Question about Vizio P2 42 in. HD-Ready Plasma Television
Visio 42 in Plasma turns on but no picture
I have a 42 inch viso plasma screen and everything was working well and then all of a sudden no picture. I pulled the back off the TV but i dont see burned parts. Do you know what could be wrong with this TV?
  • 1 more comment
  • sheltervet Mar 26, 2008
    My Vizio did the same thing last night. It is not an input problem. Just suddenly the screen went out, but we still had sound. I could still CHANGE the input (because I could hear it was being changed) but couldn't see a thing. TV still turns on and off. Called Vizio and it'll cost $537 for a repair (flat fee for the model) and I'm panicking. I just paid $1500 for this tv not two years ago.
    I am looking for the most likely problem (assuming it isn't anything external) so that I can figure out if I can find someone local to fix it. (No one seems to be willing to touch vizios, say they can't get parts)
  • jjflores592 Aug 11, 2008
    how can I buy parts for my Vizio 42" plasma tv. I don't have picture but everthing else works.
    Thanks
    jjflores592
  • sigmaproject Jan 13, 2009
    My Visio P42HDTV10A Plasma TV made a loud pop and then went black, has sound, but no picture. Was the pop the primary power supply board? How can I tell if the board is bad? I plan to take a look, but if there are specific spots where there might be burning then it would be good to look. Thanks for this site and all who post. REALLY HELPS OUT!
Just had the same problem and determined it was the primary power supply board. The TV has a primary and secondary power supply. The secondary controls the on/off and audio. The primary controls the picture. If this is shot, you will not get a picture but will hear audio. I had to call Vizio and have them send me a new power supply board ($150 + SH). Not too hard to install yourself. Hpe this helps!
Posted on Aug 22, 2008
I have a 42" vizio and have the same problem. veryting work except no picture. I bought this tv in costco almost 2 years ago. My question is can I take to costco for exchange?
Thanks
jjflores
Posted on Aug 05, 2008
    Scholar:
  • 50 Answers
Hello, My names Dave and I can tell you that you all most likely have a bad Z sustain or Y sustain board! The good news is that most of the time if either of these boards are bad you will find a blown fuss one them! I have worked on this same model of TV many times! You can lay the TV face down very gently and remove the back cover from the TV and test the fuses on the Z & Y sustain boards to confirm which one of the two are bad!
Z sustain board! P/N's: 6871QZH956A or 6871QZH056B Here is a link to the Z sustain with a picture of the board so you'll know what you're looking for http://www.shopjimmy.com/lg-6871qzh056b-zsus.htm
If you look at the Z sustain board you'll see that there are two white fuses on the board FS1 & FS2 are the location #'s. There is also a third fuse (FS3) it is a surface mount type fuse and can be easily over looked. Just locate the 8 pin main plug right next to the other two fuses and you can't miss it. It's smaller and it will have gold colored ends on it and it to is white with the location # FS3 next to it!! If any of these fuses are blown you will need to replace the board to complete the repair! You will need to test the fuses for continuity with a DMM (Digital Multimeter) Do to the fact that you will not be able to just look at the fuses and be able to tell if they are good or bad!
You'll also want to test the three fuses (FS1, FS2, FS3) on the Y sustain board P/N's: 6871QYH953A 6870QYH005B ! Here's a link to a picture of this board also. http://www.shopjimmy.com/catalog/product/view/id/179043/s/ysus-6871qyh953a/
Two of the fuses (FS2 & FS3) on the Y sustain are easy to find because they are normal white fast acting type fuses! The third fuse is also a surface mount type fuse and can be easily over looked. Just locate the 9 pin main plug right next to the other two fuses and you can't miss it. It's smaller and it will have gold colored ends on it and it to is white with the location # FS1 next to it!
If any of these fuses are blown you'll need to replace the board to complete the repair! You will need to test the fuses for continuity with a DMM (Digital Multimeter) Do to the fact that you will not be able to just look at the fuses and be able to tell if they are good or bad!
If you have any questions please feel free to contact me via www.pleasefixitdave.com there you will find all my contact info!
Dave~1-503-432-9904
Posted on Apr 01, 2010
Same issue here.  I opened the unit up and took a look.   I was just given this TV for free by a coworker who said Vizio told him it required a new "powerpack"  I'm assuming power board.  In any case on my powerboard there are two toggle switches with the labels Standard /Auto and 30v/24v.  I reversed both these toggles and on a whim put it back together.   So far the thing is working great screen comes on and right now I have it plugged into my cable boxes coax output.
Posted on Jan 22, 2009
  • 25 Answers
Make sure you have the correct imput selected. If possable check the cables on another tv. Make sure the tv is not in sleep mode. If you try all of these things and do not get any results take the tv to an authorized repair center.
Posted on Mar 26, 2008
    Problem Solver:
  • 5 Answers
I have good boards for the p42 hd. My screen went bad (broken ribbon cable). I would sell you the boards out of mine. LTHandy at yahoo. thanks, Lee
Posted on Mar 29, 2010
I have a vizio 42 lost video only if i turn off and on again i get video for about 4 minuites
Posted on Mar 09, 2010
Picture on 42" visio went
there is a part that controls brightnes n contrast on tvs, thats the one that has to be replaced by an expert. When done make sure u use standard surge guards to avoid such damage. Its a simple job.
Jun 09, 2011 | Toymax Viore 42 in. Plasma TV
I have samsung plasma tv 42" ps42c7s,have sound but dark ,no picture
Hi friend,,,
welcome to fixya
Commonly for Plasma tv's if the screen went out,,the problem will be the CATHODE RAY TUBE,it is costly to buy.if you want you can buy it,,or it may be the D-board problem will be also,,,
but it is unusual,so check the tube.
if your satisfied with my solution PLEASE RATE IT
thank u...
Apr 09, 2010 | Samsung SPN4235 42 in. Plasma HDTV
Sp42a we have sound but no picture can this be fixed
there a Plasma screen defect, needs to be checked by a tech. send to repair.
Jan 02, 2010 | Vizio P2 42 in. HD-Ready Plasma Television
Sound but no picture on 32in visio plasma
this sounds like you need a professional, can you get it fixed under warrenty
May 31, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
Samsung ps42d5s-screen is blacked out
Heya,
Does anyone know where i could get a LVDs cable for a samsung 42 inch tv searched everywhere and cant find one the model number is PS42D5s thanks in advance
Feb 27, 2009 | Samsung PS42D5S 42 in. EDTV-Ready Plasma...
42 inch LG Plasma TV - Lost picture
Most likely what happened is one of the capacitors went bad. When a capacitors goes bad it produces a popping sound. This could be an easy and cheap fix if you find the bad capacitor or capacitors. The bad capacitor will have a bulging top most likely on the power board but could be anywhere.
Feb 24, 2009 | LG 42LC3R 42 in. LCD TV
Trying to hook up a Visio 42 inch TV to my dishtv
the cables are for, sound, video. yellow is video. my daughters tv did this also. we had to junk it no one carries parts for Vizio. i would call the store and take it back, something got knocked loose during the transaction between the store and your house.
Good Luck
Aug 14, 2008 | Vizio P2 42 in. HD-Ready Plasma Television
No picture
Hav 50 inch lg no pic but got sound wtf how do i fix it an there r 5 flashes b4 green light stayes on at the start
Apr 10, 2008 | LG 42LC2D 42 in. LCD HDTV
We have no picture!
the problem is a bad y-drive bd & possibly y-sus bd. have more detail if necessary. your welcome
Feb 08, 2008 | LG 42PC3D 42 in. Plasma Television
Vizio P2 42 in. HD-Ready Plasma Television Logo
2,810 people viewed this question
Top Vizio Televison & Video Experts
pzarnold
Level 1 Expert
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
