Question about Dell UltraSharp 2005FPW 20.1" LCD Monitor
Dell 19" Monitor - Dead
Just went blank, no lights, no power, no nothing. Tried switching power cord, power strips etc. Nothing works, hate like hec to throw away a 2 yr old monitor - Dell Ultra Sharp? What else can it be, is there a light or fuse that mabye burns out, how you get these flat things to open. Thanks.
  • 2 more comments
  • rajuncajun Mar 19, 2008
    Absolutely couldn't get it to power and couldn't open it. When I dug in my paperwork further found out it was still under warranty, had it replaced. But I will be back to this site in case one of the others not on warranty ever go out. Thanks y'all. :)
  • Pauldias Aug 27, 2008
    When connected to power nothings happen.
    Can I repair it?
    Is there a fuse protecting it which is burned?
    I would appreciate your assistance.
    Thank you so very much.
  • quintonvl
    quintonvl Dec 05, 2008
    i have exactly the same problem - my fpw2005 was fine, then while working the screen faded to black and the front power led went out.. sounds like the ps went, so does anyone know how to get the outer back cover off so i can remove the power supply and test it?...
  • dsteinmann Jan 24, 2009
    I Have a 1703FPT and a 1901FP and the power supply is bad on both. the green light comes on and so does the picture but no backlight. I've replaced most of the caps but no help. Does anyone know what the common failure is on these power supplys?
Go to you can buy the board you need there , you can talk to tim he can help you out or email him
Posted on Mar 19, 2008
  • 138 Answers
Hi this is the way how to examine what's wrong with your LCD monitors. Power on both CPU and monitor. After it went blank, you have to check that you can see the image on the screen by shining a flashlight into the screen, not directly but find the best angle to the screen and take a look very closely. If you can see the icons or any image, there will be a minor problem. Like mine, I can see window image using flashlight and check lamps inside. Some of them were broken and it is very easy to replace. If you cannot see anything on the screen, there'll be some problems with inverter board. If you have soldering tool and want to fix it by yourself, check the caps first. It may cause this problem. Some caps might show leaking or burn spot on the board because of too high temp. If you don't have soldering tool, you better go get a technician to do so.
Thank you,
Posted on Mar 16, 2008
The monitor does not power up. no power light comes on, there is nothing that shows up on the screen. All cables are well connected and yes the power switch is on.
check by changing the power cord if this does not solve the problem the fault is in the power of the monitor better call technician or take it to the service centre
Aug 02, 2011 | Samsung SyncMaster 940UX LCD Monitor 19...
Desktop monitor went black & and wil not power up
Try the fuse on the monitor power cord, and if this does not cure, you will have to get another monitor....pretty good prices on ebay!
Jan 04, 2010 | Computers & Internet
Desktop PC monitor suddenly went black & power light went off
1 either ur VGA card is corrupted or
2 RAM is corrupted
3 Last may be your motherboard is gone - not sure
Monitor dead
Check your power cables properly and make sure it is attached. Check your power button, maybe you have pressed the wrong one.
Jan 03, 2010 | Acer AL1916W 19" LCD Monitor
Screen went blank and orange light is on
fiona_sheeha, If ACER warranty service not an option, then unit will need local tech to troubleshoot unit's power supply/inverter circuit for possible COMMON and repairable printed circuit board fix. You must read more of my fixya profile and visit the web links you find there so you will know and understand what ALL your options are!!! Some units require less than $5 in parts to refurbish them to working status. Your "cold-cathode-fluorescent-lamp" backlit LCD monitor isn't any different than any other brand of monitor in it's basic operating principles!! I hope this helps. 12fixlouie
Dec 30, 2009 | Acer AL1916W 19" LCD Monitor
Dead monitor dell e173fp lcd monitor
This could be either down to an internal fuse blown or the main board or the capacitor on the power supply could be faulty.
Sep 04, 2008 | Dell E173FP 17" LCD Monitor
Dead pc
try to remove all external device connected to your computer. just leave the keyboad, mouse and monitor connected.
restart computer.
if still a blank screen
remove everything connected to your computer (mouse kyeboard and monitor) restart if nothing happens
open your computer and remove all devices (hard drive, optical drives, memory... restart,,, you should be hearing beeping sounds indicating motherboard is looking for memory. try putting back 1 memory at a time and checking all mem slot. to identify if one of the memory could be causing the blank screen. if both memory will not work try to use known good working memory. if you dont get to hear the beeping sound using a known good working memory. your memory is the problem.
give me more info
Jun 19, 2008 | Dell XPS 200 PC Desktop
No power dell 1900fp silver blank screen power ??? help!!
try swapping the computer power cable and don't connect the vga cable with the system. if you get a power on self test displayed it makes sure that the monitor is fine. if nothing is displayed you can take it for repairs or else call 1-800-624-9896 its Dell technical support number or log on to
Jun 03, 2008 | Dell UltraSharp 1900FP 19" Flat Panel LCD...
Bank Monitor problems
Unplug the cable from your PC, if the monitor shows a test image, the monitor is fine and the problem is with your graphic card. If you dont see nothing on-screen after unpluging the cable from the PC, then the monitor in damaged. Send it to repair.
Jul 09, 2007 | Dell E193FP 19" LCD Monitor
Dell UltraSharp 2005FPW 20.1" LCD Monitor Logo
1,102 people viewed this question
Alun Cox
