Philips Wireless Router
Problem seeing wireless router. Sometimes my laptop will see the router and sometimes it wont.
    Sergeant:
  • 349 Answers
Many things can interfere with the signal
  • distance from router
  • brick Walls
  • wireless phones near router
  • aerial loose on router
sometimes, wrapping aluminum foil, around the aerial to make it bigger can help.
good luck
Terry
Posted on Mar 16, 2008
I have F6D4230-4 V3 Enahanced wireless router G. The connection to the internet keeps getting lost and then comes back on. Sometimes I can't get it to connect to my laptop at all, even when the wireless...
1.Log into router. Using either 192.168.0.1 to 192.168.1.1 in a browser window that is ( internet Explorer or Firefox)
2. Verify wireless router name( on the computer) >>> ( on/off) ( router status window)
3.Note router name you are connecting to.
4.. Check the laptop/desktop do ipconfig /all to see current IP addresses.
5. Set the laptop up in the router by WEP KEY or MAC address. This set up in the "security tab" in the router. using 192.168.0.1 or 192.168.1.1 to access through a browser.
6.Note router name you are connecting to.
7. Move the laptop about 20ft away and try to log on to the internet.
This is for all routers to set up wirelessly.
8. check for firmware update at the manufacturers site for your model router
9. cell phones, cordless phones, digital TV's, can affect the data signal from a router. Also distance from the router can be a factor. If your router is in a basement place the router to a upper floor and center it in the room.
Sep 29, 2010 | Belkin (F5D8231-4) Wireless Router...
Have 1 desktop and laptop connected to router ans i bought a new laptop .. and it wont work with my wireless belkin router what am i doing wrong?
check whether driver for wireless is installed properly in the laptop .To check it navigate the device manager and see device wireless is installed.
The wireless may be sometimes disabled ensure it is enabled.
Then try to search for the wireless signal and connect to it.
Ensure correct ip address is received automatically in laptop by using command ipconfig/all in command prompt
check router dhcp address range.
Mar 03, 2010 | Belkin (F5D8231-4) Wireless Router...
Wireless laptop wont pick up wireless at home
Try to improve the wireless range of your router
1.
Position your wireless router in a central location.
Move the router off the floor and away from walls and metal objects. Metal, walls, and floors will interfere with your router's wireless signals. The closer your router is to these obstructions, the worse the interference, and the weaker your signal will be.
2.Change the wireless channel of your router. Sometimes one wireless channel is clearer than others.
a.Open a Web Browser on the computer. In the address bar of the Web Browser type http://192.168.2.1
b.Click Login in the upper right hand corner of the page. The router does not ship with a password, so just click submit
c.Click on Channel and SSID the left hand column under the Wireless heading.
d.Change the wireless channel that your router is broadcasting on.
Note: You don't need to change your computer's configuration, because it'll automatically detect the new channel.
Nov 20, 2009 | Belkin (F5D7230-4) Router (587009)
Acer Wireless Network Card Will Not Connect
Sometimes when you bootup and the error message = "wireless connection has limited or no connection", or has a red X on the wireless icon, it is because the router has not issued an IP address to the wireless card. Right click on the wireless connection and then click Repair.
If this doesn't work then reboot the router then the laptop, this should fix the problem
Sep 02, 2009 | Acer InviLink 802.11b (91.49C10.002)...
I have a balance 557s laptop that the wireless wont work it shows the icon with a red x wont turn on when you push the wireless button
Sometimes when you get a red x against the wireless icon, it means the wireless card did not get an IP address from the wireless router or the router needs resetting.
To get the router to issue a new IP address to the laptop, right click on the wireless icon and click on Repair.
If this doesn't work, power off thr router for 30 secs and power up the router, wait till the LEDs on the router are on then boot up the laptop or do a Repair on the wireless icon.
Aug 27, 2009 | Computers & Internet
Router randomly stops sending out wireless signal
You may be getting interference from other routers in your area.
Check to see what channels the other routers are broadcasting in your area, change it to a channel that is not being used.
The location of the router could affect the signal strength, move the router away from concrete reinforced walls etc, and or move the router to a higher position in a clear space.
May 22, 2009 | D-Link DI 514 Wireless Router (DI-514)
Can't turn on wireless on computer
which toshiba satellite pro ?
is wireless on at the laptop?
sometimes a combination: Button FN & F1-F12
try to connect router via ethernetcable:
inside routerconfiguration enable wlan
sometimes routers have a switch outside to enable/disable Wlan
is there a WLAN-LED at the router?
May 05, 2009 | Computers & Internet
Cant see my wireless network on my laptop
You need to start by checking two things:
1. Is the wireless nic on the laptop turned on? Sometimes there is a switch or button on the laptop casing that turns the wireless nic on and off. Also you can sometimes turn the wireless nic on and off via a key combination on the keyboard. If you're sure it's turned on, take it to a wireless hot spot to verify that it is in fact picking up wireless networks in the area.
2. Did you connect to the wireless router using an ethernet cable, log into the routers configuration interface, and verify that the wireless access point is in fact turned on?
If the above does not lead you to a solution please answer the questions in this thread so that we can continue.
Jan 16, 2009 | Linksys Wireless-G WRT54G Router
F5D7230-4 wired laptop wont connect
It is not a router configuration problem its a laptop problem in the configuration. Do you have the network card installed if so try a reinstall. if not go to your network wizard and set it back up .
Oct 07, 2008 | Belkin (F5D7230-4) Router (587009)
Computers & Internet Logo
David Payne
David Payne
