AKO 131800500 washer timer
I have a Kenmore washer, model 41729042992, that would not start, it just hummed.  I replaced the timer and I'm not sure if I connected the correct wires to the #1 and 1a terminal.  The type is 514 154 A   419.  I may have reversed them.  I ran it through a wash cycle and it seems to work normally.  How can I tell?
  • Craig Monsen Mar 16, 2008
    The timer would not turn, the humming was coming from the timer motor.  I replaced it and everything seems to work fine.  I'm just not sure about the last two wires I transferred from the old timer to the new one.  I looked for a wiring diagram on the inside of the cabinet, but I didn't find one.
  • raallen22 May 12, 2008
    I have the same problem rcraigy. I was thinking it is the timer, So thanks for posting this before I took the whole thing apart to troubleshoot. Guess I'll order the part on EBAY $80 vs $146
  • 105 Answers
What do you mean on your comment that wash cycle works ok
does it wash and only hum on spin
i do not have a wiring diagram to help you on 1 and 1a
so you need to use trial and error
Posted on Mar 16, 2008
SOURCE:
Kenmore Elite wash model 100 22942 only hums, will not run after it is filled. The washer is about 17 years old
If the motor is humming it could be that it is stuck and cannot turn. Look for obstruction in drive or pump. If you leave motor on it will burn out. See if you can disconnect the motor from what ever it drives to see if it will spin freely. If it does then my diagnosis is correct.
Sep 14, 2017 | Kenmore Washing Machines
Kenmore washer 110.16112503 works in wash & spin cycle but not rinse. After wash cycle finished I hear a humming sound and the machine does nothing until I manually start spin cycle. Broken timer?
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
Sep 18, 2016 | Kenmore Washing Machines
I have a kenmore series 90 washer, model#110.20912990. There is no power, apparently there is a blown fuse, but where is it located? I just put the new timer.
First, see the Sears Parts site for your washer:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.20912990&pathTaken=partSearch
Next, see the Whirlpool / Kenmore Service manual for top load, direct drive washers. It has a troubleshooting guide.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
The easiest thing to check is the Lid Switch. Are you sure that it's connected?
Beyond that I'd make sure the timer is installed correctly and that the motor is connected.
Apr 23, 2010 | Kenmore Washing Machines
Motor will not start it only hums
Check three things:
1: 120V to the motor
2: Correct resistances of motor windings
3: Pull off the pump and make sure nothing is locking it, and subsequently, the motor shaft.
If all those things check out, replace the timer, it may be making intermittent contact.
Hope that helps.
Nov 09, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore Washer, Loose Timer Knob
There should be a spring clip that holds the timer knob on. It or the timer knob may need replaced. Here is a picture of the timer knob and the spring clip. Sure hope this helps and best wishes.
Jul 23, 2009 | GE WBSR3140DW Top Load Washer
Kenmore TL Washer Just Hums
try to wash by 1/2 load the same cycle maybe the problem come from overload laundary
Jun 06, 2009 | Washing Machines
I need to replace the timer on a series 800 washer
Fix the timer on the washer so that it fills with the correct amount of water, and so there is the correct amount of time for each cycle. Make sure the washer is unplugged and take off the control knobs and the panel that lays over the knobs. The knobs could be either at the front or back of the machine. Check the wires that link the timer to other areas of the washer. If they are slack, push them further into place with pliers.
Change the timer by disconnecting the old one. Make sure the new timer is made for the brand of washer that you own. Unhook the wires to the old timer one at a time and connect each wire to the new timer.
Mar 02, 2009 | Kenmore 23822 Top Load Washer
Kenmore Model# 110.25842400
Yes that is the correct lidswitch. (i checked via model # on sears.com) Before you replace the switch, Turn the washer manually into spin and see if it will. If it spins your lid switch is ok. If there is a humming after the washer fills then your motor is bad. It trys to work but cant. if it does nothing after it fills then you have a bad timer most likely. But see if it will spin when you turn the timer to spin manually.
Nov 20, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 70 series washer
Does it hum or click? If it clicks your coupler is out or a hum could be a faulted gearcase.
Aug 19, 2008 | Kenmore 22422 Top Load Washer
Kenmore Washer 41729042992
Plug off the wall socket. Your motor brushes need to be cleaned or changed.
Jun 25, 2008 | Miele W1903A Front Load Washer
Washing Machines Logo
808 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
