Question about Goldstar MV-1526 Microwave Oven
No power while cleaning my over the range goldstar microwave underneath with a damp cloth it flashed a bright light and then everything stopped working. any suggestions? its about 5 years old
  • Goldstar Master
  • 9,174 Answers
I would say a cooktop lamp got shorted by the moisture.
Assuming your circuit breaker is good, the main problem would probably be a blown 15A or 20A ceramic fuse inside the unit.
Once that's replaced, if the hood lights and /or exhaust fan still don't work, then your control panel would need to be repaired, which we do for $39.95 nationwide.
If you or someone you know decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
If and when you remove or install cooktop lamps, the power to the oven must be unplugged or turned off at the breaker.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Mar 16, 2008
SOURCE:
Frigidaire microwave model ffmv164lsa constant beeping, with little symbol to the top left hand side of the clock displaying with the beep.
Hopefully no one sprayed a liquid cleaner directly onto or near the keypad...
From page 23 of the owner's manual:
"Wipe the microwave oven inside and out with a soft cloth and and warm (not hot) mild detergent solution. Then rinse and wipe completely dry."
"Clean the outside surface of the microwave with soap and a clean damp cloth. Dry with a clean soft cloth. To prevent damage to the operating parts of the oven, do not let water seep into any vents or openings."
If there is moisture damage, it may dry out by itself if you leave it overnight with the door open. If not, the warranty would be voided and you'd have to arrange for out of warranty service.
If there is no moisture damage, and it failed not due to outside forces, then you should contact the manufacturer to arrange warranty service.
Oct 05, 2016 | Frigidaire Over-the-Range Microwave
We have a Goldstar mv1310w microwave that the lights have quit working on. This is the light over the range that you can turn on while cooking on the stove. We put new bulbs in and I even show voltage on...
mcdevito75 here, It could be the light sockets are dirty from cooking fumes, oil etc, remove power from the sockets and clean them with alcholol and cotton swabs or paper towels etc.
Jun 28, 2010 | Goldstar MV-1310W/B Microwave Oven
I have a Sharp Carousel over the range microwave model R -1601. I cleaned it and now it sparks when we try to use it. What can I do to fix this problem?
The cleaning operation may have spread metal particles or other conductive materials on the walls/floor of the cooking cavity. Try wiping the entire cavity with a damp, clean cloth, then heat a cup of water for a test. Hope this helps!
May 24, 2010 | Microwave Ovens
Over the Counter Goldstar MV1501 1500 watt microwave tried to change the range light. As bulb was being unscrewed I heard a pop and felt a slight shock, now microwave has no power. Outlet does have...
You can download the service / repair manual here.
Most computers will open the manual automatically, but you may need the free Adobe Reader.
It will give you safety info, step by step help in disassembly, troubleshooting tips, and reference numbers. Unfortunately it does not give you part numbers for some reason...
You can find & order parts from Encompass here or you can call them toll-free at 866-779-5835.
I would first check the fuse and oven thermostat.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Accessing some components (especially the oven cavity thermostat) for testing and possible replacement will require you to remove the oven from the wall and take off the outer cover.
If so, the installation instructions here are very handy, and it's best to have two people since the microwave can be heavy and awkward.
Once the fuse and oven thermostat are known good and the microwave functions, if the lights / fan still won't work or won't shut off, then you have a problem with the control board.
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week or so.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
The lights can can be inoperable or stuck on or no bright, too. Sometimes this will similarly affect the exhaust fan operation or inside light, too.
You should check your light sockets for a short, too.
Jun 27, 2009 | Goldstar MV-1501 Microwave Oven
Sharp R-510 FK dangerous noise
Hello. To me, it sounds like something is stuck to the inside of your cavity and it is arcing, as you are seeing a bright flash, and hearing it. I would take apart/clean everything inside the cooking area, something is causing a problem in there. Usually just a good cleaning is all it needs, as the debris is making a focus point for the energy. Try putting a small glass of water, only 1/4 full, and watch while you start it, to see where the arcing is, it won't hurt anything for a second or 10.
Hope that helped, and thank you.
Mar 29, 2009 | Sharp R-510HW Microwave Oven
Goldstar MIcrowave stopped working when light bulb blew out.
when that happen to me i change the bulb and the fuse in of the microwave f the don't work send it to the company that made it and they should tell what wrong.
Mar 11, 2009 | Goldstar MV-1501 Microwave Oven
Goldstar
We regularly repair these control units for customers nationwide by mail for $39.95 postpaid in about a week with a one-year guarantee.
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
William E. Miller
[email protected]
http://www.microwavedisplay.com
Nov 27, 2008 | Microwave Ovens
Goldstar MV154SJ Over the range Microwave oven
check the touch pad , and check the control panel...
Sep 23, 2007 | Goldstar MV-1501 Microwave Oven
Hood lights
first remove mains cord from main power. and remove the microwave oven top cover and check the bulb and crefully remove the old bulb and put new bulb. at high voltagae section dont touch any thing ,that area very dangerous ,thats why very carefully work inside the microwave oven ..
Sep 09, 2007 | Goldstar MV-1320W/B Microwave Oven
Goldstar MV-1526 Microwave Oven Logo
124 people viewed this question
Top Goldstar Microwave Ovens Experts
William Miller
William Miller
Mike
Gerry Harvey
Gerry Harvey
Are you a Goldstar Microwave Oven Expert? Answer questions, earn points and help others
