Question about Orite VC2110 Digital Camera
Orite camcorder hey there I have got a an orite camcorder but it came with a foreign charger I got an adapter & that didn't work. I was told it would charge from the usb pc cable but that wouldn't work either I now have a USB charger for my phone & I have tryed that but it won't work either I have taken the battery in & out & stuff this is a brand new camera & the people I bought it off are useless
  • Orite Master
  • 5,412 Answers
Return it for a refund - we cannot help with either incompatible equipment or your understandable frustration.
Posted on Aug 03, 2017
2 Suggested Answers
  • 2386 Answers
SOURCE: Pls Driver Required ORITE PC 2008M USB PLUG or
this device is made by orite using VMICRO ZC0301PL micro chip and the dirver of this chip will do the rest go and download it from
http://cr.am/framed.php?url=http://www.vimicro.com/english/product/PublicDriver/WIN/DRV_ZC0301PL_070404.zip&ref=driverguide
good luck
Posted on Dec 04, 2010
When I connect the battery charger to the camcorder it doesnt even even show that I have the battery charger hooked up nor does it charge the camera. Could that be a problem with the camera or the charger?
I got hold of Canon support. I had the same problem. Got a new battery, fully charged and would not run the unit. Canon told me to do a system reset. pull out main battery and aux battery (bottom of unit) and to power switch to aux for 90 seconds. the put batteries back and it should work. Hope this helps.
Nov 05, 2010 | Canon ES50 8mm Camcorder
Hey i had my dell inspiron 1525 for quite a while and now the charger stopped working for some reason. i need help
The charging circuit requires an ac adapter with an intact sensing pin in the center of the Adapter barrel plug that connects to the computer. If the pin is bent or broken, the charger is disabled.
If possible, try a known good adapter from another D or E Series Dell Portable. If a KG adapter charges the battery, replace the adapter. If it makes no difference, then replace the motherboard
Jan 22, 2010 | Dell Inspiron 1525 Notebook
My hitachi camcorder says I need an AC adapter/charger
Hi Riannasmail,
You need a camcorder to charger DC cable,it looks like a battery with a trailing cable that has a DC plug on the end that plugs into the Hitachi battery charger.If you are in the USA you should be able to buy one for about $8 to $12,if you live in UK you will be ripped off at about £24.
I made my own adaptor and charger system for less than £20,If you need more info please contact me.
Oct 14, 2009 | Hitachi DZ-MV750MA DVD Camcorder
How to charge a EFORCE FH50 Compatible Battery
Its appealing simple; Probably you will be accepting sony handcam charger accepting a cable thats declared to fit into ur camcorder and again allegation the battery. For charging the EFORCE FH50 battery, you just allegation to admit that the of the aforementioned cable anon into the battery(DC-IN slot) and bung ur charger into the bank socket. It commonly takes 135 mins to absolutely allegation the battery. Once answerable the LED at tthe DC-IN aperture will about-face off. (During charging its yellow)3_27_2012_9_39_48_am.gif
Apr 05, 2009 | Sony Handycam HDR-CX12 Flash Media...
My jvc camcorder GZ-MG37U will not charge
Camcorder has charging circuit but it could go defective. The repair would be costly so in this situation, you can purchase stand-along battery charger for around $20 and charge the batteries independently. Make sure all the contacts are cleaned and camcorder is working with direct ac adapter. Good luck -James. for furnter assistance by email, go to www.camerarepairjapan.com
Feb 11, 2009 | Canon XL2 Mini DV Digital Camcorder
Sharp view cam
This style camcorder has an adapter that feeds off of the battery charger...the charger plugs into the wall on top of the charger you place the battery and if you look on the front of the charger you will/should have an outlet that looks like two holes. This charger should have come with an adapter that looks like the battery only it is attached to a cord. You should than be able to open the battery compartment and insert the corded (battery) and presto it works...if you do not have one you can contact Sharpusa.com
May 29, 2008 | Video Cameras
How to find replacement adapter for GR-D70AS
Order the original adapter from JVC. The adapter supplies the correct current requirements to operate the battery charge circuit. JVC's web site is JVC.COM. The correct charger will provide up to 1.5 amperes of current for the charge circuit at approx. 11 volts DC. Good Luck Joe Weibel Custom Electronics (customelectronics.org)
Feb 10, 2007 | JVC Cybercam GR-D70 Mini DV Digital...
Charging battaries oversea.
The battery chargers that are included with JVC camcorders sold in the U.S. are designed to operate on power from 110 to 240 Volts at 50 or 60 Cycles AC. All that is needed to use the battery charger overseas is a plug adapter to connect into a foreign electrical outlet. These are generally available from a store which carries electrical supplies.
Sep 05, 2005 | JVC Cybercam GR-D200US Mini DV Digital...
I can't charge the battary.
Disconnect DC power cable from AC adapter/charger. Battery charging will not be possible if the DC power cable is left connected to the AC adapter/charger.
Sep 05, 2005 | Hitachi DZ-GX20A DVD Camcorder
Overseas Use
If this is true, then why does the manual for my new PowerShot SD1100 IS say, "Do not connect compact power adapters or battery chargers to devices such as electrical transformers for foreign travel because it may lead to malfunctions, excessive heat generation, fire, electric shock or injury."
Is this just a standard disclaimer in case something weird happens by using a transformer to charge the battery?
Aug 31, 2005 | Canon PowerShot S20 Digital Camera
Orite VC2110 Digital Camera Logo
79 people viewed this question
Top Orite Cameras Experts
Computer Links
Nathaniel Berrios
Nathaniel Berrios
Tony Parsons
Tony Parsons
Are you an Orite Camera Expert? Answer questions, earn points and help others
