Question about Seagate Medalist Pro 2520 2.56 GB IDE Hard Drive
Drive does not seem to spin when power applied, but it does seem to get warm. Otherwise not seen by the computer. Jim
  • borgardt Mar 15, 2008
    Drive is old and has some data on it. It has been formatted and partitioned and I would just like to recover the data. My sense is that it is broken, but is the data recoverable?
    Jim
    Novelist:
  • 104 Answers
Is your disk new? what are you trying to do with it? Is it partitioned and formatted? has any info recorded in it?
if its new, you have to make partitions, and of course make sure its well connected.
if its old and gets hot, it might be broken.
Posted on Mar 15, 2008
  • Carpenocte Carpediem
    Carpenocte Carpediem Mar 15, 2008
    data would be recoverable just if you can read the disc... so you have to insiste till windows or any os recognize it... make sure its well connected and boot windows five or six times... (you could also try this, thinking that you have a stuck problem on that hd... this is like funny and not much "academic orthodox methohd" but.. if after those booting it still not responding, disconnect the hd, grabb it with one hand from the sides and strike it not too hard against your other and, do it 3 or 4 times to see if the heads are stuck... FROM SIDES; not up and down and gently at first ok? it is better to do it more times than to do it hard... then connect it again and try. If you can see the disk on windows you can use EasyRecovery Pro to recover data and you can get a trial version from the net... http://easyrecovery-professional.softoni...
    GOOD LUCK, remember, that method is only LAST RESOURCE without spending money.
Computer powers up, MONITOR says no signal
had same problem...re-install windows ...bad drivers and such
worked fine after that
Mar 31, 2014 | Gateway Computers & Internet
My external lacie 500gb hard drive is not mounting. Its not spinning to mount. I need the data off of there. If i can get it to mount one more time i can transfer the data to another drive.
Try plugging it into different ports on your computer as well as moving the cable slightly on the drive. You probably have a loose connection somewhere on the drive so if you can get the contact it requires it should start up for you.
May 06, 2011 | Computers & Internet
Not detected hdd sata
IF you are trying to install windows, you will first need to obtain the SATA drivers for your motherboard
(This normally applies to XP only) as Vista has the satas onboard the install disc. Download the sata drivers, save to USB or floppy and when prompted at the "Press F6 to Install raid divers, press F6 and let the computer find the Sata drivers, should then install ok.
IF you have a sata installed already, and the computer cannot find the drive, do the following:
1.) boot to the Bios (f1 or F2 or F10 or del) depending on your computer, see if the drive is recognised in the Bios.
If it is proceed to step 2
If it is not, then either the Sata port connector is damaged, the sata cable is damaged or the power rail to the drive (could be a sata or 4 pin molex) is not making good contact, or the drive has suffered internal failure
2.) If teh bios "sees" the hard drive, but will not boot from it or it is still not appearing in My Computer (assuming this is a slave drive), then suspect damage to teh hard drive, you can see if it is trying to spin up by feeling the top of the drive for vibrations, it will also get warm.
3.) If the drive is not seen in My Computer and is NOT your boot drive, go to Control Panel > Admin Tools > Computer management > storage > disc management, see if teh drive is listed there. If it is, but is marked as unknown, you will need to format it
Jan 09, 2011 | Computers & Internet
Cd drive gets power but does not work
Check the Data cable from CDRom to Mainboard
May 12, 2010 | Dell Latitude C640 Notebook
COMPAQ PRESARIO S5200NX WON'T START - Press start button, led's light up for about 5 seconds - hard drive starts to spin, then led's go off and every thing shuts down. Power supply is ok (swapped power...
Hi:
Since you swapped the power supply already, and have disconnected the DVD, CD, and floppy, that leaves the hard drive and motherboard!
Look the motherboard over, and see if there are any capacitors that are bulging or leaking out on the tops.
Is the inside of the computer very dusty? Check and make sure when you power up the tower, that the cpu fan is spinning up.
Your CPU could be overheating, so removing the Heatsink fan and re applying thermal paste is an option too
If it is, try resetting the CMOS on the motherboard, or pulling the CMOS battery for a minite.
Do you get anything to display on the screen?
If you have more than one stick of memory, take out one of the sticks if possibleif possible.
Nov 06, 2009 | HP Compaq Presario S5200NX (DM173A#ABA) PC...
Running DIAG504fcd.iso says no hard drive detected
It's possible the hard drive disks are not spinning, the power and data cables may need to be reseated. Otherwise, the drive is history.
Jun 21, 2009 | Western Digital Caviar SE WD1600JS 160 GB...
Vostro laptop dvd/cd player not seen by system.
Try to get into the bios settings to make sure the device is enabled there.
Aug 02, 2008 | Acer Aspire 5610-4648 Notebook
CD/DVD drive stopped working gradually
  1. Ensure the Drive is seen in MY Computer
  2. Try removing the upper and lower filters per this article: http://support.microsoft.com/kb/314060
If the drive is seen in BIOS and in MY COMPUTER, but will not read any media after running the microsoft fix and rebooting, then replace the drive.
Jul 06, 2008 | Dell Inspiron 4000 Notebook
Non-spinning washer
Do you hear the motor running when it doesnt spin? Is the belt still over the idler pully between the drive pully and motor pully? Does the lid switch operate properly? Need a little more information if you can. Give me a shout back, and we'll figure it out. Jim
Oct 31, 2007 | Washing Machines
Open Questions:
Toshiba Support USA - Toshiba Online Customer Care Support USA Toshiba as a brand has continued living up to the expectations of its customer for nearly three decades now, by maintaining the high quality of its products with the help of delivering a combination of useful software and attractive hardware in a package, which is required for providing the needed technological expertise. With laptops becoming an indispensable and integral parts of our lives, it is important that companies today equip their laptops with all the advanced technologies along with a sleek and stylish design for that attractive feature that would add to its plus point. Our Toshiba technical support team members are available all the time on our Toshiba Support number +1 888 784-9316 and are highly adequate in resolving issues related to Toshiba printers. The fact that everyone today knows about Toshiba Support brand and most people who have tried Toshiba products like them, makes them one of the most reliable in case of printers especially. Toshiba makes business portable laptops, with highly durable features of being sturdy and long- lasting for use in all walks of life. Most laptop owners would agree to the fact that Toshiba products are designed to provide quality portable solutions and highly acclaimed for their bullet-proof build value. But with time, users might face issues with Toshiba Virus like any other laptop band and these issues can be prevented from causing any severe damage to the laptop by accessing resolution from our technically specialized team members, who are available on our +1 888 784-9316. Issues faced by Toshiba customers: Toshiba Backup BIOS update issues Slow Performance Office and outlook setup Wifi and Internet Issues Audio & Video Issues Startup and Boot problems Windows updates Windows 10 upgrade issues Computer Tune-up Issues Virus Removal Issues Data Backup, Transfer and retention issues All these issues and many more, concerning Toshiba users are directly and efficiently resolved by our technically knowledgeable team who can be Reached 24/7 on our Toshiba Contact- +1 888 784-9316.
Apr 23, 2018 | Toshiba Computers & Internet
See all Seagate Medalist Pro 2520 2.56 GB IDE Hard Drive Questions
Seagate Medalist Pro 2520 2.56 GB IDE Hard Drive Logo
60 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Computer Links
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
