FixYa.com
Tags:
NEC 20GB 5400 RPM NOTEBOOK HARD DRIVE KIT FOR VERSA 2600 SERIES
VA6 motherboard won't start up
By herself - usenet poster
I just build a system for a client and its giving me trouble.
specs...
ABIT VA6 mb
Celeron 500
1 x 128mb SDRAM PC-100 (NEC)
20gb Quantum drive
Voodoo3 AGP 16mb
Asus CD-ROm
PROBLEM
Motherboard will not boot when installed inside casing.....
(I unplugged everything and replaced the video card and ram
but still not boot)
I removed the board from the case and tried it on a testbench...
it works perfect this way
Is the board grounding / shorting  inside the case?
or do I have a bad board?
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Aug 10, 2005
Not Rated (0)
Lizzy
Lizzy - usenet poster
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
I feel for ya man, I've been working on it for three days (VA6) and is VERY
unstable....  swapped everything, yes, everything you could possibly connect
to a motherboard...  and no dice, unstable.     (i have multiple systems
available) (called Abit, and they agreed that it is probably a bad MoBo.)
It now has its very own RMA number and will soon be going back from wence it
came......
Now I will Try an FIC VIA Apollo Pro (without the onboard sound)
be forewarned, I learned from Abit that PCI slot #3 may conflict with the
onboard sound IRQ, so don't use that slot if you don't have to... or disable
the onboard sound in the bios.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
Not Rated (0)
M0nica L
M0nica L - usenet poster
Rating: 0%, 0 votes
tried everything you guys suggested  but still  nothing..
going to swap boards..
I will let you know
Solution #3
Not Rated (0)
maartenw
maartenw - usenet poster
Rating: 0%, 0 votes
The most likely problem is the MEMORY.  Swap out the RAM and watch your
tourbles go away!
-ET
Solution #4
Not Rated (0)
Phoebe
Phoebe - usenet poster
Rating: 0%, 0 votes
What kind of load do you have on the power supply?
Many of the switching power supplies used with PCs will
not regulate correctly unless they are loaded with
20% or more of their rated capacity.  Try adding
a hard disk to the power supply in addition to
your MB.  This may allow it to power up correctly.
Regards,
Ed G.
* Sent from AltaVista http://www.altavista.com Where you can also find related Web Pages, Images, Audios, Videos, News, and Shopping.  Smart is Beautiful
Solution #5
Not Rated (0)
Perkins
Perkins - usenet poster
Rating: 0%, 0 votes
Here's an update to my problem....
I eliminated the grounding issue by properly insolating the board.
I started up the system and it WORKED.
but this was shortlived........after I formated the drive and reset I had
the same problem again......no startup, no post, nothing....
I removed all the cards, disconnected all the drives......plugged in
another
video card......still nothing...
note:
only after 1/2 hour of use the power supply was letting out alot of hot
air
I suspect the power supply isn't giving the full output.....
I'm a little tired  now....
I'm going to replace the power supply tomorrow and maybe the slot1 card
Keep you all informed
Solution #6
Not Rated (0)
Luisa_K
Luisa_K - usenet poster
Rating: 0%, 0 votes
Grounding inside the case is certainly the #1 suspect under these test
circumstances.  Try putting paper washers ( a bit of masking tape with
a little hole poked through it will also work) between your mounting
screws and the top of the motherboard AND between the mounting posts
and underside of the motherboard.  Make sure that there are no unused
posts left over from a past motherboard...remove them.
Let us know if you continue to have problems.  Good luck.
df
Solution #7
Not Rated (0)
2Pansy
2Pansy - usenet poster
Rating: 0%, 0 votes
Were you testing it with the same power supply both inside and outside the
case? If so, then definitely check for grounding issues. If not, try a
different power supply (the one you used on the testbed) when it's in the
case and see what happens. It is also possible you have a bad board. Or that
your case is posessed. ;)
Jeff
Can you Help with these Hard Drives problems?
Hard Drives
USB Plug and Play stopped...
My Beyond Micro 250GB Mobile... Answer This...
Hard Drives
necesito driver de sonido
sony vaio instal? windows vista... Answer This...
Hard Drives
drive not detected in Mac
I had used the Maxtor OneTouch... Answer This...
Hard Drives
My external hard Drive DIGITAL...
My computer doesn,t noticed it... Answer This...
Hard Drives
Hard drive recorder...
My 3 month old philips dvd hdd... Answer This...
Repair Service
Find Hard Drive Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
