Washer will fill and run but will not drain or spin.whirlpool estate stock# taws690a mod.# taws690ano ser.#cc4621151
    Guru:
  • 1,894 Answers
Could be a bad motor, or something stuck in between the tubs, like a nail, wash cloth, sock.
Try to turn the belt both ways with no power on, unplug the machine, before you start. Take the Belt off, then turn the motor pulley , then turn the transmission both ways. All should turn freely.
On this model i believe you can just tilt the machine back to do all this.
Posted on Mar 15, 2008
  • dewan nafees ahmed Mar 16, 2008
    sounds like the motor control board is bad. you could test the motor to
    see if it ohms out ok, the diagram has the readings. The diagram should
    be on the side panel (inside the cabinet) on the lt side in a brown
    envelope.
    else
    • Washer will not drain or spin, but
      does agitate
    -Test lid switch
    -Test water level switch
    -Test pump
    -Test drain hose
Whirlpool type 107
Sounds like the clutch may be slipping. Does it go into a high speed spin?
Aug 18, 2013 | Washing Machines
My whirlpool Estate washer is not draining or spinning but aggitates, what can be the problem?
Sounds like a cycle switch problem. The switch is not turning and making contact with the next cycle. It needs to be changed!
Jan 09, 2013 | Whirlpool Washing Machines
Estate washer will fill up but want drain spin, or agitate
sounds like pump is working but not transmission... check under washer for plastic shavings, lovejoy coupling might have disentergrated, VERY cheap fix if done yourself.
Apr 16, 2012 | Whirlpool Kitchen Appliances - Others
Our whirlpool washers agitator doesn't agitate during the spin or wash cycles
I would asume you mean it does not adjatate during the wash or rinse cycles.If it fills and you can here the motor run after it fills/then it drains and does not spin and fills again for the rinse but does not adjatate ? I would guess you have a broken motor coupler ..Most shops will do that repair for under 100.00....If I had more info I could be more sure...anyhow if more info is needed just repost....I hope I help you if I did please give a vote...thank you good luck
P.S mod # helps so much
Feb 02, 2011 | Whirlpool Washing Machines
Kenmore washer MOD 110.24422300 SER CP4427442 the washer wont spin, it makes a harsh and loud noise when it comes onto the spin cycle.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Oct 20, 2010 | Kenmore 12502 Top Load Washer
Washer keeps filling w/ water, only stops when changed to spin
Your drain line is too low.
OR the drain line is restricting air where it enters the drain stand pipe.
Remove the drain line and hold it up high.
Turn the washer on to fill. It should fill then stop.
This example should explain what you must do to correct the drain line problem.
Mar 12, 2009 | Whirlpool Washing Machines
Estate washer won't spin
If it still agitates and fills, this is most likely due to a faulty lid switch.
Oct 12, 2008 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Final spin cycle
Lots of possibilities to check out before considering a problem with the machine: Is the load unsorted, too big or off balance? Drain restricted or too high? Oversudsed? Water draining completely out before going into spin?
Jan 08, 2008 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Washing Machines Logo
162 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
