Question about Gateway 2520915 Keyboard
Mikomi wireless keyboard
Iv tried to plug in my new keyboard but it not working the lights are on and flashes when i press any button but it wont right
  • Anonymous Apr 13, 2009
    its annoying the hot keys work and the mouse but none of the other keys work and i tried this and it still didn't work do i have to sit there and press the connect button on the receiver then press the button underneath the keyboard for 3 secs for 255 time!?
  • 151 Answers
You must in
  1. right click on my computer
  2. click on properties
  3. click on hardware
  4. click on device manager
  5. click on keyboards
  6. click on(+)
  7. then right click mouse
  8. click on update driver
  9. select second option in window(advanced)
  10. then click on( search removable.......)
  11. then insert driver cd in cd rom
  12. And click on Next option
If you have done this then do this
  1. if it is not work then do above procss and select third option(Don't search.I will...............)
  2. And click Next option
  3. click Next option in next window.Thats it
Hope this be of initial help/idea. Pls post back as requested, how things turned up or
should you need additional information.
Good luck and kind regards.
Thank you for using FIXYA.
Posted on Mar 16, 2008
SOURCE:
Hi I have a KM80545 (mikomi) Argos value range wireless keyboard. The keyboard has been working fine until the batteries needed changing. Hence I have changed batteries and the keyboard doesn't seem to be...
I had the exact same problem but with my mouse! the keyboard worked so it obviously was a problem related to connecting to the router (USB)
I later discovered that the LED light on the USB is a button, so click that and click the little circular button on the back of your mouse, then be patient, the mouse should reconnect!
Apr 24, 2010 | KME PC Keyboard and Mouse
A few keys wont work on keyboard and when i turn on note book screen flashes. by pressing enter computer turns on but then there is still buttons that wont work about 5
A laptop keyboard can be replaced by a repair store however, before we get into that, I also suggest you plug in a USB keyboard into your laptop and double check that another keyboard does work. Once confirmed you can decide whether you want to fork out cash for a new keyboard or buy a new keyboard. Logitech sells a wireless keyboard + mouse set for $30 which is incredible.
Dec 31, 2009 | Computers & Internet
Alright so my keyboard on my desktop just crapped out on me. I'm trying to figure out what it is and have no idea. I try the usb ports on the front, no luck. But when i plug the mouse in the front along...
Are the batteries good?
Normal 0 Press the Receiver button (and the lights will start flashing.
Then if the Keyboard isn't working, press the small RESET/CONNECT button on the back of the board to connect the keyboard to the receiver.
Jan 05, 2009 | Logitech Elite 967234-0403 Keyboard
Wireless keyboard and wireless Mouse
Try
If the MOUSE isn’t working, push the small RESET/CONNECT button on the back of the mouse to connect to the receiver. Then they should work okay.
Hope this helps. Bud
Jun 09, 2008 | Logitech MX3000 USB PS/2 Wireless...
Mikomi
just install the mouse drivers, and then follow the hardware installation. 1. Turn on PC wait for windows to load 2. Insert the USB Plug of the receiver 3. Press the small button on the mouse & Keyboard 4. Press the button on the receiver. then the connection between the mouse and keyboard will be established. Press keys and Move the mouse to see if the connection is ok.
Jun 04, 2008 | Micom (VIP-4004-ISO-DX) (VIP4004ISODX)...
Wireless belkin keyboard
Hi. I have just worked out how to solve this as I had a similar problem. When you change the batteries of a Belkin Wireless Keyboard model F8E332ukBNDL you need to reconnect the keyboard to the wireless receiver that plugs into the USB port. To do this you press the 'Connect' button on the receiver and also press the green LED connect light at the top right of the keyboard - the one that flashes each time you press a key. I'm not sure in what combination you press these but I pressed them both and it worked.
May 16, 2008 | Belkin (F8E832-BNDL) (DBF8E832BNDL)...
Thing just won't work.
After starting up the computer with the wireless receiver, keyboard and mouse attached,, (with good batteries in both) install the CD software program and thenif it doesn't work follow these instructions:
May 11, 2008 | Microsoft Wireless Optical Desktop 1000...
Wireless keyboard
Dec 25, 2007 | Computers & Internet
Don't run the setup program. Instead reboot your computer and use the windows add hardware wizard to install the drivers from the CD. The windows hardware wizard will detect several different devices, allow it to install them all from the CD.
Dec 01, 2007 | Gateway 2520915 Keyboard
WIERLESS MULTIMEDIA KEYBOARD 98059
Wireless keyboards and mice have a "sync" button you can push to make sure that the peripherals and the receiving station are all on the same channel.  On your receiver (the one you plug into the computer) you will see a button.  Pressing this should cause the lights on it to blink.  When this happens press the button located on the bottom of the mouse (usually very small and recessed - try using a pen tip).  The lights should stop flashing and the mouse will be on the correct channel and should work.  Repeat the process with the keyboard if that does not work as well.
Oct 23, 2007 | GE (JASHO98059) Keyboard
Gateway 2520915 Keyboard Logo
71 people viewed this question
Top Gateway Computers & Internet Experts
Ekse
Prashant M
Prashant M
Thomas F. Schneider
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
