Question about Dishwashers
Kenmore elite clean lite is flashing won't shut off.unit won't work modle #66516912001 serial#fk4402228.it flashes 7 times over and over.i shut off all power turn back on still flashes .i replaced electric board in door panel new button panel
  • rtrendler Mar 15, 2008
    the answer you gave scares me.i already called sears and they will be happy to send a repair man.they won't give answer they won't make money that way .unless its your uncle.thats why i paid for this fixya.tell me this is not the way you guys work.
    it seems when we use the rinse aid something go wrong.
    President:
  • 1,314 Answers
I have a service bulliten on this if you will email me at [email protected] ill send it to you its too big for here
Posted on Mar 15, 2008
  • robert samples Mar 15, 2008
    and thats not how we work here lol
    Genius:
  • 3,587 Answers
That's a sensor issue...something is truly unhappy..kenmore is the least likely to have a service manual online. maybe if you call Sears service, they'll at least give you a hint as to what's up with that..
  • Patrick Michaels
    Patrick Michaels Mar 15, 2008
    well, as you may know, not everyone knows everything. among the appliance folk, Kenmore is the most closed with information. Of course, you'll find that soon enough...
    besides, what did you pay< 10.00? That would get you around 5 minutes with a service tech.
    good luck
SOURCE:
Won,t work just flashing blue light
Cycle light flashes, but machine wont start - Kenmore Elite ...
https://www.ifixit.com/.../Cycle+light+flashes,+but+machine+wont+...
iFixitThe Kenmore Elite HE3 is a washing machine by Kenmore. ... Whatever cycle I choose, the light just flashes and holding the start button ... I don't seem to have a black pin....the normal wash button just keeps flashing and won't let me start or .
The good ol' Whirlpool Lid Lock Flashing Light Problem - ApplianceBlog
www.applianceblog.com/.../42456-The-good-ol-Whirlpool-Lid-Lock-Fl...
Dec 11, 2013 - 10 posts - ‎3 authors Red Lid Lock light flashing intermittently when you try to start a cycle. ... Mode -- Lid Lock won't work, nor will anything that requires the lid to ... Once the lid has locked the second time, the washer ... shuts down with the lid lock blinking; go back into diagnostic codes and look for shifter or speed sensor errors ...
Nov 26, 2015 | Washing Machines
Kenmore elite dishwasher stops in mid cycle green clean light flashes 8 times pauses and then flashes one more time
Float Switch
The float switch may be hung up and this can cause the dishwasher to be stuck in a cycle. see the diagram
Timer / Control
If your dishwasher gets stuck in a cycle first try shutting off the breaker for at least 5 minutes if this does not correct the problem you will need to replace timer/electronic control.
May 23, 2013 | Kenmore Dishwashers
My washer keeps shutting off and flashing 11F
serial communication error communication between the central control unit and the motorunit cannot be sent correctly
check wire harness connections to the MCU, the motor,and the CCU
check the drive system for any worn or failed components
check MCU
check motor
check wire harness
Apr 30, 2010 | Kenmore Elite 45986 Front Load Washer
I HAVE KENMORE DISHWASER MOD.#665.16034400 SERIAL#FR4603273 THE GREEN (CLEAN) LIGHT IS FLASHING AND UNIT WILL NOT RUN. CAN YOU HELP PLEASE? I have tried making sure door is shut and latched properly. I...
Usually light flash on computerized panels when there is a problem in the circuitry. Some have a 'pattern' to the flashes that will be know to a serviceman. Depending upon the problem it may be cheaper to buy a new unit than to repair an older one.
Oct 02, 2017 | Kenmore Dishwashers
Kenmore 665 17033400 Elite dishwasher clean light flashes 7 times and it wont run. i used the reset combination, all lights lit and stayed lit until i pressed reset. Then it started a wash. now the wash...
That signals an issue with a faulty heater &/or heater drive circuit.
(that info comes from their troubleshooting guide)
I ran into it this weekend and discovered that the heater coil in the bottom of the washer was broken.
Jan 14, 2010 | Kenmore 24 in. 17032 Built-in Dishwasher
Washer stops in middle of load and flashes F11.
this is not good . F/11 CODE serial communication error . the communication between the central control unit (ccu) and the motor control unit (mcu) cannot be sent correctly . now that sounds bad . don't panic!! ck the wir harness connectors to the mcu ( motor ) and ccu ( program panel . something is loose/ also ck the drive systen for any worn of failed components .belts/pulleys/ leakage.. ck mcu/ the ccu/ ck motor/ ck wire harness. -hope this will help . (look for loose connections this is most common.. mm
Dec 02, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite Dishwasher clean light ind flashing and won't start
You will have to reset the console. To do this, close the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cyle finish (1-2 minutes).
You should now be able to run the dishwasher as normal.
Feb 17, 2009 | Kenmore 24 in. 15142 Built-in Dishwasher
That means the control sensed that the heater in the d/w did not operate 3 times in a row. so the unit locks out. First remove the kick plate and you may have to pull the unit out from under the cab, but check your heater. use a meter to see if it reads open, if so order a heater assy it will come with a new control replace it to. If your heater checks good press in sequence normal wash , heat dry ,normal wash,heat dry , normal wash , heat dry three times within 6 sec all the lights will come on then hit cancel. What that did is reset the control and clear that fault. Keep in mind that d/w does not heat it's own water your incoming water temp should be 120. the d/w will maintain that temp. when starting your d/w first turn on your hot water till it gets hot then start your d/w this insures your unit fills with hot water and not cold
Jan 09, 2009 | Kenmore 24 in. 15142 Built-in Dishwasher
Keeps flashing clean Kenmore dishwasher 665.17019401 need a new owners manual
i was trying to install my kenmore elite 665 dishwasher but i cant find the plug do they come with one? or were do i hook it up?
Sep 22, 2007 | Dishwashers
Dishwashers Logo
65 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
