Question about Pentax K100D Digital Camera
Autofocus does not work ( when ON ) with any lenses .
  • krazydarcy Jul 17, 2008
    My autofocus seems to sweep from far focus to near and back once and gives up trying to focus. My focus indicater when in manual focus ) works fine which tells meit's not a problem with the sensor. I suspect my problem might be the firmware (flashed from v1.0 to 1.02)
    Problem Solver:
  • 18 Answers
I remember reading a review of the K100D that mentioned that it had poor low light performance. I know mine has a really hard time focusing in low light situations. It does the sweeping back and forth & most of the time never ends up taking a picture. (Even when it bursts the flash to try to focus.)
I've just started experimenting by using a flash light aimed at the subject I want to focus in low light situations, and the camera seems to be able to focus & take a shot more reliably.
If this works, I'm going to rig up something to hold the flash light underneath the camera so that I can use it more often.
I will post an update if this works!
Take Care & Happy Imaging!
Glen
Posted on Aug 01, 2008
SOURCE:
Is adding grip for nikon d5100 solve the problem of auto focus with sigma 170-500 lens
No. This lens lacks an autofocus motor, relying on the camera to have one. The D5100 lacks an autofocus motor, relying on the lens to have one. Adding a battery grip does not change this situation.
The D5100 only autofocuses with lenses having an internal autofocus motor. Nikon designates such lenses AF-S, Sigma calls it HSM. Lenses without the motor will only autofocus with the larger and heavier Nikon cameras such as the D7000.
Nov 27, 2012 | Polaroid Wireless Performance Battery Grip...
I have a Nikon D40x and purchased the AF nikkor 50 mm f/1.8D lens a couple years ago, but find that it can only be focused manually. Is there any way to "turn on" the autofocus? I have not had...
Sorry, but the D40x lacks an autofocus motor, depending on the lens to have one. Nikon calls such lenses AF-S. This particular lens does not have such a motor, relying on the camera to have one. The only 50mm lens currently available with an autofocus motor is this one:
http://www.nikonusa.com/Nikon-Products/Product/Camera-Lenses/2180/AF-S-NIKKOR-50mm-f%252F1.4G.html
Earlier this week the Nikon web site listed a new 50mm F1.8 lens with an autofocus motor, but then it was removed. Hopefully they will officially announce this lens soon.
Apr 14, 2011 | Nikon Normal AF Nikkor 50mm f/1.8D...
Will a Nikon Sigma 70-210 work on my nikon D60??
Assuming the lens has a Nikon mount, then it will fit and work on the D60. Sigma makes lenses for a variety of cameras; a lens with a Canon mount, for example, will not fit onto a Nikon camera. However, the 70-210 is a rather old lens. Unless it specifies "HSM" it will not autofocus on the D60. The D60 does not have an autofocus motor, relying on the lens to have one. Nikon calls such lenses "AF-S" while Sigma designates theirs "HSM".
Feb 03, 2011 | Nikon Sigma 70-210 F4-5.6 55MM AutoFocus...
LOOKING FOR A Nikon Normal AF Nikkor 50mm f/1.4D Autofocus Lens WITH VR.
There is no such thing. You can see a full list of current Nikon lenses at
http://www.nikonusa.com/Find-Your-Nikon/Camera-Lenses/index.page
You can see a list of current and old Nikon autofocus lenses at
http://www.bythom.com/nikkordb.htm
You'll see that no 50mm Nikon lens has ever had VR.
Sep 28, 2010 | Nikon Normal AF Nikkor 50mm f/1.4D...
I'm looking to buy a digatil camera a D3000 and
See my answer to your other post.
One more addition for the D3000. Older autofocus lenses without a built-in motor will not autofocus on the D3000. Only AF-S and AF-I lenses will autofocus on the D3000.
May 07, 2010 | Nikon Cameras
I have a Nikon D60 and my autofocus has stopped working. It is not because of the lense because i have tried other lenses and the auto focus won't work with them either so it must be an issue with the...
You should check custom menu setting 2, and make sure it's set to one of the auto modes. Make sure the lenses you are using are AF-S and not regular AF lenses. The D60 has no autofocus motor, so autofocus only works with AF-S lenses.
I always suggest folks take a look at Ken Rockwell's website also, here's a link to a specific page on autofocus on the D60.
Post a comment here if none of this works and I'll see what else we can do.
http://www.kenrockwell.com/nikon/d60/af-settings.htm
Jan 08, 2010 | Nikon D60 Digital Camera
Will my quantaray tech-10 NF AF zoom lens (for me
Yes, with caveats. The autofocus won't work on D40/D60/D3000/D5000. The metering may not work in all modes on all cameras. Since you didn't specify which camera, I can't give you a better answer than that.
I have 30-year-old Nikon lenses working fine on my D90, but without metering. And the old lenses date before the invention of autofocus.
Nov 27, 2009 | Cameras
Nikon 18-55 zoom lens doesn't autofocus
You might like to check if the A/M slider switch on the lens by the Nikon label is set to A.
It sometimes gets moved accidently.
Set to M the lens will not autofocus.
May 24, 2009 | Nikon Normal AF Nikkor 50mm f/1.8D...
Won't take pictures when set to A on the lense.
if you're using D40/X, make sure that the attached lens has built-in autofocus motor (e.g. code AF-S for Nikon, HSM for Sigma), because the camera does not have built-in autofocus motor in the body so only manual mode will work in most AF lenses..
if you're lens is already one with built-in autofocus motor, you might need to check the motor at a service center
Apr 16, 2009 | Nikon D40x Digital Camera
Pentax K100D Digital Camera Logo
140 people viewed this question
Top Pentax Cameras Experts
Ekse
Jerry Greenberg
Jerry Greenberg
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Pentax Camera Expert? Answer questions, earn points and help others
