Question about Miele Dishwashers
Miele Dishwasher door release problem
We have just run for the 1st time our brand new Miele G2872 dishwasher.
At the end of the programme the door opened slightly, held open by a plastic arm.
The arm though appears stuck and we can now neither open fully or close the door.
Do you have any suggestions?
I switched the dishwasher off at the mains and then back on again. At this point the plastic arm started making a noise like it was trying to retract so I pulled the door to help it along. The door opened and the arm fully retracted - much to my relief.
Posted on Mar 16, 2008
I have a whirlpool gu2400 dishwasher. The spring loaded soap dispenser door does not open during the wash cycle to release the soap.
Whirlpool dishwashers use a wax motor or a solinoid to release the door at a specific time during the cycle. So for proper cleaning the soap cup is nessesary . The part isn't that expensive and fairly simple repair.
Dec 30, 2014 | Whirlpool GU2400XTP Built-in Dishwasher
I need manual for Bompani Dishwasher BIDI60FSS Please as I cannot open my brand new dishwasher as I cannot release the door lock?
some dishwashers require the door release to be held for a period of time. This is a child safety feature
May 04, 2014 | Dishwashers
Fan not stopping on miele dishwasher G2872 SCVi
This one is supposed to make coffe not wash dishes .
Oct 26, 2013 | Miele Coffee Makers & Espresso Machines
Can I turn the beeper off on the end of the washcycle on the DDY062 Hoover dishwasher. I want to put it on timer delay and dont want to be woken in the middle of the night.
These are the instructions taken directly from the DDY062 manual:
Alarm mute for the PROGRAMME END
The alarm for the programme end may be muted as follows:
IMPORTANT The dishwasher must be ALWAYS off before start this procedure.
1. Hold down the "PROGRAMME SELECTION" button and at the same time switch on the dishwasher by pressing the "ON/OFF" button (a brief audible signal will sound).
2. Keep the "PROGRAMME SELECTION" button pressed for at least 15 seconds (during this time, 2 audible signals will sound).
3. Release the button when the second audible signal sounds (3 "PROGRAMME SELECTION" indicator lights will come on).
4. Press the same button again: the 3 indicator lights (which indicate that the alarm is activated) will start flashing (to indicate that the alarm is off).
5. Turn off the dishwasher by pressing the "ON/OFF" button to confirm the new setting.
To turn the alarm on again, follow the same procedure.
Jun 21, 2012 | Hoover Dishwashers
My brand new Miele dishwasher door wont saty down when loading and unloading - tonight was the last straw as it shot up and has really hurt my forearm!!! Please tell me what I can do to sort this out =...
you can tension the door springs or release tension by a screw at the top ....you will have to look for it check the book for directions....you probably have a model made for a door panel to be fitted and dont have the panel fitted yet...
Feb 10, 2011 | Miele Inspira G2140 Dishwasher
Our Miele dishwasher has started to make a noise when the drying cycle starts, 25 mins from the end of the programme. Sounds like a the fan bearing or, because it's pretty new, maybe it's obstructed or...
And do you get a pool of water on the floor when you open the door and the fan drains out? If so, then you have the Miele problem.
This happens every year or two. Take off the outside front panel to access the hose that runs from the bottom of the fan down to the dispenser, and lets the water drain out through it to the interior. Clean out that hose as well as you can. Replace. This is a stupid problem that Miele should have a permanent fix for. Grrrr.
In fact I just did this with mine today. The hose cleans out quickly, the problem is getting the front back on. 4 hands make it easier. It slips on when you start close to vertical, then slip in in and down. For putting the screws back in, you might have to use a micro screwdriver to re-align the little clips on the door panel. (You will see what I mean when you do it!) This costs a service call ($100, give or take) to call for service. It can be done at home with no added parts. I think it applies to all Miele dishwashers, and I have now done it several times. As I said before, this is a design fault and should not be necessary!
PS: I still have the puddle on the floor, so am trying again only 3 days later! But this has worked before.
Nov 27, 2010 | Miele 24 in. G646SC Plus Free-Standing...
23 in. Novotronic G841 Built-In Dishwasher: the door on my miele G481 built in dishwasher won'...
hi,
you need to adjust the door tension springs which is by a screw each side of the hinges on the plinth of the unit at the front. There is a symbol of a spring to show you which screws to release. do them evenly and the door will not spring up,
May 18, 2010 | Miele 23 in. Novotronic G841 Built-In...
Dishwasher will not start
Check the drain pan area under the dishwasher, if it full of water it will trip a float switch and run the drain pump until the water evaporates or is removed by a shop vac.
Oct 03, 2006 | Miele 24 in. G638 Plus Free-standing...
Dishwashers Logo
991 people viewed this question
Top Miele Dishwashers Experts
mpservices
Craig Butler
Craig Butler
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
