Question about Microsoft Office Outlook 2003 for PC
Outlook problem!! Whenever the outlook opens up, it shuts down right away. A report error to microsoft message appears and once I click on to it, a regret message appears and the outlook express programme shuts down. Pls help as I have not seen mail on my outlook for over three weeks!!!!
  • peru Mar 23, 2008
    it says outlook cannot open your default folders
    Novelist:
  • 104 Answers
Uninstall office completely, restart your system and reinstall office completely...
Posted on Mar 15, 2008
I keep getting an error message that says, "Microsoft Outlook. Cannot open the Outlook Window. The set of folders cannot be opened. Errors have been detected in the file C:\Users\my name\AppData\Loc
To resolve this problem, use the following steps. On the Start menu click Run. In the Run dialog box, type the following command:
Outlook.exe /resetnavpane
Note:
There is a space between "Outlook.exe" and "/resetnavpane" Click OK. Note If you are using Windows Vista or Windows 7, you may not see Run on the Start menu. In this situation, use the following steps to locate the Run option. On the Start menu click All Programs. Click Accessories. Click Run.
Apr 15, 2013 | Dell Computers & Internet
I keep getting the message The data file 'personal folders' was not closed properly when I open Outlook, how can I prevent this from happening?
The underlying reason why Outlook displays this "data file" check is very simple. There is a single flag in the header of the data file that is a Boolean value (True or False). While you use Outlook the value of this flag is constantly changing as the data file is updated. When the update begins the value is changed to False and then when the update completes the value is changed back to True (implying the update is finished and successful).
So, the key to the problem is the shut down process because once the Outlook.exe process is exited this flag value cannot be changed. If the Outlook.exe process was terminated prematurely or a 3rd party add-in did not properly set the flag value to True then the flag value can be left at False. If you start Outlook with a data file where the value of the flag is False you are guaranteed to see the "data file" check. If the value of the flag is True then you will not see the "data file" check.
Right now, there are a few known common causes for this issue:
- Shutting down Windows before the Outlook.exe process has exited
- 3rd party add-ins improperly "closing" the data file
- Outlook crashing
- Non-Outlook process accessing the data file
http://support.microsoft.com/kb/954642/en-us
http://support.microsoft.com/kb/948733/en-us
Regarding the post advised by Rod, I would like to explain more detailed:
When you shut down Outlook, the Outlook window goes away, but the Outlook.exe process can continue to run for some time. That's why you can see Outlook.exe sitting in Task Manager for a few minutes after closing the Outlook window. If you shut down Windows while the Outlook.exe process is still running Windows will not wait for the Outlook.exe process to exit. So, you increase the likelihood of encountering the "data file check" issue the next time you start Outlook (because the Outlook.exe process was not able to "close" your data file(s) completely before Windows was shut down).
On the other hand, if you leave Outlook running when you shut down Windows the Outlook.exe process will continue to run and exit on its own. When Windows is shut down, it sends messages to all visible window frames telling them to quit, and will wait for those programs to quit before shutting down. Not until all processes with open windows have exited will Windows finally shut down. This is somewhat counter-intuitive to most people as traditional training has always advised manually closing applications before shutting down Windows.
Mar 10, 2011 | Microsoft Computers & Internet
Logged on and my email icon was missing as well as other icons. tried to start outlook and the message is simply cannot start outlook. cannot make google my home page as dell4me contiues to override any...
This issue may occur if you deploy Outlook 2003 with the Microsoft Office 2003 Custom Installation Wizard and specify a personal folder (.pst) file in the Windows Installer transform (MST file) by using the Default location for PST files path option. The problem occurs because you specify a file name instead of a folder path.
To resolve this issue for future installations of Office, use the Custom Installation Wizard to edit the MST file. To do this, follow these steps:
  1. On the Change Office User Settings page (page 10 of 24), expand Microsoft Outlook 2003, expand Miscellaneous, and then click PST Settings.
  2. In the right pane, double-click Default location for PST files, and then type the path that you want in the Default location for PST files box. For example, type %USERPROFILE%\Local Settings\Application Data\Microsoft\Outlook\.
  3. Click OK, and then follow the steps to complete the wizard. When you have corrected the MST file, deploy Office by using the correct MST file.
To resolve this issue for an existing installation of Outlook that is experiencing this problem, specify the .pst file by using the Mail icon in Control Panel.
Or If you are receiving and Err like
Error message when you start Outlook: "Unable to open the Outlook window," "No profile has been created," or "The list of Profiles cannot be loaded"Follow the step's below:This issue may occur on a computer that is running Windows XP if the Outlook.exe file was configured to open with the Windows program compatibility mode setting. When you set compatibility for Outlook to Windows 95 or to Windows 98/Windows Millennium Edition, Outlook displays this error message. This is because the location of the Outlook Profile information in the registry differs on a Windows XP-based computer.
To resolve this issue, follow these steps:
  1. Locate Outlook.exe.
    Outlook.exe is typically located in one of the following folders, depending on the version of Outlook that you are running:
    • Microsoft Office Outlook 2010 C:\Program Files\Microsoft Office\Office14
    • Microsoft Office Outlook 2007 C:\Program Files\Microsoft Office\Office12
    • Microsoft Office Outlook 2003 C:\Program Files\Microsoft Office\Office 11
    • Microsoft Outlook 2002 C:\Program Files\Microsoft Office\Office 10
    • Microsoft Outlook 2000 C:\Program Files\Microsoft Office\Office 9
  2. Right-click Outlook.exe, and then click Properties.
  3. On the Compatibility tab, click to clear the Run this program in compatibility mode for check box.
  4. Click OK.
  5. Try to start Outlook. If you receive error message again, use Method 2.
Regard's
Pcs365.8
Jun 16, 2010 | Microsoft Windows XP Home Edition
Cannot open outlook window - had it open checking e-mail and computer 'jammed up' and would not do anything - shut down and restarted - tried to open outlook and window flashed open (white) and immediately...
You could try and repair office by going into add/remove programs if it's XP, or programs and features if its vista.
Both are found in control panel.
Find your office 2003 line in add/remove programs, click uninstall, and you should get a repair option. YOu will probably need the disk to repair it.
Aug 11, 2009 | Microsoft Office Outlook 2007: Windows
Microsoft Outlook 2007 Enterprise Not Responding/"Hung"
Try opening outlook in safe mode and see if that works
go to your start button
go to run
type in outlook /safe
also you could disable any add-ons that you are not using
also you could do a detect and repair
http://office.microsoft.com/en-us/outlook/HP101407921033.aspx
Feb 15, 2009 | Microsoft Office Professional 2007 Full...
Exiting Outlook 2003 running in Vista OS
There is a compatibility update from Microsoft for Vista and Outlook 2003:
http://support.microsoft.com/kb/929427
It doesn't address specific problems there, but it tells you how to get the compatibility updates. Sounds like a good place to start.
Dec 31, 2008 | Microsoft Office Outlook 2003 for PC
Outlook express keeps shutting down
Microsoft products are always affected with virus I am prepared to recommend Eudoramail which is the best as what my experience is concern for email services. Download with this link below http://www.eudora.com/
Hope this will work your problem.
Nov 24, 2007 | Microsoft Office Standard for PC
HOW DO I FIX THESE ERROR MESSAGES?
you need to run a inbox repair tool.
Make sure you close outlook
Start > My computer > Tools > Folder options > General tab click on show hidden files and folders > Apply ok
Go to the follow wing location to find scanpst.exe
if you are using Outlook 2007
If you using Outlook 2003
C:\Program Files\Microsoft Office\Office11
Double click on SCANPST.EXE
Click on browse go to following locaiton where your pst file as been save
C:\Documents and Settings\Robyn M. Drothler\Local Settings\Application Data\Microsoft\Outlook\outlook.pst
Click on start > then click on repair
Sep 11, 2005 | Palm Treo 600 Handheld
Microsoft Office Outlook 2003 for PC Logo
93 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
