Question about EliteGroup (ECS 915PL-A2) Motherboard
Checked all of those...any other thoughts?
Great response, but I've checked all of those. Any other thoughts?
Thanks! Stephen
    President:
  • 2,351 Answers
Http://www.fixya.com/support/t444871-915pl_a2_no_post_no_beep_no_keyboard
Lets address the video. Display is more important.
If your only using one PCI-E you do not need to plug in the 4-pin power connector pg. 20 in manual, see notes no# 4.
However it is unclear if this is true by reading your manual.
On other boards the 4-pin 12v power connector is not needed un less you are running 2 PCI-E cards.
(You will have to test this statment).
Disconnect the power connector pg. 20 in manual, see notes no# 4.
Remove your installed PCI-E1 video card & re-seat it, (making sure it is seated evenly). (If you have a second PCI-E card do not install it.
Start PC & enter bios. Check that your bios is set to PCI-E for video display & not VGA. Pg. 32.
While in the bios disable the audio. (for now).
Set Plug & play Aware O/S, to No. (This allows the bios to set IRQ's rather than windows).
Save & re-start the PC. Did you get video? No?
Shut down the PC & connect the 4-pin 12v connector for the PCI-E1. Start the PC. Did you get video display?
Other reasons for not to getting video display.
CPU not seated correctly / bad or bent pin. Socket locking arm not engaged. Thermal grease not applied. HeatSink not locked.
1. Video card needs cleaned. (use house hold Alcohol & cotton sawbs). Clean copper contacts. Clean out PCI-E slot.
2. There may be a short between the board & the case.
3. Connection is loose, (either end of the video cable).
4. Connected to the wrong video out-put. (Switch cable to second video out put on a dual out port card).
5. Have a bad video card. (Swap it if you got another).
Memory check.
1.Can include not correct voltage for board.
(you'rs must be 2.5v). No higher.
Over clocking memory in bios. (Set to Auto)
3. Bad DIMM. (remove one DIMM if two is installed), (swap slots in-between restarts).
4. Download free Memory Tester (click the link).
http://www.memtest.org/
Give the stuff above a try Stephen.
It's late & I'm wired.
Have a good day!
Posted on Mar 18, 2008
  • Mike Peluso
    Mike Peluso Mar 20, 2008
    All out of options. ;-{
SOURCE:
Went to jump start Ford Focus 2008 put the wrong lead on terminal had a spark but now the car won't start after replacing the battery
here's another Stephen to help you the first one is correct and after you do these things suggested by Stephen also since you have a volt meter check your cables first then go to the starter and see if you have voltage going in if you do the solenoid on the starter has gone to the great fried starter heaven in the sky change the starter motor
here are some pictures to help you good luck to you and way to go Stephen from Stephen
Feb 14, 2015 | Ford Cars & Trucks
Hi Stephen, what do you know about a 1983 Ford Crown Victoria? Runs great, then stalls and won't start. replaced a few things already, still the same. Any ideas?
have you checked into the fuel throttle sensor (throttlebody)?? im haaving issues right now as well with my 2004 explorer
Jan 25, 2013 | 1983 Ford Crown Victoria
Sharp aquos won't turn on
if it was a new tv you can ask the supplier for check up it was covered with warranty.
Sep 22, 2012 | Sharp AQUOS LC-22SB28UT 22" LCD TV
I AM LOOKING FOR A NEW YORK ****** CAMOUFLAGE BALL CAP. WAS WONDERING IF YOU COULD PLEASE HELP ME. I LOST MINE AND AM LOST WITHOUT IT. THANKS IT IS FOR A MALE THIS IS MY WIFES E-MAIL STEPHEN
eBay has a great search engine. Try using it. If it is available on eBay, it will show up in the search results.
Hope that helps.
Sep 09, 2011 | eBay Auctions
I've got a 1996 Kawasaki ZX6R. The bike runs great. However, it will shift down into first gear, but won't shift up past neutral. Any thoughts? Thanks, Lance
The bike has a bent shift fork. The engine must come out then gets flipped upside down to remove the bottom half of the crankcase. This allows access to the gears and shift forks. The repair is not recommended for the home mechanic. Please rate my answer. Thanks. tombones49_211.gif
Jul 14, 2011 | 1996 kawasaki ZX-6R Ninja
Our bread maker doesn't heat at all, it will make the bread then just turns off. We've had it for about a year, we've made 10 loafs, maybe. Those were some expensive loafs of bread :( Any...
Contact [email protected] for a service center near you.
Otherwise, try to reboot your breadmaker's computer by plugging it in then pressing and holding the Stop/Pause button down for at least 3 seconds.
Hope this helped. ;)
Jun 10, 2011 | Cuisinart CBK-200 Bread Maker
Hi i have brought a second hand car, which was fitted with an Alpine cda9830r stereo, but no user manual, i have found one for a cda9830 stereo, is there a lot of difference in the two, as i have amps,...
Hi stephen my names Josh. Its great you could find a second hand manual for the cda9830 and theres not any difference your manual will tell you need to know about the cda9830r as well. Your amp hook up will be very standard speakers and sub will match very well with the that alpine in your car.
Mar 05, 2010 | Alpine CDA-9830 CD Player
I am working on a Murray riding lawnmower. It cranks great. The motor runs great,but when I let my foot off the clutch the motor dies. If I am quick and push the clutch down I can stop it from dieing,but...
If there is a switch on the grassbox it might be faulty or the box may not be closing tight. Check the switch under the seat and the cutting blades safety
switch, it must be one of these. Stephen
Sep 07, 2009 | Briggs & Stratton Garden
Replacement baffle installation
thats why we are here,thanks for the compliment
Aug 31, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Relay click and 9 blinking led.
Try the following steps:
1. Remove the power supply to X Main board, check VE. If you get normal VE then replace the X Main board. Otherwise to 2.
2. Remove the power supply to Y Main board, check VE. If you get VE then replace the Y Main board, otherwise to 3.
3. Replace the SMPS board & SMPS 200V board.
Good Luck
Mar 22, 2008 | Samsung SPN4235 42 in. Plasma HDTV
Open Questions:
See all EliteGroup (ECS 915PL-A2) Motherboard Questions
EliteGroup (ECS 915PL-A2) Motherboard Logo
48 people viewed this question
Top EliteGroup Computers & Internet Experts
Alun Cox
Thomas F. Schneider
Ekse
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
