Every time I print a page I get a fuser error report
    Guru:
  • 1,894 Answers
Have you tried by replacing the fuse??
Posted on Mar 15, 2008
  • dewan nafees ahmed Mar 16, 2008
    I truly believe that you did not take the fuser out. It is not a simple process and is not readily accessible.
    You most likely took out the toner cartridge, which works with the fuser.
    The fuser is what "fuses" the toner to the paper so the documents print
    as expected. There are fuser kits that can be purchased, and they
    usually come with some decent instructions.
    in case of new printer
    A fuser problem is serious but if it is is a new printer, use the
    warranty now. Don't play with it as more than likely you can't recover
    and you *MAY VOID* the warranty in any attempts, so use the warranty.
    You should have returned it immediately once the problem cropped-up to
    be within the quicker satisfaction settlement period, you may now have
    to deal with a warranty center if not the vendor themselves for repair,
    but start the process. Plus, document this as well, cal,s letters, etc.
    to best serve yourself if any other problems arise.
    To explain what the fuser is, one must explain what the fuser does.
    A laser printer works by assembling the page in its memory, then
    transfers that "image" by scanning a drum. The drum then picks up a
    charge which will attract the toner. By varying the laser you can
    induce specific dots, creating an image on the drum. The drum is
    rotated through the toner, the charge then attracts the oppositely
    charged toner particles (the uncharged sections don't have anything)
    The drum, now dark with toner, is touched to the paper, which has an
    opposite charge, thus transfer all the toner over to the paper. Then
    the paper is sent THROUGH the fuser, which basically MELTS the toner
    onto the paper permanently.
    If the fuser is too hot, that means the temp control unit for the
    printer fuser has FAILED, and that is NOT something you can fix by
    yourself. The labor will likely cost more than the printer unless it's
    under warranty.
    You took out the toner cartridge, which is NOT the fuser. Toner
    cartridge is just the toner and the drum together in one unit. The
    fuser is where it warns "high temp! do not touch!"
    Just buy another printer or use the backup printer. Again, this is NOT something you can fix by yourself.
    Sergeant:
  • 406 Answers
Hi let me know which is the brand of your printer, Iam online now I will assist you esactly
  • 1 more comment
  • Rafique Mannasaheb Mar 15, 2008
    HP Samsung Dell Lexmark ETC
    Does your print are perfect before or the toner was volatile and can be removed by hand
    If the fuser is having an error remove fuser unit may be some paper Jam Or contact points are having a problem.
    If Its not getting heated up let me know
Why does my Konica Minolta 1690MF have a fuser jam error whenever I print in color?
Everything you checked sound good. Might be printer software problem, and needs to be re-flashed. Software only available from secure web site that a technician would have, see what it cost if to much buy a new one with extra bells and whistles !
Jun 18, 2014 | Konica Minolta magicolor 1690MF All-In-One...
How do I print a single call report for a FAX previously sent
Printing a fax call report
A fax call report is a brief report that indicates the status of the last fax that was sent or received.
To print a fax call report
1. On the all-in-one control panel, press Menu.
2. Use the < or the > button to select Reports, and then press .
3. Use the < or the > button to select Fax Call report, and then press .
4. Press to select Print report now. The all-in-one exits the menu settings and prints the report.
NOTE To set the fax call report to print automatically, see Setting print times for the fax call
report.
Setting print times for the fax call report
You can set the all-in-one to print a fax call report after any of the following events:
? Every fax error (the factory-set default)
? Send fax error
? Receive fax error
? Every fax
? Send fax only
? Never
NOTE If you select Never, you will have no indication that a fax failed to be transmitted
unless you print a fax activity log.
To set the print times for the fax call report
Use the following steps to set when the fax call report is printed:
4. Press the > button once to select Print report, and then press .
5. Use the < or the > button to select the option for when you want the fax call reports to be printed.
6. Press to save your selection.
The following print-time options are available:
Including the first page of each fax on the fax call report
If this option is turned on and the page image still exists in the all-in-one memory, the fax call report
includes a thumbnail (50% reduction) of the first page of the most recent fax that was sent or
received. The factory-set default for this option is On.
To include the first page of each fax on the fax call report
Use the following steps to include the first page of each fax on the fax call report:
4. Use the < or the > button to select Include 1st page, and then press .
5. Use the < or the > button to select On or Off, and then press to confirm your selection.
Jul 06, 2011 | HP LaserJet 3050 All-In-One Printer
How to stop to print the journal after send fax everytime?
Sending Confirmation
This report shows the fax number, the number of pages, elapsed time of
the operation, the communication mode, and the communication results.
You can set up your machine to print the message confirmation report in
one of the following ways (see page 5.3):
• Automatically after each transmission (ON)
• Automatically only if an error occurs during transmission (ERR)
• No report printed at all (OFF). You can print this report manually at
any time you want.
SENDING CONFIRM - A confirmation report shows whether the
transmission was successful or not, how many pages were sent, etc.
Select ON to print a confirmation report automatically each time you
send a fax.
Select OFF to turn this feature off.
Select ERROR to print only when an error occurs and the transmission
was not successful.
Nov 27, 2010 | Samsung SF-5100 Plain Paper Laser Fax
My HP 1040 fax prints a sending confirm notice after every fax is sent. Is there a way to turn this feature off as it is a major waste of paper.
Reports you can print
You can print these reports whenever you need to. Some of these reports can be set to print automatically also.
1. Press Report/Help.
2. Choose the report you want by using left or right arrow.
3. Press Start/Enter when the desired report is displayed.
4. The selected report will be printed.
Sending Confirm
A confirmation report shows whether the transmission was successful or not,
ON: prints a confirmation report automatically each time you send a fax.
OFF: never prints a confirmation report (You can print one manually using the
Report/Help button (see Print reports on page 51).
ERROR: prints only when an error occurs.
Nov 25, 2010 | HP 1040 Plain Paper Inkjet Fax
For some time now there is a black line down the right hand side of the page. I suspect there is dirt on something, but have no access to the inside of the machine. Yesterday there were a few copies that...
This is almost for sure going to be a fuser fixing sleeve defect. I just repaired one of these the other day. An easy way to tell for sure is to print a page, and pull out the power cord when the page is halfway through the printer. Open the back and pull out the paper. More than likely you will see the defect on the portion of the page that has gone through the fuser (directly behind where the paper comes out, but not on the part that hasn't. This can be a reliable repair if done by an experienced tech. I usually charge $75 to do this on this model. Make sure if you get the repair done that the tech uses only a brand name fuser sleeve. If you are in the sacramento, ca area, I can repair it for you.
Sep 29, 2010 | HP LaserJet 3050 All-In-One Printer
How to find number of pages printed from a brother HL 5250N
Turn on the printer.
Once it is on and the status light is on, press the Go button 6 time. Status light turns yellow and printer will print off internal configuration - including number of pages printed. Should be 3 pages. This report also includes the percentage used of toner, drum, laser, and fuser.
Dennis
Jan 27, 2010 | Brother HL 5250DN Laser Printer
922 Server fuser error
922 fuser errors is a bad fuser - you might try turning off printer - holding the select and return button down at the same time - turn on printer - HOLD buttons until it starts inting (about 15 sec) and the arrow over to print test pages - if the error doesn't return - repeat a few times.... this may by pass the error.. then power off - ON and see if problem is gone. replace fuser if not
Apr 08, 2009 | IBM Infoprint 1120 Laser Printer
HP Colour Laserjet 3550 printing problems
I can tell you that it is NOT the Fuser unit. I would change the drum unit first. This would be the most likely cause.
Mar 11, 2009 | HP Color LaserJet 3500 Printer
Confirmation page
You can configure your HP all-in-one so that it automatically prints error and confirmation reports. If you need printed confirmation each time a fax is sent, follow these instructions before sending any faxes and select Send Only. To set automated report options from the control panel Press Setup. Press 2, and then press 1. This selects Print Report and then selects Fax Report Setup. clip_image001.gif Press to scroll through the following report types: Every Error: prints whenever there is any kind of fax error (default). Send Error: prints whenever there is a transmission error. Receive Error: prints whenever there is a receiving error. Every Fax: confirms every time a fax is sent or received. Send Only: prints every time a fax is sent indicating whether the fax was successfully sent or not. Off: does not print any error or confirmation reports. Press OK to select the report.
Jul 29, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Double page copies and CRU Error
CRU Fuse error equates to a problem the machine has reading the print cartridge installed in the machine. It has nothing to do with the fuser.
Suggest that you change the print cartridge.
Oct 01, 2007 | Samsung SF 5100 Laser Printer
Computers & Internet Logo
35 people viewed this question
David Payne
David Payne
