Won't start after repair
SUGGEST YOU PULL OUT PLUG THEN OPEN DOOR UNSCREW TOP SECTION OF PANEL TO GAIN ACCESS TO DOOR LIMIT. CAREFULLY BRIDGE BOTH WIRES OUT AND ALSO WITH WATER SWITCHED OFF, SWITCH POWER BACK ON. IF NOTHING STILL, CHECK POWER TO DOOR LIMIT. IF THERE IS POWER, EITHER THERE IS A LOOSE WIRING CONNECTION ON THE BOARD OR IT HAS AGAIN GONE FAULTY.
Aug 22, 2007 | KitchenAid 24 in. KUDM01TJ - Multiple...
Bosch 24 in. SHX46A05 Stainless Steel Built-in Dishwasher Logo
867 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
