CANON SUPER G3 IMAGE CALL MF4150
PRINTER WILL NOT PRINT. PRINTER INDICATES PAPER JAM. THERE IS NO PAPER JAM.
  • BOYANCE Mar 20, 2008
    PRINTER INDICATES PAPER JAM. THERE IS NO PAPER JAM. THE ANSWER TO MY PROBLEM IS MY PRINTER NEEDS TO BE RESET. I'VE TURNED MAY PRINTER OFF AND BACK ON. HOW DO I RESET???????
  • Sweetpea40 May 20, 2008
    printer states it has a MF paper jam, no paper is jammed it will not receive faxes
  • 148 Answers
Your printer needs to be reset.
Posted on Mar 16, 2008
Print copy cleaning on canon mf4150
If the toner is not fixed on the paper, and very likely that the fixing film is broken.
in this case it should be replaced fixing unit.
Mar 03, 2015 | Canon imageCLASS MF4150 All-In-One Laser...
Canon printer MF 8080 cw will not reset after a paper jam
Hello, If the printer will not reset then you still have a piece of paper stuck somewhere in the paper path. Did you power the printer down and back up? Here is manual.
Canon imageCLASS MF4150 Manual
Sep 30, 2014 | Canon imageCLASS MF4150 All-In-One Laser...
I had a major paper jam at my printer (Canon, Super G3, imageClass MF 4150). I removed all the paper which was not easy. The printer is not working and switches to following messages: Paper Jam, Lift panel...
  1. Protect yourself from shock. Disconnect the power cord from the back of the Canon Inkjet Printer. This is an important step when working inside ANY electronic device.
  2. Step 2 Unhinge the back access panel of the printer. It seems repetitive to say this, but this door will be in the BACK of the printer.
  3. Step 3 Look through the opened back panel and look for paper. Remove any and all paper you find jammed there.
  4. Step 4 Close the back access panel. Make sure that it latches into place and looks the same way that it did before you opened it.
  5. Step 5 Find the front or top access panel. This is the panel you would lift to change ink cartridges. Open this access panel. If the carriage that holds the ink cartridges moves, then you forgot to unplug the printer, go back and do that now. Look for paper that may be jammed in this area of the printer.
  6. Step 6 Remove any paper you find jammed here. When pulling from the front there will be resistance from the paper feeder. Pull slowly or the paper will rip and create a more stressful problem.
  7. Step 7 Close the front access panel. Make sure that it falls or latches back in place. It should look the same way that it did before you opened it.
  8. Step 8 Plug the printer's power cord into the wall outlet, and attempt to print again. If the printer prints the job, then you have successfully removed the paper jam.
Jan 26, 2010 | Canon imageCLASS MF4150 All-In-One Laser...
Got a paperjam. Pulled out the paper, but the paper jam error won't go away and the printer won't print. I read that it may be the paper jam trigger spring that is out of place now and requires...
No it's not. Make sure to open EVERY door on the printer and check for any additional paper. Also, power the printer off and back on a few times and see if it goes away.
Dec 24, 2009 | Canon imageCLASS® MF4150 All-In-One Laser...
The paper feeder of my canon super g3 jams every time
Yes, there is an easy solution, possibly. Mainly because you say it may do a single job, and then it keeps jamming. Do you see the second sheet jamming in when it is not called for? Anyhow, you may try cleaning the rollers, all of them, like I did here: http://annoyances-resolved.blogspot.com/2009/09/paper-jam-buy-new-laser-printer.html This completely solved my problem of persistent paper jams.
May 04, 2009 | Canon - SUPER G3 FAX BOARD-T1 (0450B002AA)
Canon Imageclass MF4370dn constant paper jam errors
Dear
Inside the back panel there are paper sensors attached to lever, a small spring connected to lever to keep its home position, the spring may dislocated from its position or the lever sticked to the base. some times a small piece of paper sticked at this may cause the problem.
Thanks.
Apr 20, 2009 | Canon imageCLASS MF4150 All-In-One Laser...
Canon MF4100 Series UFRII LT has paper jam after i accidentally turned off the printer while it was int he middle of printing. The LED screen on the printer says "Paper Jam" then "Lift panel to open open...
just press the resume button and if the problem presist switch off your printer and computer and again restart both of them. and if still paper jam then press resume button.
Feb 27, 2009 | Canon - SUPER G3 FAX BOARD-T1 (0450B002AA)
I have a canon super g3 printer and it has a error on it saying rec. paper jam
I pulled the plug on it, counted to 10, and plugged back in. So far the first fax worked fine. We'll see if this takes care of the problem.
Dec 28, 2008 | Canon - SUPER G3 FAX BOARD-T1 (0450B002AA)
Copier canon mf4150 says it has a paper jam, but there is no paper jam.
1. First, clean your printer. Get some spray-n-wipe cleaner and a clean cloth and clean the entire inside of the printer. Also ensure your paper isn't dirty. Now print a test page. Does the symptom persist?
2. Remove all jammed paper. Check the paper tray first. Look closely at the paper rollers nearest where the paper exits the printer; this is a common source of jams. If you’re trying to print labels, they will often jam just before exiting the printer.
3. Try to print a test page. Does the printer still jam? If you can find no source of the jamming, check the printer's message display window and refer to your user’s manual to look up the printer error code.
Sep 16, 2008 | Office Equipment & Supplies
Computers & Internet Logo
403 people viewed this question
Alun Cox
David Payne
David Payne
