Question about Saeco Royal Professional Espresso Machine
Coffee Grounds My Saeco Royal Professional is not forming pucks in the dredge drawer. And the grinds seem damp and very course. What shall i do?
    Sergeant:
  • Saeco Expert
  • 223 Answers
I would try cleaning out your coffee grinder first.
Here is the link to some helpful documents: http://www.cerinicoffee.com/Saeco_technical_documents.asp
Espresso machines and cleaning supplies
Visit www.CeriniCoffee.com
Posted on Mar 16, 2008
2 Suggested Answers
SOURCE:
  • 70 Answers
SOURCE: Coffee Grounds
Grinder needs to be adjusted or it popped out of its shaft.
Grinding the coffee too fine or the grinder backing up will cause tension between the upper burr and the grind shaft casing.
Once this happens 9 times out of 10 it will relieve pressure by popping itself out of the shafting or worse yet, cracking the shaft itself.
If you open the side of the machine where the brew drive is and you see grinds all over the place, there's a good chance that's what happened.
Needs to be sent out for repair.
Posted on May 22, 2008
New Royal Professional Machine has the workd Dregraw.miss can not use the machine what must I do to get started need help.
Hi
Dredge drawer is the big box on the bottom right. That is where the grounds are dumped. Remove the drip tray and pull the drawer out about half way. Push it back in with 1 finger on the right side of the drawer. That should clear the message. If it comes back on when you put in the drip tray, there is a section of the drip tray that can be removed to stop that. On the right side of the drip tray is a notch. Inside that notch is a thin piece of plastic. It curls up on the right side. Cut out the piece that curls up (just the piece that curls, about an inch). When you push in the drip tray that curl lifts the dredge drawer and knocks it out of position.
Jan 10, 2011 | Saeco Royal Digital Plus Coffee...
My coffee is weak. i have played with the grinder, placing it at different no. on the outside plus i have played with adjustment on the interior.
Hi
Check the grinds. If they are coarse you have a separated grinder. It usually means it needs to be replaced I have seen them on ebay, but if you can't find them, I have some. If they are not coarse, you have to make 3 coffees before the grind will take affect. After you change the grind you have to make 3 drinks before you will see a change. If you don't have a puck in your dredge drawer, you don't have enough coffee going into the brew unit. Push the lever behind the door in the center top back to the +, then forward 1 click, and try that. There should be a full puck going into the dredge drawer that has the consistency of coarse sugar. If it very coarse its the grinder.
Dec 12, 2010 | Saeco Magic De Luxe Espresso Machine
Machine won't work due to dreg drawer
Check to see if your machine has an "exit chute" or similar area where from the used pucks are ejected. The area might be clogged with used coffee grinds and causing a false reading from the machine.
Dec 14, 2009 | Saeco Royal Digital Plus Coffee...
My Saeco magic grinds the beans, but no coffee comes out. Sometimes it makes one cup, and skips. Other times, I grind the equivalent of 8 cups of coffee without any cups of coffee coming out.
HI
When a machine grinds but doesn't make any coffee there are a couple of things.
If the grounds are wet in the dredge drawer, then you have a plugged brew head and need to clean it.
If the grounds are dumped dry into the dredge drawer, then you have an overcharge and need to adjust the dosing lever back from the full charge. On your machine it is inside the door at the top center. Pull the lever back towards the front 1 click. Then try again.
Nov 14, 2009 | Saeco Magic De Luxe Espresso Machine
DREDGE DRAWAR FULL SIGNE COMES UP. EVEN AFTER EMPTYING DREDGE DRAWER MACHINE WILL NOT RESET TO PRODUCT READY
Hi When you empty the dredge drawer, the machine must be on and in use. Take the dredge drawer out and leave it out for 15 seconds. If the machine is off when you empty it doesn't know that.
Jun 15, 2009 | Saeco Royal Professional Espresso Machine
Waret Pucks
Hi There are 2 problems that can cause a watery puck. 1. Like EsWorld said, If the grinds is too coarse it leaves room for more water and you get a watery puck. 2. But if your grind is like a grain of salt, the you don't have enough coffee going into the brew unit, and this leaves room for extra water. To fix this, there is a lever on the top center of the door. The lever will increase the dose if pushed towards the back. DON'T push the lever to the full back position. This could cause an over charge, which could cause the brew unit to dump the ground coffee with out making because it could not compress the charge, or it could break the brew drive. 1 click back from the full plus is fine and will give a great shot.
Jun 03, 2009 | Saeco Royal Professional Espresso Machine
SAECO Royal Professional no water comes out?
Hi
What is the lever for despensing grounds on the top of the side door reading. If its all the way to the back it probably too far. Pull it back one click and try it. The other thing you should try if its not the grounds it to push the button you want to use and hold it in until the liquid coffee want is reached, then release the button. This is called programing and you can do it to each button for you desired amount.
Mar 30, 2009 | Saeco Royal Professional Espresso Machine
Coffee Grounds
Mar 15, 2008 | Saeco Royal Professional Espresso Machine
DregDrawer full message won't clear
When you need to empty the grounds draw remove the drip tray and pull out the dregs draw - don't open the side panel or turn off the machine, - It works for me!!
Feb 20, 2008 | Saeco Royal Professional Espresso Machine
Saeco Royal Professional Espresso Machine Logo
388 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
Pierre Laplante
espressofixr
Level 1 Expert
Ray Murphy
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
