Question about Rainbow E series Canister Wet/Dry Vacuum
Rainbow Run Hot?
I have an E Series Rainbow. There is a component on the cicuit board, I believe it is a resister. This part gets hot and heats the soder and lets loose. After I reinstalled this component, vacuum ran for a few minutes before part falls out again. Any suggestions?
Thanks
  • Steve_340 Mar 15, 2008
    Yes, I did resolder it.
Filho da puta
Posted on Mar 15, 2008
    President:
  • 1,673 Answers
Did you re-solder that component? You may have to replace that computer board, it may have other damage that you can't see.
  • Lauren Junge
    Lauren Junge Mar 15, 2008
    The the board has other problems and you need to replace it.
Why does my plug get extremely warm or hot?
Inside the wire, several strands of wire are broke. Heat is caused by less strands of wire that have to carry more current in amps. This is a safety and fire hazard. Cut the old plug off by cutting the cord about 2 inches away from the plug. Strip the wires carefully. Do not cut or break off any strands of wire. Install a new plug. Make sure you buy a round plug that has a round opening for your round cord. A lot of plugs are for flat type of cords only.
Oct 24, 2015 | Rainbow E series Canister Wet/Dry Vacuum
Looking for replacement component for motor controller board, a capacitor that is in series with the AC input line.
Unfortunately Rainbow does not offer this part by itself, they only make the computer as a complete assembly. Rainbow E2 controller 120v You can try contacting local vacuum shops and see if they have any broken Rainbows with good controllers that they would be willing to sell only that part to you.
800-775-6586
GoodVac com
Feb 10, 2015 | Rainbow Vacuums
How to get solution out of rainbow shampooer
It is always best to run hot clean water through the wash cycle to flush out all soap when finished. This helps to prevent soap from drying in the lines and pump. You can also try this to help free a pump that is not working correctly.
Our tech. team is available if needed... Contact Us
RainVac
May 24, 2014 | Rainbow E series Canister Wet/Dry Vacuum
The e series rainbow 2 speed works only on low speed. High speed will not run. What is srong?
It is either the switch or the controller. Call us and we can see if it is still covered under your warranty.
RainVac
www.rainvac.com
800-523-0510
Jul 23, 2012 | Rainbow E series Canister Wet/Dry Vacuum
Aquamate II doesn't come on
The early version of the AquaMate II was very sensitive to clogging. Run very hot water through all the lines in the wash cycle to clean out soup buildup. Let us know if that fixes it.
RainVac
www.rainvac.com
800-523-0510
Jun 22, 2012 | Rainbow E series Canister Wet/Dry Vacuum
Aquamate tank wont pump
Not sure what version you have but the early version of the AquaMate II was very sensitive to clogging. No matter the version, run very hot water through all the lines in the wash cycle to clean out soup buildup. Let us know if that fixes it.
RainVac
www.rainvac.com
800-523-0510
Jun 15, 2012 | Rainbow E series Canister Wet/Dry Vacuum
VACUUM RUNS FOR A MIN AND THEN SHUTS OFF
It sounds like a problem with you motor. The hepa filter has nothing to do with the motor, and should not have been removed. It sounds like the repair man doesn't know much about rainbows. It could be a short in the motor housing or faulty/improper wiring. It may have happened after it when it was worked on the first time. Is it similar to the problem you were having before?
If you bought it from a rainbow dealer, you need to contact them, you should have a warranty, depending on when you bought it. If it is still under warranty, they will fix or replace it for free. If the warranty has expired, they may be able to work out a deal to get it fixed or may be able to direct you to a rainbow repairman.
Aug 09, 2009 | Rainbow E series Canister Wet/Dry Vacuum
Rainbow d4c
If it just quit running, it could be the cord. If you have a meter, you can check it to make sure it isn't broke. Take out the 4 I think, screw from the bottom, the top half should come off, then you get to the switch and the end of the cord. Check the motor brushes also, if they are worn down, they may not be conducting and the motor won't run. It gets involved, so don't know if you want to do this at home.
Feb 24, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Rainbow e series
It could if the separator is binding, or dragging, when it turns, causing the motor to over heat, that maybe what you are smelling. If it is, then replace the separator.
Dec 29, 2007 | Rainbow E series Canister Wet/Dry Vacuum
Rainbow Vacuum Cleaner starts slow smells hot
Sounds like the motor is going bad and will eventually not start. I am in the process of changing the motor in mine too and they are not cheap. just search around for a motor
Aug 31, 2007 | Rainbow E series Canister Wet/Dry Vacuum
Open Questions:
See all Rainbow E series Canister Wet/Dry Vacuum Questions
Rainbow E series Canister Wet/Dry Vacuum Logo
222 people viewed this question
Top Rainbow Vacuums Experts
Doris Wittkamm
Level 1 Expert
Jim Parker
Jim Parker
Are you a Rainbow Vacuum Expert? Answer questions, earn points and help others
