Question about LG LRFD22850 Bottom Freezer Refrigerator French Door
Frozen Water in Pan behind freezer drawer.
It apears to be the problem you suggested. We must access it through the back of the refrigerator right? Not through the front by removing the freezer drawer?
  • Nancyv Mar 16, 2008
    My husband removed all of the freezer parts, door, etc. We didn't realize the back wall can be removed...It appears to be a large piece, so we didn't remove it, as we didn't know the ice maker droped down. However, we will look at it again, if the problem persists.
    The ice began melting into the pan area....we used a hair dryer on the back wall and let it thaw for several hours, while the refrigerator was unpluged.
    Do you think that will solve the problem? If not, we will start all over again, and remove the ice maker this time.
    How often does this happen?
    If the freezer door was not closed properly at one time, could that have caused the ice build up?
    President:
  • LG Master
  • 2,651 Answers
Yes you will have to remove the freezer door and go through the front of the unit. the door itself is the easy part to get off, it lifts off the rails, you may have to remove a screw a few inches back fromm the freezer door on both freezer rails(phillips head screw, ). empty the freezer pullout before trying to remove. after that the the pull out upper shelf comes and thenyou can remove the horizontal rails , the ice maker drops down and then the back wall can be removed
Posted on Mar 15, 2008
  • Ron Coons
    Ron Coons Mar 16, 2008
    completly defrosting the refig might possibly solve you rproblem, as foar as how often does it need to be done, well if everything is working properly never. freezer door might attribute to other problems but not freezing the drain tube, thats more a fluky thing
How to take out freezer drawer for cleaning
Drain is clogged in the back and that is why water is in freezer.
As for drawer you can either remove drawer above it and pour water behind frozen drawer or slowly chip at the ice to break it loose.
Apr 25, 2015 | Refrigerators
Top drawer of freezer seems to work but large bottom drawer not freezing even at -5degrees. Can this be fixed?
This problem seems to be two sided. A refrigerator defrost it is supposed to take the water from defrost down a pipe located behind the freezer rear wall to a pan below the refrigerator where there is a fan blowing warm air over the water to evaporate back into your home or business. If that drain is blocked your refrigerator will accumulate a large block of ice and frost behind the rear panel of freezer and temperatures will warm considerably in fresh food compartment and freezer. Here is one site I want you to read over=> Leaking Refrigerators Just What may Be Happening and here=> Leaking Refrigerators here is a link to a service manual=> LFX25960xx Service Manual Let me know if this service manual is close enough to your model number. At this point I am looking for air blockage behind the rear panel of freezer. If air is being blocked by ice and frost you can use a hair drier to help speed you up while melting ice. If drain is blocked use whatever you can to open the drain line mentions on the links I sent you to and let me know what is found, Thanks Sea Breeze
Feb 18, 2012 | LG LFX25971ST Bottom Freezer French Door...
Ice build up in the bottom of the freezer compartment to the point that it will flow under the gasket like a glacier and melt. There is not an icemaker hooked up. No free water is piped to the unit and...
You have a common problem of a clogged drain, in the back bottom of the freezer, behind the shelf and drawers, you will find a drain pan that has frozen completely over with a ice sheet. This has caused defrost water to run forward and collect under your racks in the freezer. I would advice you to turn off unit, and remove all the ice collected in the freezer, clear the pan with warm water, then restart your unit back up.
Once the pan and drain tube is clear, your unit should be fine.
I hope this helps
Aug 02, 2011 | Whirlpool 24.8 Cu. Ft. Side-by-Side...
GE Profile leaking onto floor
Clean the drain pan and drain line in the back of the freezer section behind the cover underneath the evaporator coil. (hint: use turkey baster with hot water) Make sure water drains when you pour it in. If it doesn't - also clean drain tube on the back of the unit behind the cover. When done - put the tube exactly where it was.
Good luck! :)
Vlad
First Choice Appliance
Apr 19, 2010 | GE Profile TPX24PBDCC Side by Side...
Excessive water in the bottom of the refrigerator but none in the underneith drain pan, everything is cold in the refrigerator and frozen in the freezer, what can be the problem? How can I fix it?
the problem is the water tank located behind the lower drawers,the hoses press into the tank on rh side,usually crack or deteriorate @ point of connection-must replace the tank itself
Mar 10, 2010 | Westinghouse WRS3R3EW 33" 22.6 Cu. Ft....
Water colecting on floor of freezer in fridge-freezer (Hoover floorstanding model 3 years old). I can not find a drain hole - water apears to be running down from cabinet behind bottom drawer.
The ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repairs.
Mar 24, 2009 | Maytag MSD2754G Side by Side Refrigerator
Frididaire side by side refrigerator- water freezing in bottom
Frozen or Plugged Defrost Drain
On Side By Side Refrigerator
The defrost drain pan is located at the bottom of the freezer compartment behind the back wall of the freezer. On some models the pan is accessible without removing the back panel and others are not.
Once you get to the defrost drain pan use a hair dryer to melt the ice from the pan.
Once the ice is removed use a turkey baster like this one: Turkey Baster http://www.repairclinic.com/SSPartDetail.aspx?PartID=428708&PPStack=1
To squirt hot water into the drain hole to clear the drain.
When the drain is clear you should hear or see the water you are squirting into the hole enter the pan under or behind the refrigerator.
TheRepairGuru ---- www.repairclinic.com
Jan 27, 2009 | Frigidaire FRS20ZSG
Freezer drain plug
Self defrosting refrigerators as well as freezers all have a defrost drain system. This drain system can become plugged or frozen causing defrost drain water to back up into the refrigerator or freezer compartment. The water may gather under the crisper drawers on top freezer models. On side by side, bottom or stand alone freezers ice will build up in the freezer at the bottom and eventually leak out the door.
Plugged Defrost Drain - Freezer on Top (Water under the crisper drawers)
At the top of the refrigerator next to the temperature controls there usually is a cup-like part that carries the defrost drain water into a tube and out the back of the refrigerator to a defrost drain pan behind the unit. Pull the cup out of the tube and clean the cup with hot water and soap. If there is no cup, pull the refrigerator out away from the wall, go behind it and disconnect the drain tube to clear it. If the drain tube is not accessible from the back or the drain can not be cleared from there the main back panel in the freezer can be removed to access, thaw and flush out the drain under the cooling coil.
Use a turkey baster to flush HOT water into the tube to clear any obstruction. The water squirted into the tube should end up in the defrost drain pan.
If the tube will not clear with hot water try blowing it out with compressed air.
Put the cup back on and make sure it is all the way on or in the tube.
Plugged Defrost Drain - Side By Side, Bottom-Freezer Refrigerator or Stand Alone Freezer
The defrost drain pan is located at the bottom of the freezer compartment behind the back wall of the freezer. On some models, the pan is accessible without removing the back panel and others are not. After you get to the defrost drain pan use a hair dryer to melt the ice from the pan.
Once the ice is removed use a turkey baster to squirt HOT water into the drain hole to clear the drain.
http://www.repairclinic.com/Whirlpool-Refrigerator-Parts
Jan 26, 2009 | Whirlpool ET9FTKXK Top Freezer...
Ice behind the high humidity compartment
You have clogged train which has frozen over. There is a factory kit to add a heater. You firrst might want to try and defrost the tube using warm water after your remove the ice. You want to make sure that water will flow down that trough and passed the tube. THe watere goes to a drain pan below.
Dec 02, 2008 | Sub-Zero 650 / O Bottom Freezer...
Roper Refrigerator
open the freezer compartment loo for ice build up on floor of frezer especally towards rear behind back panel. sounds like you have a clogged/frozen defrost drain tube. removing back panel of freezer will give you acess to drain trough, melt away the ice with a hair dryer, youll find a drain hole under there somwhere,pouring boiling water down the drain will clear it pretty quickly( i use a steam machine purchased from the infomercials)
Mar 05, 2008 | Roper RT21AKXKQ Top Freezer Refrigerator
LG LRFD22850 Bottom Freezer Refrigerator French Door Logo
337 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
