Question about Thomson 28VK25US TV
TV Thomson Scenium 28WF64E L
Every few minutes "menu" appears on a screen.
Remote controler is not in used (without battery inside).
I have allready replaced processor ST90R92 (IR001 on the diagram) but the problem is still the same.
  • Tadekpl Mar 15, 2008
    I am not an expert in english abbraviations. What does it mean "PCB".
    Sergeant:
  • 406 Answers
See that any of the buttons are pressed or any thing is shorting any of the switches or wires or PCB in your Television
Posted on Mar 15, 2008
LG 47LG50 Program Menu displays on its own without remote control or manual inputs.
Thats the IR board. You can get the IR board along with the button assembly at the following link for your model its 15.00 just scroll down the page. It also may be the main board that has the issue if it is you can also get the main board there also its 84.00
http://tvrepairworld.com/lg__zenith_lcd__plasma_power_supply_boards
Dec 16, 2012 | LG Televison & Video
Philips 42pf7320a37 Plasma TV. Menu appears without being requested remotely or manually. Must select Menu Remotely (or manually) to regain screen. Screen stays on for a few seconds or up to 20...
Check that this is not caused from a stuck button, or a defective remote recalling the menu.
If it is not the remote, then you will probably need to replace the control board or the button assembly.
Nov 01, 2008 | Philips Televison & Video
Flat Screen 42 inch Vizio does not respond to the remote, called Vizio tech told me to take out batteries and push every button, replace batteries and try. Worked for 3 minutes then stopped again,Replaced...
You can use your phone camera to test the remote. Place the remote to the camera and push to see the IR on the camera. If this works for more than 3 minutes then the IR detector or the processor circuit in the main board is faulty.
This means you need to remove the main panel and use a multimeter to test when the remote is used, trace and see if the fault leads further to the processor.
Jul 18, 2011 | Televison & Video
I have a olympus digital camera stylus 7040 .. i use it but i few minutes later it appears with the line on the screen ..what solution can you give me ? and where is the problem of my olympus camera?thanks...
When the line appears.. Press the menu button. If the line is still there, then the processor for the screen may be going bad. If not, then camera needs to be reset by leaving battery out for about 48 hours... this will reset all the processors. But it does sound like something internal.
Jun 28, 2011 | Olympus Stylus 710 Digital Camera
Can't seem to switch to input with the remote or go to any channel to use my DVD player
Hello
Check first if the Remote Control hanset emits infrared rays or not. Infrared rays are invisioblw to us. There is an easy way to check it. if you have a cellphone with camera option, set it to camera mode, and place the remote hanset against its lens about 1 feet away or so, and press each button on the remote control. You can see the infrared indication on the screen of your cellphone.
If it is Ok, just reset the remote control.
You might need to reset the remote: remove batteries and press the number 1 button for at least 60
seconds. Release the 1 button, replace the batteries, and (if necessary) program the remote again.
Check also for
Something might be between the remote and the remote sensor on the component. Make sure there is a
clear path.
• Maybe the remote isn't aimed directly at the component (DVD, TV, VCR) that you're trying to operate.
• Maybe remote is not in TV Mode. Press the TV button so remote will control TV.
• Maybe batteries in remote are weak, dead, or installed incorrectly. Put new batteries in the remote. (Note,
if you remove the batteries, you may have to reprogram the remote to operate other components.)
How to Use the Remote Control to Complete
the Initial Setup
The technical term is "Navigation"- how you move through the
on-screen menus. The method is the same throughout the menu
screens: highlight your choice and select it.
To highlight a menu item, press the arrow buttons on the remote
to highlight one of the items listed on the screen. Use the up or
down arrow button to move up or down. Use the right or left
arrow button to move right or left.
To select the item that you've highlighted, press OK.
Note: Highlighted means that the menu item stands out from other
menu items on the list (appears darker, brighter, or a different color).
Turn on the TV
Press TV on the remote, or press POWER on the TV's front panel.
Note: Pressing the TV button not only turns on the TV, but puts the remote
into TV mode. "TV mode" means that the buttons on the remote control
operate the TV's functions.
Complete the Initial Setup
The menu system in your TV allows the TV's features to work
properly. The first time you turn on your TV, the SETUP screen
appears with Language highlighted. The default language is
English. To choose another language, press the right arrow
button on the remote.
If these doesn't work, the infrared sensor inside your Tv has got damaged and should be replaced. OK.
Nov 29, 2010 | RCA 27R410T 27" TV
Cant change ''favourite'' channels or get ''menu''
Make sure the batteries are fresh in the remote control ( I am assuming you are using a remote control to access the on screen display) If you have a universal remote and replaced the batteries you most likely will have to enter the code for the specific TV that you have.
Jun 14, 2009 | Televison & Video
New batteries, remote works for a few, then starts beeping
update your software, then update your firmware to the remote. have it connected without batteries and then when prompted to connect the remote, add your batteries and see if the software will connect and update. Good luck.
Jan 07, 2009 | Logitech Harmony 520 LCD Remote Control
Menu rca hd52w59
i have seen this problem at the shop. a few times the front panel has become damaged. replaceing this has resolved it for me
Apr 04, 2008 | RCA HD52W59 HDTV Projection Television
Crazy menu, comes on periodically without using remote
believe it or noT: try replacing all of the switches on the control panel (((power button switch,menu button switch, etc...)))
Oct 27, 2006 | RCA HD52W56 52" Rear Projection HDTV
Screen problem
check captions on your menu settings it has caption 1 and 2 if it is not set on caption it could be on text which cause the black box to come on the screen turn off every thing on the caption menu.if that does not work then take you set to a tech to have it reset then it could be your eprom or your video circuit.good luck.
Aug 28, 2006 | Samsung TXK2754 27" TV
Televison & Video Logo
369 people viewed this question
Top Thomson Televison & Video Experts
Are you a Thomson Televison and Video Expert? Answer questions, earn points and help others
