Question about Palm Treo 650 Handheld
Buttons not working properly
Ive recently dropped my treo 650.. the buttons will work sometimes and sometimes they dont.. also when i send a text message it will switch back and forth between caps and uncaps.. and whomever recieves the text says that theres a period between every word... please help me
    Guru:
  • 377 Answers
Hi dear
BACK UP your Treo 650 software and data BEFORE doing the following.
1. RESET the Treo 650 back to default set by holding power buttom following by reset the treo.
2. There is a way to reset the voltage regulator in the Treo ; believe is by holding the RESET for > 3 seconds. Believe need to take out the battery in out during this process. Can't recalled the correct steps. This could could reset the Treo's power regulator.
3. TRY reinstall your palm software with minimun software or 3rd parties one, this software could be running in the back ground which drain the battery.
Try above steps might help.
Mine also got the same problem last two weeks, my treo could felt there is kind warm sensation if it took out from my waist pouch after leaving it for sometime on the table. BTW, the battery could felt quite warm also.
If yours also behave the same which I believed the Treo got some kind of contact problem which draw more power then usually does.
Now, mine got no more warm sensetion after carry out above steps. It gets better as Compared to last two weeks ago BUT not that good as compared previously when it can last 3~4 days after a full charge.
Good luck
Posted on Mar 26, 2008
Hi how to unlock my palm 650 to used outside of USA
You can use the Unlock code to Unlock Your Palm-One Tero 650 model Phone,You can get the Unlock code from here
Wickedunlock and follow the instructions and Unlock it step by step..
Palm One Treo 650 Unlocking InstructionsWarning : Do not enter any wrong unlock codes on your Palm One Treo 650 mobile phones. If you enter over a certain amount of wrong unlock codes on your Palm One Treo 650 mobile phone, your phone may get hard locked and sometimes become unusable.
1 - Switch ON your Palm One Treo 650 with an ACCEPTED SIM Card,
2 - Go to Menu and select "Phone Tool" or "Phone Application",
3 - Type on Virtual Keyboard *#*#CODE#,
4 - Select with PEN "Numer" and Palm One Treo 650 will show that it's unlocked now!
or
1 - Switch ON your Palm One Treo 650 with a NOT ACCEPTED SIM Card,
2 - Enter the Unlock Code we send to you.
or
1. Remove Palm One Treo 650 battery, unplug cable,
2. Switch ON your Palm One Treo 650 with a NOT ACCEPTED SIM Card,
3. 'Sim not allowed' is displayed, click OK,
4. Go to the dial pad, and dial *#*#CODE#,
CODE: The unique unlock code for your Palm One Treo 650.
ACCEPTED : We mean, to use a sim card from the network your Palm One Treo 650 is locked to.
NOT ACCEPTED : We mean, to use a sim card from a network other than the network your Palm One Treo 650 is locked to.
Jul 10, 2011 | Palm Treo 650 Smartphone
Treo 650 reset itself and the phone app seems to
plz re-install da cell phone software...the old one is damaged badly
Nov 14, 2009 | Palm Treo 650 Handheld
Trying to check out a text messaging campaign and don't know how on my treo...I want to check out Get8751 to 878787
-Go to the All category for applications
-Select Messaging
-Select the New button
-Type '878787' in the To field
-Type 'Get8751' in the Body
-Select Send
Oct 20, 2009 | Palm Treo 650 Handheld
Unlocked Treo 650 wont send text messages
I have the same problem using an unlocked Treo 650 on O2(UK).
One thing you need to do is make sure that the Message Centre Number is set correctly for the SIM network you are using. Get the MCN from the internet, then on the Treo Messaging > Menu > Options > Preferences > Network > Manual > Edit to check/set the MCN.
Oct 01, 2009 | Palm Treo 650 Smartphone
My voice drops out on palm treo 650
Sorry, no solution - just some added info. I have the same problem with a Palm Centro. Changed sim card (O2) but no improvement. Palm eventually replaced Centro, but fault persists. Anyone with similar problems / solutions?
Sep 13, 2009 | Palm Treo 650 Handheld
I can receive text messages but cant send them
contact cricket and get there messae centre number of them, enter this into the option on your message settings, also get them to send you a sim update and also a gprs message update this will sort all your problems
Dec 30, 2008 | Palm Treo 650 Handheld
Not receiving some of my text messages
I also have a Treo 650 that works flawlessly. I'm on AT&T and sometimes a message gets delayed but I don't think I've ever missed a message. I would believe it is the verizon network. It could also be effected by sunspots and the part of the world you are in.
good luck
Nov 14, 2008 | Palm Treo 650 Handheld
Palm Treo Rebooting After send an Text/SMS
Hello, hope it helps (from http://www.chaddickerson.com/blog/2006/05/19/what-to-do-when-sending-an-sms-makes-your-treo-650-reboot/)
The application that causes the reboot varies, but it’s always the same error related to the message store. Here’s how you fix it (and beware — this deletes all the text messages on your device!):
  1. If you don’t already have it, you need to download and install FileZ on your Treo. All this does is give you access to all the files on the Palm OS filesystem. This is a tool that must be used very carefully, since you can move, copy, and delete any files on the Treo, even ones you didn’t know were there. It’s one of the most useful Treo utilities you can have.
  2. Run FileZ on your phone and choose “View and Edit Files.” In the next screen, you should see “Internal” under Filename. It might also say “ROM.” If you have an SD Card, you should also see “External” or “SD Card.”
  3. Click on the little wedge beside “Internal” to expand the list of files on your Treo.
  4. Find Messages Database and delete it (you do this by checking it, choosing “Details,” and then clicking “Delete”)
Apr 01, 2008 | Palm Treo 650 Handheld
Palm treo 650
You can do a soft reset by pressing the small indented button on the back with your stylus,: or you can do a hard reset by removing the battery and pressing the same button on the rear with your stylus. I would try the soft reset first, as the hard reset wipes all your data.
Jan 05, 2008 | Palm Treo 650 Handheld
Palm Treo 650 Handheld Logo
Top Palm Computers & Internet Experts
Michael Vincent Cruz
ray gallant
Raj Patel
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
