Question about Epson ACULASER CX11NF All-In-One Printer
Copier stopped working - has ADF jam message
In the middle of copying a page off the glass, the copier broke down and now has a continuous ADF jam message. i have tried turning it off, unpluggin power and unplugging scanner and plugging all back in to no avail. copier will not work and message will not clear even though it says press start to clear.
i can still print from my computer, just no copies or scans.
  • 1 more comment
  • lunafarm Mar 15, 2008
    btw, it's an epson aculaser cx11nf.
  • mikeena Mar 26, 2008
    i have the same issue. i was told that it is probably the adf board. just cant find it or a new adf
  • Anonymous Mar 27, 2014
    Have cleared paper, reset paper, powered off and on. Message still wont clear. Taken flashlight and cannot find even a tiny piece of paper. Copier is locked into paper jam message with red blinking light.
We had the same problem, the machine had an ADF alarm,we turned it off and on but no good, we also tried to Unjam any paper and rollers but no good.
We then turned off the machine, and unplugeed the mains power and then unplugged the top cable, plugeed both back in and turned on the power.
And now the machine is working perfectly.
Posted on Oct 20, 2008
While trying to solve the problem, i unplugged the cord & plugged it back in. that solved the problem.
Posted on Sep 17, 2008
    Problem Solver:
  • 11 Answers
As mentioned in the other thread concerning this problem, the board seems not the problem.
I had the same problem and found out, that the cable connecting ADF and "main machine" was the problem. In this cable are 10 wires, one of them - in my case the violet one - was broken.
I used a new wire and soldered it in between, now it works fine.
I think - as this very short cable is only plugged on both sides (ADF side under the cover) - you should check this first. Spare - part should be much cheaper.
An other soultion can be, that the sensor - hook slid out of his mount.
Hope this helps
    Genius:
  • 1,447 Answers
What operating system are you on?
Posted on Mar 24, 2008
SOURCE:
PIXMA MX330 Error message "Document in
The sensor may be dirty even if it looks like there is no paper jam. Take a bottle of compressed air and give it a once over. Make sure you don't shake or tip the compressed air as you don't want to fast freeze anything.
If this does nothing, you probably have a failed sensor which will need replacing.
Chris
Aug 18, 2011 | Canon Office Equipment & Supplies
Trying to fax, scan or copy and anytime I try the erro message Document in ADF press OK to discharge document
Hi sdrnjen977,
Here's what you can do to address the issue and clear error message: Document in ADF.
If you press the Stop button during scanning, Document in ADF. Redo operation after checking document in ADF and pressing OK. appears on the LCD. Press OK button so that the remaining document is automatically fed out.
Removing the jammed document from the Document Tray:
1. If printing is in progress, press the Stop button.
2. Turn off the machine.
3. If a multi-page document is loaded, remove any pages other than the jammed page from the ADF, then open the Document Feeder Cover.
4. Raise the Paper Release Lever, then remove the jammed page from under the roller to the Document Feeder Cver side.
5. Pull out the jammed document from the ADF.
6. Press down the Paper Release Lever, close the Document Feeder Cover, then turn on the machine.
Removing the jammed document from the inner side of the Document Cover:
3. If a multi-page document is loaded, remove any pages other than the jammed page from the ADF.
4. Open the Document Output Slot.
5.Open the Document Cover.
6. Insert your hand into the Document Output Slot, then while pushing up the paper output rollers inside the Document Output Slot with your fingers, pull out the document from the inner side of the Document Cover.
7.Close the Document Cover.
8. Close the Document Output Slot, then turn on the machine.
Hope this helps.
Thank you for using FixYa.
Jun 30, 2011 | Canon PIXMA MX860 OFFICE AIO-2.5IN LCD...
Does canon pixma mx 310 work faxing page up or page down?
When using the ADF load the document with the side you want to copy, fax or scan facing UP in the ADF.
When using the platen glass load the document with the side to be copied, faxed or scanned facing DOWN on the platen glass.
Trust this helpful.
Please vote.
Dec 15, 2010 | Canon PIXMA MX310 All-In-One Printer
Everytime I fax something on my HP Laserjet 3050, the recipient receives the document with a line going down the middle of the page. How do I get rid of the line?
The way this ADF works is that there is a stationary scanner head and the machine moves the paper over it. The line down the pages is due to debris stuck between the page and the scanner. The ADF panel should open to show you the glass that needs cleaning. See the link below for full instruction. You should be able to test this by making a copy.
Jun 14, 2010 | HP LaserJet 3050 All-In-One Printer
Hp LJ 4345 mfp vertical line down printed copies
Dirt.
Open the ADF, the top of the scanner/copier.
The ADF glass is the thin strip of glass on the left. Damp cloth with windex or any glass cleaner. Scrub the strip of glass.
Dec 04, 2009 | HP LaserJet 2840 Printer
When trying to copy papers do not feed but if you scan they will
HP LaserJet 3050z, 3050 All-in-one, 3052, 3055, 3390 and 3392 versatile printer - Error reported: Document Feeder Jam ISSUE: How to correct the HP LaserJet 3050z, 3050 All-In-One, 3052, 3055, 3390 and 3392 versatile printer if this error is reported: Document Feeder Jam SOLUTION:
  • Clear the jammed media from ADF (HP LaserJet 3050, 3050z).
  2. Remove any jammed media with care.Take out the page gently. NOTE: Take care not to tear the paper. c01075162.gif
  3. Close the ADF cover plate.
  • Clear the jammed media from ADF (HP LaserJet 3390, 3392, 3052 and 3055).
  1. Open the ADF cover plate. NOTE: Check whether all packaging straps inside the ADF are removed. c01075163.gif
  2. Unload the jam clearance component.Lift the two handles with both hands until the component clutch is released.Rotate and lift the jam clearance component, and then put it aside. c01075164.gif
  3. Lift the green handle, and rotate the paper picker until it is opened. c01075165.gif
  4. Gently remove the page without tearing it.If you feel resistance, go to the next step. c01075166.gif
  5. Open the ADF cover plate, and loosen the media gently with both hands. c01075167.gif
  6. When the media are stopped, pull the media out gently along the shown direction. c01075168.gif
  7. Close the cover plate of the flat scanner (HP LaserJet 3390, 3392, 3052, 3055). c01075169.gif
  9. Insert the jam clearance component to reinstall it.Press the two reeds until the component is properly engaged.Install the clearance component correctly. Otherwise, paper jams will continue to occur. c01075171.gif
Have a good day
Jun 22, 2009 | HP LaserJet 3055 All-In-One Printer
Minolta EP 2010 copier, top loading doesn't pull paper
Hello sir; try to made 2 copies one go through by adf another one just put on the glass,if one copyclean another not clean then clean up the glass, if both copy all lines then replace drum unit.
Jan 06, 2009 | Office Equipment & Supplies
Black Line in the middle of the page.
open the adf and you will see small glass, on the glass is a spec of dirt or most proberly tipex, clean the glass and line will disapear
Apr 01, 2008 | Brother MFC-7820N Laser Printer
Epson ACULASER CX11NF All-In-One Printer Logo
176 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
