Question about Cell Phones
Bluetooth Thanks. I'm having a hard time finding the battery. Can you suggest to me where the battery is.
  • 85 Answers
Give details of ur problem hen i will make any solution
Posted on Mar 18, 2008
My blueparrott not taking a charge can any one help me
It is actually very easy to remove the battery on the BlueParrott B250-XT. To remove the earpiece, just pull it out of the socket but be careful not to pull the wire attached to it when you separate it from the body. Next, remove the five screws to access the battery compartment. Disconnect the battery from the board and leave it disconnected for 10 minutes or so. Re-connect the battery and re-assemble. Connect the headset to your charger and after a couple of minutes, it should start charging showing red until fully charged. If it still won't charge, you may have to order a new battery. You can find a replacement battery on EBAY for around 10 dollars. Repeat the battery replacement and check to see if it starts to charge. If it works, you are good to go. If it does no work, you may have to send it to the manufacturer for repair. Good Luck!
Nov 11, 2014 | VXI Corporation Blueparrott B250-XT...
I have a G'zOne S series phone. In my line of work the phone is great. But, I've tried 3 different bluetooth devises and a couple of verizon ear pieces and I have the same problem with each one, LOW...
The best bluetooth headset for ur phone will be BLUEANT X3 MICRO BLUETOOTH HEADSET.
Here are the PRODUCT FEATURES:
  • High quality, Full duplex audio makes a natural conversation on your cell phone or computer!
  • All these recharging options are provided in the box: USB charging cable for computer, AC travel charger for 110-120 volt AC, and a 12 volt DC car charging cord (SAM460CLA).
  • Use with VoIP programs, and handle calls between both your cell phone and VoIP if Bluetooth enabled!
  • Supports Bluetooth Profiles of Hands-free, Headset.
  • LED lights can be switched off for night time driving.
  • Tiny Ergonomic Design provides a Very small size of only 52 mm x 26 mm x 28mm, and weighs only 13 grams!.
  • Rechargeable Lithium Ion Battery lasts for more than 7 hours talk time, or 180 hours of Standby time.
  • Stores Bluetooth pairing information for up to 3 different Bluetooth devices, one at a time.
  • Bluetooth Version 1.2 for Fast connectivity & security, and Bluetooth Class 2 for range up to 30 feet.
Goodluck,
Don't forget to rate me as fixya..
Jan 12, 2008 | Cell Phones
My calcomp a300 cricket phone bluetooth is malfunctioning it wont pair with phones or find any devices
First you will want to make sure that the device is set to the discovery mode and then search for other bluetooth devices to see if it will pair with them. If for some reason that does not work then what you can do is to take the battery out while the device is on, this is called hard shocking the device and you will want to leave the battery out for at least 1 minute, then reinstall the battery and power the device on and then try to see if the device's bluetooth functionality is working. If these troubleshooting tips do not work then the bluetooth function on that device is faulty. If the handset is under 1 year old. then you may be able to call your wireless provider and most of the time they will swap it out for you free of charge, but you will want to check with them first. I hope that you have found this information useful as that is my goal.
Jan 18, 2011 | Cell Phones
N73 when i try to open bluetooth application it show error msg as unable to perform bluetooth operations wht to do ??????? please suggest once i had already restored by*7780# still same problem continues
The error massege shows as unable to perform bluetooth operations when memory is full.
Try to delete some of the data applications and try to perform the bluetooth operation.
Even if you find the same problem to perform bluetooth the remove the battery when the mobile is switched on and remove the sim and reinsert after 2 mins.
Hope I helped you.
Thanks for using ' Fixya ' and have a nice day!!
Nov 09, 2009 | Nokia N73 Cellular Phone
Where in the Motorola S9 bluetooth headset is the Battery located? How do I get to it and replace it?
i think 9 times out of 10 replacing the battery will take too much time and hassle
even if you open it up get the battery out finding a perfect match for the battery will be hard getting all the voltages capacity of the battery size
if i was you i would get a new one from ebay or something
Oct 02, 2009 | Motorola Mobility S9 Headphones
Bad performance of laptop's battery
Lithium-ion battery doesn't need to be discharged like older types, in my experience it likes to be kept full most of the time and discharged only occasionally.
Check power options. If you are not using the very lowest power options, you will get a lot less life on stand-alone battery than 'advertised'.
If you are using wireless, bluetooth, the cd/dvd drive a lot, and making the HDD and CPU work hard, these all use more power.
If it's a new computer but you are getting less than say 40 mins useful time while the computer is in continuous use on stand-alone battery, perhaps you could ask Dell?
Sep 12, 2009 | Computers & Internet
Short time between bluetooth charges
You should have up to 4 hrs talk time, and 180 hrs of standby.
Make sure you charge the 2050 until the l.e.d. turns off. As long as the light is on, its still charging.
If you did that, I would return the unit for exchange, your may have a defective battery.
Mar 17, 2009 | Jabra T-Mobile Wing / Dash / SDA /...
Bluetooth light on, but laptop not been found
may be the hardware is switch off.contact your compputer manual on switching on the bluetooth dongle.
Mar 06, 2009 | Dell Latitude D600 Notebook
Replacing the battery in these headphones
The battery is inside the left earphone ( or the earphone that doesnt have the on off switch on it). I have got that far but cannot find a replacement battery.
Dec 14, 2007 | Logitech Bluetooth Wireless Headphones
Bluetooth and infared
check your imei and bt mac adress.if they are not paired,bt and ir port will not work.other thing that may be wrong is bt module itself,that got damaged after the fall of the phone
Aug 25, 2007 | Samsung SGH-D500 Cellular Phone
Cell Phones Logo
19 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
