Question about Lenovo ThinkPad R51
Micro phone problem
Hi
micro phone no working every time i fill windows problem.
    Sergeant:
    Champion:
  • 256 Answers
Is your antivirus upto date it is because of virus.
Posted on Mar 15, 2008
I just got a zte n817 phone want to get a 32gb micro sd card will it be compatable with this phone
That is kind of an entry level phone. You better stick with a 8Gb or max 16Gb micro SD. When the card fills up, the device slows down and that is a pain. So, try to get a class-10 micro SD if you can.
Jun 08, 2017 | ZTE Cell Phones
My mobile is not working ,at the time of working some files corrupted and it showing not enough memory while i wants to play music now it's not going to switch on
hi,
lets try to fix your problem without spending a single cents..removed your micro sd ,(small memory card of your phone) then scan it in computer,,by doing this you need an all in one card that supported mini sd,mini sd ,memory stick etc..then you will find if your micro sd is having a virus..back up your files then reformat your micro sd ,then after formatting back your files...without your micro sd open your phone ,if it is ok now ,so the problem is your micro sd...if still there the problem ,reset your phone by doing this ,type *#7370# and enter your locked code..wait until the phone reboot itself.
if not works we go to the second solution but you need this gadget and tools in able to fix your problem...
1.mxkey dongle activated
2.ufs interface
3.7210c fbus cable
*open mx key
*select BB5
*put the fbus cable in 7210c
*put the mcu ,ppm ,cnt ..(the flash file must be higher than former version to prevent damage on phones software ,the old version shall appear when you scan or bus check the phone..)
*bus check the phone
*back up rpl first in mx key
*flash the phone and wait until it is done..
goodluck and thanks for trusting fixya..
Jun 22, 2010 | Nokia 7210
My mobile 3110c is take so much of time for start
hi,
lets try to fix your problem without spending a single cents..removed your micro sd ,(small memory card of your phone) then scan it in computer,,by doing this you need an all in one card that supported mini sd,mini sd ,memory stick etc..then you will find if your micro sd is having a virus..back up your files then reformat your micro sd ,then after formatting back your files...without your micro sd open your phone ,if it is ok now ,so the problem is your micro sd...if still there the problem ,reset your phone by doing this ,type *#7370# and enter your locked code..wait until the phone reboot itself...goodluck ,i hope it will help you..
Jun 16, 2010 | Nokia 3110 Cellular Phone
Hi..how do I transfer phone contacts to sd card?
hey you cannot transfer contact in sd card, unlike the picture images etc. but phone contacts you cannot,
Nov 15, 2009 | Samsung SCH-i760 Smartphone
Having problems playing music frommy sandisk 4gb micro memory card on my motorola ve240 cell phone
I have a similar problem, the issue for me was windows media player was creating a folder called music on my sd card and uploading the music there during sync function. However, the phone only looks in the \my_music folder on the SD card. Sync your phone, then rename the newly created music folder to my_music and the player will work. Still looking for a permanent solution to this problem.
Apr 27, 2009 | Motorola Mobility MOTORAZR VE20 Cell Phone
Memory Card dnt work ? how do i fix it ?
hi..there may be a problem with your mobile phone micro-sd slot
or their might be a problem with ur micro-sd card. u can also do
one thing just take the micro-sd card and clean the pins of micro-sd
card with spirit,aftershave lotion, isopropyl or body spray. just take
the above mention chemical in a soft cotton cloth and then try to
clean the pin of sd card by rubbing the cloth on it.
try this out..
thank u..
rate me..
Apr 12, 2009 | Motorola Mobility E770 Cellular Phone
I have a PNY MICRO SD 2GB for my Samsung Messenger. When I put the Adapter into the computer it showed some files. One named My_Music. I put a CD in and downloaded the Cd onto the My_Music file. It showed...
Hi. Well the problem is that your songs probably aren't recognized as mp3 files. I have a SanDisk micro SD and I downloaded a CD onto on a program such as RealPlayer or Windows Media Player first. Secondly, I dragged the files from there onto my SD. Try this but if this doesn't work then take out your micro SD and format it to your phone. This will end up erasing all that you have on there and possibly require you to do it many times just as I had to do, t eventually mine did work perfectly. I hope this works.
Dec 23, 2008 | PNY 2GB microSD Memory Card
D900 mp3 problem
Just try formatting the SD card. Hope it works fine.
Just connect the micro SD with computer.(You need SD adapter, SD card reader, and USB connection) Most computer will recognise the SD card automatically. Format the micro SD in the Window Explorer(or My Computer). Format menu can be found if you click right-button with cursor on the drive letter. After formatting, re-insert micro SD into your D900.
Some Korean experts says the problem might be caused by different file system (e.g. FAT, FAT32, etc) in each memory card. So they recommended not to share your memory card with different mobile phones as well as any electric devices (eg. MP3 player and digital camera).
Nov 24, 2008 | Samsung SGH-D900 Cellular Phone
Vaio and micro sd
Appreciate the direct "Ask Me".
Since you have verified that the card works (in your phone) and that the adapter works (in another computer), then the issue could very well be with the Sony VAIO VGN-C140G/B. More specifically, the USB ports/drivers. Presumably that the Sandisk 2Gb Micro SD & the adapter were working before and that you are using Windows Vista, pls check your updates that has anything to do with USB. Alternately, you may want to rollback/downgrade the USB drivers and/or seek USB driver update from the Sony site rather from Microsoft.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for your continued patronage of FixYa.
Sep 12, 2008 | Sony VAIO VGN-C140G/B Notebook
Saving music on my micro sd..
why cant i get my micro sd to show on my phone
Oct 26, 2007 | LG CHOCOLATE VX8500 Cellular Phone
Computers & Internet Logo
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
