Can not get sound. speakers are pulged in - Computers & Internet
    Sergeant:
  • 349 Answers
Check that the sound is not muted
ensure speakers are plugged into the green socket
you may need to re install the driver for the sound card,or sound chip on motherboard, if so search on google with something like this sound driver for "insert sound card brand & model, or motherboard here).
good luck
Terry
Posted on Mar 16, 2008
When I play videos the sound from the monitor is fine. However, the auxillary jack in the back of the monitor makes static when I pulg in the outside speakers, but their is no sound from the video. I...
The auxiliary connector could be an input as your Polaroid monitor instructions would indicate. There may be no provision for external speaker connection.
Nov 26, 2013 | Polaroid 15'' HDTV Monitor FLM-1511
I unplugged my sound system to re-arrange the living room and when I plugged it all back in it just wouldn't turn on at all. no lights, no nothing. I tried it in 3 different outlets and then in an...
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or uninstall
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
make sure you have an earth ******** before touching any parts inside your computer
hope this helps
May 31, 2011 | Logitech X-540 Computer Speakers
I plugged my speakers in and I can't here anything..they have been working fine until now..;>!
Check Your sound drivers and also check the jack in which u plugged your speakers pulg it in the audio jack
If the sound drivers are missing then download it
thanks
May 17, 2010 | Computers & Internet
Sp5 peavey stop working it is getting the signal and you can pulg another speaker in the normal port and the other speaker works
The "in" and "out" jacks on the speaker are connected in parallel, so the fact that the other speaker works really doesn't tell us much. If you are not getting any sound at all from either the woofer or the horn, than the internal crossover is probably the defective part. The easiest way to hunt this down is to remove the rear plate that has the connectors on it and try each speaker directly,. Assuming that each speaker works, replace the crossover. Parts should be availabel from, Peavey directly. Call them and speak to the service parts department.
Dan
Oct 03, 2009 | Peavey Music
No sound coming through the handset, but phone works otherwise
The port might be bad that the curly cord pulgs into.
Sep 30, 2009 | Avaya 700340193 Corded Phone
I have a acustimass 9 system , but i dont kno whow to plug it
The plug design they use is proprietary. So you would have to cut off the plug and connect your own jack to the wiring to be able to use it elsewhere.
Jun 18, 2009 | Bose Cinemate Digital Home Theater System...
Saund problem
update your BIOS and Sound card from HP
there might be Bios Update or Sound Card driver...check the version
Good luck
Mar 13, 2009 | HP Pavilion dv9000z Notebook
My speakers are broken and im not sure why?
u have to go to the control panel there u find the audio settings and give necessary adjustments there .
Dec 09, 2008 | Dell AS500 Sound Bar Computer Speakers
Sc-pt660 panasonic home theater system
If you press the Dolby PL button which is next to the functions button you should get your surround sound.
Nov 30, 2008 | Panasonic Home Theater System System
Dell speakers
Make sure you plug the 1/8 connector to the Green port on the sound card or on the system board in the rear. If this is a laptop connection the one with the headphone jack will do it. Now if you don't hear sound then the sound driver might be disable or not installed. You just need to go to where your system was made by to fix that problem. Just download the correct sound card using the make and model number.
Jul 29, 2008 | Dell HK395 Computer Speakers
Computers & Internet Logo
60 people viewed this question
Alun Cox
David Payne
David Payne
