1986 SONY TRINITRON COLOR TV KV20TS20 having trouble with cable connection
I have a 1986 SONY TRINITRON COLOR TV KV20TS20 that I am having trouble setting up for cable. The cable line is hooked into the TV but I still just get the regular channels and they seem to jump up and down, lots of static.
Help please?
jomaru
  • 337 Answers
SOURCE: Audio has a lot of static
You can possibly diagnose the problem by trying a different speaker,it does not have to be the same shape as the original but it has to have the same amount of resistance (ohms),radio shack might have one that you can try or one from a broken radio ,if you use one with different value it might not sound as loud but we are trying to see if you hear the static or is gone.You need to unplug the unit from the wall,remove the back cover and locate the speaker,disconect the wires and reconect the one to try then plug the set and turn it on,the antenna will need to be reconected too.Is the most simple test you can do without getting in too deep.Let Us know how it goes by a way of a new question or if you need more information.
Posted on Nov 01, 2006
  • 20 Answers
SOURCE: Sony Trinitron Tv
Dear sammy5,
Stop by any TV repair shop in your area, and ask to borrow a used original Sony remote, they may require a small deposit; access the menu, perform your set up, then return it. Or you could buy a universal Sony remote from Walmart that should work just fine, for about. $7.00.
Hope this helps.
Richard
Posted on Nov 08, 2007
salt56
  • 373 Answers
SOURCE: No sound on some channels
Check in the menu to see if the audio is on SAP. If it is change it to Stereo. Hope this helps
Posted on Dec 30, 2007
MikeMaierTV
  • 206 Answers
SOURCE: TV Snow and Static Sound
Sound like its all cabled wrong So its from the source, (wall satalight Whatever ) to VCR in then VCR out to TV, Now when the VCR fires up it tunes the RF output to Chanel 4 and has a strong signal, that over rides just about every thing. Simply way to stop this is one of two ways, press the TV/VCR button on the VCR, or simply turn off the VCR to let the signal pass through.
Posted on Mar 06, 2008
  • 7 Answers
SOURCE: Sony FD Trinitron WEGA KV-24FS120 24" TV Color changes
Try turning down (off) the color during such an episode. If the image is tinted pink or green instead of black and white when you do this,you have either an intermittent short in your CRT (tube), which is terminal,or a gun drive problem, which may be repairable. If you're feeding it component instead of composite signal,it may just be a bad connection of the B-Y cable.
Posted on Mar 19, 2008
What is the code for a 2001 Sony Trinitron?
Search Results
    Sony eSupport - Remote Control Codes & Programming ...
    https://esupport.sony.com/.../select-system.pl?...RCOD...
    Sony CorporationFind the codes you need to program your remote control. ... Television - Accessories; Television - FD Trinitron® & WEGA™; Television - Internet TV & Players ...
    [PDF]Trinitron Color TV - Manuals, Specs & Warranty - Sony
    https://docs.sony.com/release/KV20FV12.PDF Sony CorporationRefer to section 54-300 of Canadian Electrical Code for Antenna Grounding. Lightning .... Congratulations on your purchase of the Sony Trinitron Color TV.
Dec 08, 2015 | Sony Televison & Video
I have a sony trinitron tv and it wont turn on. any clues?
I have a sony trinitron KV-2FS100 and my color is not showing right. I had trouble turning on the tv what is the problem please?
Jan 23, 2010 | Sony Televison & Video
Just hooked up on Sony Trinitron Wii and no color - how to get color
Instead of the 3 color coded cables for AV used the 5 color coded cables that were also included. I figured this out since the manual stated the AV cables were for 480i and the other cables were for 480p TV. I guess our Sony Trinitron was more advanced than I thought even though it is a '99 model. Anyway it works great now!
Dec 26, 2009 | Nintendo Wii Console
Sony kv-36fv27 color is bad.
Know to solders?Resolder ur video board socket holes that connected to( CRT tv Tube).Resolders the Yoke cable red, green,yellow connected to the main board also.Should get colors back,if the colors IC on the video in not dead,and capacitors help the IC on the video board.
Dec 19, 2009 | Sony FD Trinitron WEGA KV-36FV27 36" TV
No Color playing DVD just black & White
Have you tried playing the DVD in PAL60,NTSC 3.35 or alternately select the colour system on the TV manually rather than in auto ?
Aug 25, 2008 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Sony TV KV 27FS 100 Picture in BW when connected to my Laptop.
connect a dvd to the tv using the same cable.
If the color is O.K. then the fault is in the laptop.
Thanks Guy9
Jul 07, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Mar 19, 2008 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Kv36fs13 picture is purple
YOU HAVE SURELY THE CIRCUIT OF RED COLOR MALFUNCTIONING , - I F YOU CAN  YOU HAVE TO CHECK ON THE BOARD CONNECTED TO TRINITRON TUBE THE CIRCUIT  OF RED COLOUR SOMETHING IS TROUBLE -- DELFO
Feb 29, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Have no red color and the other colors seem to be fading on my sony KV36FS13
in that tv you have surely the color circuit trouble - if you can you have to check  the red color circuit , first transistors then voltage or a capacitor not functioning ,
I HOPE THIS MAY HELP YOU - DELFO
Jan 19, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
TV colour problem
how did you explain trouble do you have a problem on tv with color
board ,surely a capacitor has few' capacity' for making the driving on
color that can  be rarely
delfo
Dec 18, 2007 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Televison & Video Logo
307 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
