Question about Samsung HT-WP38 System
Samsung Home Theatre "Protection Error"
I have the same problem as the person on the previous page. When I turn on my Home Theatre unit I get "Protection" and it shuts off. What is this and how do I fix it?
  • 1 more comment
  • Anonymous Apr 05, 2008
    Same problem with Samsung HT-P38
  • ilko Mar 02, 2009
    Hi. I have the same problem - PROTECTION and then shut down. But this problem appears only on DivX disks. Please help me to fix this problem!
  • John Pearce
    John Pearce Sep 07, 2018
    I have a Blu Ray Samsung HTB-H4500R. This player worked for a few minutes before showing Protection message. Fan and inside cleared of all dust, but no improvement, even with lid off. Also no signs of components getting hot, or speaker wiring problems. Eventually fault cleared by removing front control panel, disconnecting the one ribbon cable and brush cleaning the reverse side of board with alcohol (where there were deposits of a sticky nature which were there from manufacture). Dust was attracted to these deposits causing a malfunction of possibly high impedance circuitry. The clue was that I had read elsewhere about disconnecting this panel on other Samsung Blu Ray players which cleared the fault and using the remote control for operation. I think the sticky stuff was used on screws going into plastic, and may have migrated with time.
    However, I started to receive the same error message again. Further investigation of the main PC board showed evidence of a deterioration in what looked like solder flux on the underside of the board. This was washed using a brush and alcohol (methylated spirits - or maybe ethanol). If you place the board edge-on on some kitchen towel, you will see the offending material wash off. Using the board immediately after cleaning (even if it looks as though the alcohol has evaporated) will result in a protection error showing, but leaving the board to dry properly in a warm place for a few hours will enable the board to function correctly. Still working after days of use! One thing I also did was to give the spring mounted heat sink on the audio chips a little wiggle to ensure a good contact.
    John Pearce
    The fault has returned, and after obtaining a quote from my local Samsung repair centre of high, but unspecified cost, had another look after discovering the fault could be cleared for sometimes a short or long period by jarring the unit on the surface it stood on, and decided to look for dry joints. These were found on one of the two power semiconductors (attached to one of the heatsinks). These were made good together with the soldered connections immediately associated with these dry joints. Also remade soldered connections to the other power semiconductor and its nearby solder connections. Also checked soldered connections of the two 560 ohm wirewound resistors where there was evidence of slight heating damage in that area. The capacitor between these resistors could be subject to heat damage, but the capacitance of the component was correct. After re-assembly, the player was no longer giving fault errors and was mechanically stable. There is a design fault with the efficiency of heat dissipation from devices on this PC board since this kind of fault should not occur.
    Previous attempts by cleaning the boards with alcohol simply appeared to clear the fault because the dry joints were disturbed.
    John Pearce
I've had a similar problem where the fan stopped moving and the system gave the usual "protect" error. i think the IC's burned out on the amp board since the error was no longer there when i unplugged it. i ordered a new board off ebey for $25 shipped. make sure this is the problem by unplugging both the power and data cables from the amp circuit (the board with the big heatsink) and starting it. if it says starts normally then the problem is the amp circuit
Posted on Sep 14, 2009
    Habit-Forming:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 10 Answers
Check the speaker connection the problem my be caused by shorting wires!Otherwise its a bad amp.
Posted on Jan 21, 2015
Here is a tech note from Samsung concerning this problem. Not a fix but at least some sort of an answer about the problem. I guess you could check continuity on the fan and if it is dead you could replace it.
http://erms.samsungelectronics.com/customer/ph_srch/jsp/faqs/faqs_view.jsp?PG_ID=3&AT_ID=24114&PROD_SUB_ID=52&PROD_ID=-1
Posted on Mar 30, 2008
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • Samsung Expert
  • 75 Answers
No further troubleshooting, needs for repair this is a major fault
Posted on Dec 30, 2014
SOURCE:
Hi,how can i reset my LG 7.2 home theatre system? The unit keeps displaying (M-PROTECTION) please help me.
Protection can't be "reset". The condition that caused it has to be corrected. Protection is enabled if the audio output is driven too hard or speakers with the wrong impedance (or shorted) are connected. Failure of related components can cause protection to be enabled.
Dec 02, 2016 | LG Audio Players & Recorders
Samsung home theatre protection error
There is a failed part in the amplifier. Usually a transistor in the output section.
Aug 08, 2015 | Samsung Audio Players & Recorders
Sony Home Theatre System Turning Off
Appears that you have a bad cap in the power supply that is changing value as it heats up. Hard to find - only thing you can do is go to suspected units and replace them hoping that you got the bad one. Or just wait till it finally pops.
Apr 02, 2017 | Sony Home Theater: DAV-DZ870W ALL REGION...
The home theatre system LG HT904TA went in to protection mode. Mean that the receiver/dvd panel shown 'protection ' on the display panel. I have try to switch off /on but the 'protection...
If you've disconnected the speakers and the fault is still showing then the fault is internal with the Amplifier and it's shutting down to protect itself from further damage.
Your only solution is to remove the cover and have a look at repairing it yourself or take it to a repair shop.
Jun 28, 2011 | LG Audio Players & Recorders
My dvd home theatre system ht tx75 keeps shutting down
protection error message means that your unit's fan is not working
it is a feature to keep your unit from overheating
check if there is anything blocking the fan of your unit from rotating
if problem still persist replace the fan
May 28, 2009 | Samsung HT-TX72 Theater System
I didn't solve the problem,however i called sam sung and I will be sending it in for repairs under warranty.
thank you
Jan 27, 2009 | Samsung 1200W 5.1-Ch. XM-Ready Home...
Protection
sounds like you may have your speakers connected wrong or too many speakers. Check all your speaker wires for a goo tight connection and speaker compatibility with your Home theater system. Hope this will help you
Dec 20, 2008 | Sony MUTEKI HTDDW1600 Theater System
My home theatre system (sAmsung DVD home theatre system HT-Tx75)shuts down automatically after 10 minutes of listening to the radio...it says 'protection', then shuts off. i checked to see if it was on...
Protection mode on a Samsung player most likely means that the unit is overheating due to a non or low functioning fan. Before taking it somewhere to be serviced turn the unit on and see if the fan in the back is functioning (it should be on whenever the unit is on). If it is not you can try gently blowing it out with a can of compressed air.
I am sure that you can have it serviced but it might be cheaper to purchase a new player.
Good luck and take Care,
-WN
May 06, 2008 | Televison & Video
Dvd home theatre system
When I turn on my DVD it says "welcome to samsung dvd, no disk, protection, good bye" Why? What is wrong and how can I remedy it???
Oct 18, 2007 | Samsung Audio Players & Recorders
Samsung HT-WP38 System Logo
12,356 people viewed this question
Top Samsung Audio Players & Recorders Experts
Mike Duncan
Mike Duncan
Marvin
Marvin
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
