Question about GE Spacemaker JVM1640SJ Microwave Oven
Ge microwave - uninstall from mounting plate
No matter what we do we cannot get our ge microwave uninstalled. all screws are removed, but because of the countertop above the microwave, there is no space to lift the back to get it off the mounting plate. help!
  • GE Master
  • 9,098 Answers
If you don't have the installation instructions, you can get them here.
They're very helpful when installing OR uninstalling.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Mar 16, 2008
How do you uninstall a GE spacesaver microwave oven
Deanna, it would probably be best to have a second person there to help hold the microwave. You would need to loosen and remove the screws from inside the cabinet that hold the microwave to the cabinet. Just to let you know, as you face the microwave, the right side of it will be a lot heavier than the left side because of all the equipment that is behind the control panel. You might put a pillow or something else soft to help cushion the microwave and protect your counter in case it lets go all of a sudden. Depending on the model and the type of mounting bracket there could be anywhere from 3 to 6 screws that hold it in place. Hope tis helps!
Feb 13, 2015 | GE Microwave Ovens
How can I remove a GE Spacemaker Microwave JVM62
Some older microwaves slid off the mounting plate. Try pulling it forward and see if it slides off. Some of them had screws that screwed into the back plate. Remove the grill panel and see if there are screws on each side.
Aug 25, 2014 | GE Your Spacemaker Microwave Oven Model...
Remove mounted GE Spacemaker Microwave JVM140K
There should be 2-3 screws thru the floor of the cabinet above the m/w that secure it in the front. Once those are removed the m/w will slide straight out on rails mounted to the wall plate.
Dec 28, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Was microwaving a hotdog on a paper plate covered by another paper plate and the microwave just kind of went poof and now nothing lites up (display) and it wont work. I checked the breaker it is on and...
Yes there is.
Unplug the MW.
Uninstall from wall mount (if installed that way.).
Remove outer cover by removing the screws at back and (possibly) bottom sides.
Locate fuse. Replace only with an equivalent type and amperage.
You can test the MW without reinstalling or putting the outer covering back on.
Dec 21, 2009 | Kenmore 63672 Convection/Microwave Oven
I need to know how to uninstall a GE spacemaker microwave oven model JVM250av001...any one out there know how..?
Put padding on the floor near by for a landing zone. Disconnect the power in the cabinet above. There are two screws in the upper cabinet that support the front. There is a wall plate that supports the back. When the two front screws are removed you will need to be supporting the microhood or it will fall. A strong assistant is nice to have. I like to have the stove out of the way so I can get under the microwave to support it. Once the front two screws are removed, tip the front down, pull the cord out of the upper cabinet. Then lift the back slightly to remove it from the channel on the wall bracket. Set it down Done.
Sep 13, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
How do i UNINSTALL MY ge spacemaker xl
TIP: Go to the web and type enter your model number then scoll to page 4 of 7 and when you come to BACK COVER, click to enlarge exploded diagram on left. Veiw enlarged diagram at top of page. You can print the entire diagram by holding your pointer in the upper left hand corner of diagram. Select the print icon. Now you have what you need. Part number 993 is the mounting plate attach to wall. Open your cabinet doors above microwave, have someone hold it, and remove the screws going through cabinet into top of microwave. Pull down and out slowly towards you until the unit slides off the support arms. If you found any of these suggestions helpful, please rate my solution. D. Lange
Apr 27, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
I'm trying to remove a Hotpoint RVM58003. I removed four long bolts from the top but it does not move. Any help on what I need to do to remove it? Dan
The Hotpoint RVM58003 (circa 1984) cannot be lifted off a hanger after the four top screws are removed because it doesn't have a separate pre-installed hanger like newer units do. The rear mounting screw holes are part of the outer frame of the unit, which requires removal of the Microwave sub-assembly of the Hotpoint RVM58003 to expose the outer metal frame and the array of pre-drilled rear mounting holes before the rear mounting screw(s) can be accessed and removed. Based on my recent experience removing a Hotpoint RVM58003 Microwave Hood from 1984 it appears the unit was originally installed this way too. Please note that this is a very involved process. Basic steps are: 1) Unplug AC power to the unit, or turn off the circuit breaker. 2) Remove the top plastic grill over the door and control panel (2 screws). 3) Next to the grill screws remove the larger left/right screws holding the Microwave sub-assembly in. 4) Drop down the hinged light bulb/air filter cover panel (mine had 7 screws). 5) Remove the small metal cover plate on the right under the control panel. This exposes the Microwave sub-assembly electrical connector. 6) Disconnect the Microwave sub- assembly connector. 7) Carefully pull the Microwave sub-assembly out of the frame and set aside. You may need to fish the power cord through the cabinet or unscrew the power cord terminals. NOTE: this is best done with a helper because this sub-assembly is about 25-30 pounds. 8) Once the sub-assembly is out the rear plate is exposed and the rear mounting screws can be removed. I found that the GE/Hotpoint Owner's Manual does not have installation instructions. Neither does the GE web site, they only have the Owner's Manual. For more specific help and instructions I suggest calling The GE Answer Center at 800-626-2000 or hiring a professional installer experienced with this older style Microwave Hood.
Jan 23, 2009 | Hotpoint JE740WY/GY Microwave Oven
How do I uninstall an old Sharp R-1450 Carousel over the stove microvave oven? I removed the screws from the top that it hangs on and it still won't move. Help and Thanks.
You need to remove the grill above the door to find two more screws that go straight to the back wall plate. They will be on the left and right side. That is the only other way that they mount to the wall.
Good Luck
Dec 18, 2008 | Sharp R-1480 Microwave Oven
You can download Kitchenaid/Whirlpool owner's manuals and installation instructions here.
They're very handy when uninstalling them too.
If you have a problem with your microwave, we may be able to guide you to an affordable repair.
If you're interested, please reply back with your brand and model number as well as your symptoms so we can help you.
Dec 14, 2008 | Microwave Ovens
GE Spacemaker JVM1640SJ Microwave Oven Logo
335 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
