PROGRAMMABLE ROOM THERMOSTAT
Wireless siemens PROGRAMABLE ROOM THERMOSTAT RDJ10/RDJ10RF This controls my baxi combi boiler control which is on the blink.
Transmitter working - receiver not live - this happened when replacing batteries into transmitter.
receiver is hard wired in to the 240V mains electrics of my home.
Have tried to reset reciever function - no joy
Q. Need help to re-set the receiver as first fix.
Q. Want to know if I can manulaly over ride this unit without danger to the boiler and us and use the Baxi main contol unit and switch it to the CONTINUOUS position?
Any help apprecitated
Thank you
Peter & Lindsy
    Sergeant:
    Champion:
  • 326 Answers
I found this on a search:
"I have the full set of instructions, contact me at gjb@eggconnect.net
Not a very reliable system, transmitter keeps resetting to 17:25; locks up. Whole system then requires setting up from scratch. Had a replacement transmitter, no change, and same faults.
GJB"
Perhaps this can help.
Posted on Mar 16, 2008
Manual for Thermostat Siemens RDJ10RF
THE BOILER READS ROOM STAT OFF, BUT IN ACTUAL FACT IT IS ON, PLS ADVISE WHAT TO DO
Nov 08, 2009 | AT&T Siemens S46 GSM Cellular Phone
Boiler is a baxi control for heating is honeywell.
this will be your diaphram inside your divertor valve.
the one that looks like a spaceship.
it will e split.
Oct 05, 2009 | Honeywell Programmable Thermostat Heater
Re: combi boiler.
if you have hot water at the taps but the heating isn't working make sure the thermostat is set high enough for the boiler to run check the time clock settings are on.
if these are working it could be a faulty diverter valve switch not sending a signal to the boiler to run.
Mar 23, 2009 | Water Heaters
Require room thermostat for ferroli combi boiler optimax 25c . I have a honeywell at the moment which stopped working. it has two wires coming into it from the boiler
Get a Ferroli wireless programmable room stat. City plumbing supplies can get hold of them but you'd be looking at approx £130. Part number 30800009. No wiring involved, the receiver connects to the boiler pcb. Had same problem but now fine.
Feb 18, 2009 | Honeywell Programmable Thermostat Heater
When i turn heating or hot water on fuse board trips
it was a faulty heating pump. replaced, all ok now.
Jan 03, 2009 | Honeywell Electronic Programmable...
I have a Honewell CM921/927 wireless programmable room thermostat that is operating the combi boiler in AUTO mode even when the time setting is meant to be off (no output). The target temp is 20 deg and...
If the room is at the set temperature even when the rad are warm the boiler is doing its job. It takes steel rads up to an hour to cool down so if they stay warm to the touch that is normal.It takes steel rads a long time to heat up when they get cold so its cheaper to let them not get real cold.I was told not to put a programmable thermostat on our boiler simply because it takes a lot of gas to bring your house up even two degrees. I run a non programmable and set our heat at 72 degrees and do not touch it all winter. There should be a water shut off on each rad so if you want your bedroom cooler just shut that shut off on that rad off.
Apr 10, 2017 | Honeywell Heating & Cooling
Computers & Internet Logo
1,336 people viewed this question
Alun Cox
David Payne
David Payne
