Question about RCA P52926 52" Rear Projection Television
FORMAT I THINK....
TOP OF HEADS LOOK CUT OFF, PICTURE LOOKS TO CLOSE UP. IS IT THE FORMAT? I'VE TRIED THAT TOO. WHAT COULD IT BE?
  • 373 Answers
Try "Zoom" feature
Posted on Mar 16, 2008
SOURCE:
Cant get a full screen
quite often their are bars on the top and bttom of the picture, or on the side because of how wide the original picture size, if you look for a button on the remote that says 'Format', you should be able to adjust the picture size, but it may cause other channels or movies to 'cut off the heads' or stretch other images
Oct 19, 2013 | Sony Televison & Video
Im trying to flush the cooling system on a '97
Not positive about that engine, but the usual method is the heater inlet will come off the cylinder head somewhere and to the firewall, and the heater outlet (the return hose) will be at same place on the firewall and go to the water pump, very close or at the fitting where the lower radiator hose attaches to the water pump inlet.
Jul 21, 2013 | Cars & Trucks
To whom it may concern. I own a RCA D52W23 Monitor and run it through a VHS recorder. The problem I am having is when watching non-HDTV channels,I can not see the top of the picture (Heads cut off).Only...
look through the video or setup menu and find Picture Format- make sure it is not set to ZOOM.
I believe "format" is also on the remote-- upper left?
Apr 13, 2011 | RCA D52W23 52" HDTV CRT TV
Returning to "streched" picture as top of heads
Remote control is needed to change aspect ratio. The button on the remote is labeled format. Standard definition sources have six picture sizes and HD has two.
Bill W
integrityhomeworx.com
Mar 13, 2011 | Mitsubishi WS-55511 55" Rear Projection...
Picture is cut off at the top and bottom of the screen - The top of the head is cut off and any writing on the bottom Help!
Look on your remote to see if you have a picture butto or you can try and go to the menu settings and see if you can adjust the tv format from widescreen to regular or 4:3 or 16:9
Sep 23, 2009 | Televison & Video
Heads cut off on the screen
Ocean's Eleven. Best remake movie, I think.
I believe your TV is in "ZOOM" mode for the screen. This will make a 4x3 picture come up closer to fill in the 16x9 screen, but this cuts off the top and the bottom.
Keep pressing the WIDE button on your remote until the picture looks best.
If you have HD channels, the screen mode should be on NORMAL. HD channels will have the 16x9 screen format.
The non-HD channels will have 4x3 screen format. When the screen mode is on NORMAL, you will have the cut off picture on the sides because the 4x3 format will not fill in a 16x9 screen.
May 30, 2009 | Vizio Gallevia GV42LF 42 in. LCD...
Cuts off the bottom of my pictures
that happens to my camera also
what i think is happening is that live view uses a digital immage not what the image sensor sees when you take the picture the optical view finder uses the atual immage that the sensor will see
May 25, 2009 | Sony Alpha DSLR-A300 Digital Camera
My closed captioning is getting cut off
Are you changing the format or picture size. Some times marked zoom on the remote. Are you using a cable box or SAT recever. These boxes also have setting for format change.
Apr 24, 2009 | Televison & Video
Mitsubishi WS-55513 55 in. - Picture to latge for scheen
Change your Display Format (widescreen mode) . You're using ZOOM. Press FORMAT on the TV remote control to cycle through the available display formats.
Feb 09, 2009 | Mitsubishi WS-55513 55" Rear Projection...
Can't view entire screen
make sure that you tv is set to the "standard" format and then try changing the aspect ratio on the cable box.
Jan 26, 2008 | Mitsubishi WD-52631 52" Projection HDTV
RCA P52926 52" Rear Projection Television Logo
32 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
